| Write-Up: F-Body Brake Mod | |
+40bigdave matt270avian highwaywarrior charlieRobinson Jamax Karma #1BearsFan J. Chris Davis robotennis61 GMFreak8 helodown66 VJD2 Eldo KillaKeninaRiv 99prixgt Snowdog 98riv vendetta Rickw SuperRiv07 Supercharged TonySmooth89 Shintsu '96reese albertj Kustom Kreationz ewolfe0050 Buickman104 palermocorey90 jax95riv turtleman dreww Jack the R RivMan deekster_caddy T Riley AA racinfan oldsman105 Mr.Riviera 44 posters |
| Subject: Write-Up: F-Body Brake Mod Wed Feb 14, 2007 10:18 pm | |
| anyone know if the F-Body brake kit will work on a riviera? the 96's have 11" rotors and the 97+ have 12" IIRC. i just want to be able to stop better! i need new rear rotors b/c mine are getting thin and warped. do you think new Brembo rears will improve anything? (not drilled) or should i just get the cheap-o's at the local store? i almost ran into a semi today b/c... well, i was racing some jetta that thought he was the $h!t. i was doing about 80 and WAY up in front of him, but i digress. so a semi pulls out blocking all 3 lanes and then realizes he can't make the turn so he stops there!!! slaming on brakes at 80mph is not very fun. i was able to stop in plenty of time and probably could have stood on them a little more, but i feel like the car could have stopped sooner and with less nose dive. the abs didnt really have to do much but maybe thats just good tires? can i just go to the junk yard and pull some aluminum 2 piston calipers off a f-body? would i need 12" rotors too? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
oldsman105 Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Wed Feb 14, 2007 10:28 pm | |
| http://www.regalgs.org/forum/viewtopic.php?t=23860&highlight= http://www.regalgs.org/forum/viewtopic.php?t=22786&highlight= | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Feb 14, 2007 10:30 pm | |
| thank you i guess i should have looked there first :roll: but at the same time we have to grow here _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
racinfan Addict
| Subject: Re: Write-Up: F-Body Brake Mod Wed Feb 14, 2007 11:25 pm | |
| Are the sleeves necessary for our knuckles? | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu Feb 15, 2007 9:12 am | |
| and how about my rear rotor Q? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
racinfan Addict
| Subject: Re: Write-Up: F-Body Brake Mod Thu Feb 15, 2007 9:54 pm | |
| - racinfan wrote:
- Are the sleeves necessary for our knuckles?
I can't get ahold of rivman because his email is inactive and I don't think he's on regalgs anymore. It would be nice to know what needs to be tapped to match what for the mounting hardware....or if it is indeed a direct bolt up. | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu Feb 15, 2007 9:57 pm | |
| and are the brackes on the 96's attached to the knuckels? i cant even remember what they look like right now. i have some pics of front and rear stock setup but i didnt take any of the brackets we should make a clear write up of the parts needed to do the upgrade, i wish i had the $$ right now to buy some LS1 calipers, rotors,pads, etc, etc....it all adds up! _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu Feb 15, 2007 10:14 pm | |
| You can probably get a hold of Rivman with AIM, screen name: robstccg _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
racinfan Addict
| Subject: Re: Write-Up: F-Body Brake Mod Thu Feb 15, 2007 11:14 pm | |
- You can probably get a hold of Rivman with AIM, screen name: robstccg
Thanks, I left him a message. The '97-'99 cars share the same knuckles/control arms so that's good. It looks like all the necessary hardware can be had for about $100 shipped but its worth it for the extra pot. (pun intended) | |
oldsman105 Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Thu Feb 15, 2007 11:49 pm | |
| - Mr.Riviera wrote:
- and are the brackes on the 96's attached to the knuckels? i cant even remember what they look like right now. i have some pics of front and rear stock setup but i didnt take any of the brackets
we should make a clear write up of the parts needed to do the upgrade, i wish i had the $$ right now to buy some LS1 calipers, rotors,pads, etc, etc....it all adds up! yes we have the brackets attached to the knuckle . I am doing this also but bot till the summer. Shame because I need brakes now and i was hoping they would last into the summer to do the whole swap. We need to get rivman2 over hear. | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu Feb 15, 2007 11:56 pm | |
| quote " we need to get rivman2 over here." ... NEWS TEAM ASSEMBLE!!! ok i need some sleep now _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
oldsman105 Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Sat Feb 17, 2007 10:40 pm | |
| Did anyone contact rivman2 if not I will PM him to see if he will join the darkside. | |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Feb 18, 2007 12:18 pm | |
| Not sure, but I thought he got rid of his Riv? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: Write-Up: F-Body Brake Mod Sun Feb 18, 2007 3:55 pm | |
| dude is oldsman the "star wars dude" scaring anyone else??? whats up with all the star wars stuf ahhhahahha jk but seriously? | |
oldsman105 Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Sun Feb 18, 2007 4:12 pm | |
| What do you fear the Force
actually I am more Star Trek then Star Wars
oh and I pmed rivman2 | |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Feb 18, 2007 10:51 pm | |
| I have seen someone who installed the Fbody kit on a Grand Prix, I don't see any reason it wouldn't fit the Riv.
