| Write-Up: F-Body Brake Mod | |
+40bigdave matt270avian highwaywarrior charlieRobinson Jamax Karma #1BearsFan J. Chris Davis robotennis61 GMFreak8 helodown66 VJD2 Eldo KillaKeninaRiv 99prixgt Snowdog 98riv vendetta Rickw SuperRiv07 Supercharged TonySmooth89 Shintsu '96reese albertj Kustom Kreationz ewolfe0050 Buickman104 palermocorey90 jax95riv turtleman dreww Jack the R RivMan deekster_caddy T Riley AA racinfan oldsman105 Mr.Riviera 44 posters |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Feb 18, 2007 10:51 pm | |
| I have seen someone who installed the Fbody kit on a Grand Prix, I don't see any reason it wouldn't fit the Riv.
FWIW My '98 stops on a freakin dime with stock brakes. It's scary how fast it stops the few times I've really had to mash the brakes. I mean scary fast stopping. I was very very impressed.
I use cheapo rotors and really good raybestos pads. When I replace the pads I use new cheapo rotors. Yeah, they might warp easily, but they are so cheap... who cares?
-Derek | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Feb 19, 2007 8:36 am | |
| My '98 is very strong at stopping, but the earlier years had smaller discs. Wonder if there's a way to adapt later Riv brakes to the '96-97s? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Feb 19, 2007 12:21 pm | |
| Shouldn't be an issue to put the larger caliper brackets on. They do it for GP and GTP's all the time. I think you can use the GTP's GMPP Brake Upgrade kit to get the larger caliper brackets, pads and rotors.
Of course, I don't know for certain if the '95 and '96 had the same caliper bracket bolt pattern, but I don't see why they'd be any different.
As far as I can tell, there's no reason you need to get the stuff new from GMPP either. I beleive Ed Morad has a couple of late Riv's that should be good donors for the necessary parts. Any of the other large later Gbodys (Park Ave comes to mind) should make okay donors as well. | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Feb 19, 2007 1:31 pm | |
| i believe they are different, you guys with the 97+ brekas have it nice and easy if you want to upgrade to f-body calipers, but i think our (95 and 96) brackets are part of the suspension knuckle and that whole thing has to be replaced $$. you can find some 2 piston calipers on ebay for under $100 or you could go and spend 400 on a pre done package rivman2 said his rotors were 10.5" but i think mine are 11" and the 97+ are 12" besides having an extra piston and 1" larger surface area, are there any weight reduction benefits to the LS1 calipers and brackets? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RivMan Amateur
Name : Rob Location : Ypsilanti, Mi Joined : 2007-02-20 Post Count : 28 Merit : 2
| Subject: Re: Write-Up: F-Body Brake Mod Tue Feb 20, 2007 8:21 pm | |
| Hey guys
I'm here!
There is no easy way to swap out the newer brakes on the 95-96 Rivs. They don't have a seprate caliper bracket, the bracket is cast in to the steering knuckle. You have to replace the knuckle with one from a 97 Riv. (Not sure if the 98-99's are the same as 97, so I can't say if those work.) Also, if you swap out the 97 Kunckle, you have to use the 97 Spring and Strut assembly.
There is a pretty good weight differance between the 95-96 and 97 assemblys. The 95/96's have a 10.5" Rotor, Cast iron caliper, and Cast iron Kunckle. The 97's have a 12" Rotor, Aluminum Kunckle, Cast Iron Bracket and Caliper. The whole assembly is a little lighter, even with the larger rotor. The LS1 Calipers are even lighter.
-Rob | |
oldsman105 Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Tue Feb 20, 2007 8:39 pm | |
| I love it when a plan comes together . welcome rivman On topic. do you have to change the Lower contorl arms also? | |
RivMan Amateur
| Subject: Re: Write-Up: F-Body Brake Mod Tue Feb 20, 2007 8:41 pm | |
| I don't think you need to swap them out. They appear to be the same shape / size. The 97's are aluminum though, so I swapped them out.
-Rob | |
racinfan Addict
| Subject: Re: Write-Up: F-Body Brake Mod Tue Feb 20, 2007 11:11 pm | |
| - RivMan wrote:
- (Not sure if the 98-99's are the same as 97, so I can't say if those work.)
They are the same. I'm glad you checked the site out! | |
| Subject: Re: Write-Up: F-Body Brake Mod Sat Apr 07, 2007 11:01 pm | |
- My '98 is very strong at stopping, but the earlier years
had smaller discs. Wonder if there's a way to adapt later Riv brakes to the '96-97s? What's the difference between 97-98 disks? | |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Apr 08, 2007 3:19 pm | |
dreww Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Mon May 14, 2007 2:25 am | |
| - RivMan wrote:
- Hey guys
I'm here!
