 trans press
3 posters
gosloriv
gosloriv
trans press Empty
PostSubject: trans press   trans press EmptyThu Jan 31, 2008 1:46 pm
does anyone know or remember where i can find a write up on installing a resistor to booost trans pressure !!!
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 1:56 pm
Trans pressure? For that you need this.
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=SAG&MfrPartNumber=MD28
Not electrical. It replaces the transmission shfit modualtor which controls trans fluid pressure.
You can adjust with the screw inside.
gosloriv
gosloriv
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 2:14 pm
no no i think on that other buickgs forum or whatever there was a thread on installing a resistor in the wire from the ecm to the pressure regulator in the trans that controls the pressure depending on the demand.
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 2:17 pm
Yes but you have a 4t60E trans. the resistor mod is for a 4t65E trans found on 97+ rivieras.
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 2:18 pm
yeah but i think the 95 and 96 rivs have a different transmission thats vacuum modulated and not electronic.
gosloriv
gosloriv
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 2:20 pm
OH !!!!!!! gotchya !!!!! thanks !!!! can you disconect the vacuum and boost pressure then ?
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 2:27 pm
that will cause undesired shifting results. You need the modulator.
gosloriv
gosloriv
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 2:31 pm
what kinda undesired results
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 3:03 pm
Incorrect shift ponts, bucking, sudden tcc lockup . stuff like that
gosloriv
gosloriv
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 3:07 pm
ic...........thank you very much. so what i cxan buy a hipo modulator?
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 3:26 pm
any auto parts store
gosloriv
gosloriv
trans press Empty
PostSubject: Re: trans press   trans press EmptyThu Jan 31, 2008 3:48 pm
ty again !!!!
trans press Empty
trans press
» Press-on SC pulley, or MPS?
» New Trans
» Trans oil
» ZZP trans pan
» 1997 N/A Trans?
Riv Performance ::   N/A 3800 Tech :: Series II N/A Engine, Transmission, PCM-