FWIW My '98 stops on a freakin dime with stock brakes. It's scary how fast it stops the few times I've really had to mash the brakes. I mean scary fast stopping. I was very very impressed.
I use cheapo rotors and really good raybestos pads. When I replace the pads I use new cheapo rotors. Yeah, they might warp easily, but they are so cheap... who cares?
-Derek | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Feb 19, 2007 8:36 am | |
| My '98 is very strong at stopping, but the earlier years had smaller discs. Wonder if there's a way to adapt later Riv brakes to the '96-97s? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Feb 19, 2007 12:21 pm | |
| Shouldn't be an issue to put the larger caliper brackets on. They do it for GP and GTP's all the time. I think you can use the GTP's GMPP Brake Upgrade kit to get the larger caliper brackets, pads and rotors.
Of course, I don't know for certain if the '95 and '96 had the same caliper bracket bolt pattern, but I don't see why they'd be any different.
As far as I can tell, there's no reason you need to get the stuff new from GMPP either. I beleive Ed Morad has a couple of late Riv's that should be good donors for the necessary parts. Any of the other large later Gbodys (Park Ave comes to mind) should make okay donors as well. | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Feb 19, 2007 1:31 pm | |
| i believe they are different, you guys with the 97+ brekas have it nice and easy if you want to upgrade to f-body calipers, but i think our (95 and 96) brackets are part of the suspension knuckle and that whole thing has to be replaced $$. you can find some 2 piston calipers on ebay for under $100 or you could go and spend 400 on a pre done package rivman2 said his rotors were 10.5" but i think mine are 11" and the 97+ are 12" besides having an extra piston and 1" larger surface area, are there any weight reduction benefits to the LS1 calipers and brackets? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RivMan Amateur
Name : Rob Location : Ypsilanti, Mi Joined : 2007-02-20 Post Count : 28 Merit : 2
| Subject: Re: Write-Up: F-Body Brake Mod Tue Feb 20, 2007 8:21 pm | |
| Hey guys
I'm here!
There is no easy way to swap out the newer brakes on the 95-96 Rivs. They don't have a seprate caliper bracket, the bracket is cast in to the steering knuckle. You have to replace the knuckle with one from a 97 Riv. (Not sure if the 98-99's are the same as 97, so I can't say if those work.) Also, if you swap out the 97 Kunckle, you have to use the 97 Spring and Strut assembly.
There is a pretty good weight differance between the 95-96 and 97 assemblys. The 95/96's have a 10.5" Rotor, Cast iron caliper, and Cast iron Kunckle. The 97's have a 12" Rotor, Aluminum Kunckle, Cast Iron Bracket and Caliper. The whole assembly is a little lighter, even with the larger rotor. The LS1 Calipers are even lighter.
-Rob | |
oldsman105 Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Tue Feb 20, 2007 8:39 pm | |
| I love it when a plan comes together . welcome rivman On topic. do you have to change the Lower contorl arms also? | |
RivMan Amateur
| Subject: Re: Write-Up: F-Body Brake Mod Tue Feb 20, 2007 8:41 pm | |
| I don't think you need to swap them out. They appear to be the same shape / size. The 97's are aluminum though, so I swapped them out.
-Rob | |
racinfan Addict
| Subject: Re: Write-Up: F-Body Brake Mod Tue Feb 20, 2007 11:11 pm | |
| - RivMan wrote:
- (Not sure if the 98-99's are the same as 97, so I can't say if those work.)
They are the same. I'm glad you checked the site out! | |
| Subject: Re: Write-Up: F-Body Brake Mod Sat Apr 07, 2007 11:01 pm | |
- My '98 is very strong at stopping, but the earlier years
had smaller discs. Wonder if there's a way to adapt later Riv brakes to the '96-97s? What's the difference between 97-98 disks? | |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Apr 08, 2007 3:19 pm | |
| Subject: Re: Write-Up: F-Body Brake Mod | |