-Rob so it sounds like its best to wait (if possible) until you upgrade your front suspension too. hit two birds with one stone. i must be one of the few 96's with no problems. But then again, I never have to slam on the braks and I coast as much as possible (as these cars will coast forever is seems like). I've only had the brakes serviced once in about 60,000 miles. and NO rotors were warped or had to be replaced. just pads. maybe I shouldn't mess with what works huh? | |
| Subject: Re: Write-Up: F-Body Brake Mod Sat Aug 04, 2007 1:29 am | |
| Ok, now i'm gonna do the f-body caliper upgrade and get new rotors and pads from work. I have a 97 so i already have 12" rotors so I get my stock rotors right then the f-body calipers, brackets, pins, and pads.. then all i have to worry about is the tapping/sleeving the bracket bolts right? last question is is there any problem using my existing brake hose on the f-body caliper. in this...
http://www.clubgp.com/newforum/tm.asp?m=2434239&p=1&tmode=1&smode=1
...excellent write up, he used new SS hoses that cost over $100. personally, i don't feel the need to spend that kind of money on the hoses. | |
| Subject: Re: Write-Up: F-Body Brake Mod Tue Aug 21, 2007 12:23 pm | |
oldsman105 Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Tue Aug 21, 2007 5:35 pm | |
| Great!!! Keep us updated on your progress . I will hopefully be picking up 97 front spindles and control arms to do the the upgrade as well. Your calipers look outstanding, I hope my calipers come out half as good as yours . | |
jax95riv Aficionado
| Subject: Re: Write-Up: F-Body Brake Mod Tue Aug 21, 2007 6:12 pm | |
| Very nice Codith, you're staying busy with the mods. The brake upgrade is one I want to do also! Keep us posted. | |
| Subject: Re: Write-Up: F-Body Brake Mod Tue Aug 21, 2007 7:37 pm | |
| Very cool! Nice work on the paint, looks clean. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
palermocorey90 Expert
| Subject: F-Body Brake Mod Fri Feb 01, 2008 8:38 pm | |
| im buying Cody's(turtleman) rims 19" konig imagine's , with the bigger size i dont want to risk my braking .what is the F-body brake mod . just bigger rotors and F-body calipers or what | |
Buickman104 Enthusiast
Age : 38 Location : New York City Joined : 2007-11-29 Post Count : 156 Merit : 0
| Subject: Re: Write-Up: F-Body Brake Mod Fri Feb 01, 2008 9:03 pm | |
| The F-body brake upgrade generally refers to upgrading to 12-13 inch rotors and to 2 piston calipers. For your year, you are going to need 1997 riviera front spindles. They sell the kit at the w-body store.
http://www.wbodystore.com/grandprix/w-body-store-12-inch-dual-piston-brake-kit-p-82.html
http://www.wbodystore.com/grandprix/w-body-store-13-inch-dual-piston-brake-kit-now-includes-lines-p-228.html | |
| Subject: Re: Write-Up: F-Body Brake Mod Sat Feb 02, 2008 8:46 am | |
| wont it be easier to go to a junk/scrap yard and get a set of F-body calipers and then order a set of 12" rotors | |
ewolfe0050 Aficionado
| Subject: Re: Write-Up: F-Body Brake Mod Sat Feb 02, 2008 10:32 am | |
| That's what I did but I also have a '97. You will need the '97+ spindle to do this. It shouldn't be that difficult. I think after locating the spindle you need to machine the holes to fit the ball joints it think. There's some trhead on how to do it somewhere here... | |
| Subject: Re: Write-Up: F-Body Brake Mod Sat Feb 02, 2008 10:35 am | |
T Riley Guru
| Subject: Re: Write-Up: F-Body Brake Mod Sat Feb 02, 2008 10:41 am | |
| I would be interested in finding that Write up too.......... i think i might do that mod...... | |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Feb 03, 2008 1:48 am | |
| so could i get a list im going to the bone yard in the morning(well non cuz im sleeping in) | |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Feb 03, 2008 9:14 pm | |
| 97+ riviera spindle (lower knuckle) f-body caliper f-body caliper bracket and hardware 12" rotors pads for a f-body posible longer brake lines that should be all, but then again i havent done this so i cant say for sure. rivman did this on his 95 and he is the one who did the write up. i dont know where it is (either it has been moved to this site or it is still on regalgs.org i also think rivmans cardomain site had some pics of the mod _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Feb 04, 2008 3:16 pm | |
| Subject: Re: Write-Up: F-Body Brake Mod | |
