| Write-Up: F-Body Brake Mod | |
+40bigdave matt270avian highwaywarrior charlieRobinson Jamax Karma #1BearsFan J. Chris Davis robotennis61 GMFreak8 helodown66 VJD2 Eldo KillaKeninaRiv 99prixgt Snowdog 98riv vendetta Rickw SuperRiv07 Supercharged TonySmooth89 Shintsu '96reese albertj Kustom Kreationz ewolfe0050 Buickman104 palermocorey90 jax95riv turtleman dreww Jack the R RivMan deekster_caddy T Riley AA racinfan oldsman105 Mr.Riviera 44 posters |
ewolfe0050 Aficionado
| Subject: Re: Write-Up: F-Body Brake Mod Tue Sep 29, 2009 9:42 pm | |
| I don't have my stock wheels anymore... but I know there are certain types of stocker 15's that will clear stock brake setups such as the earlier Grand Prix's. From what I understand there is an aftermarket aluminum drag wheel that will work but they cost $400...
The guy selling them also has a set of MT ET Streets in a 26x10x16 but they aren't full slicks.
He also has a set of BFG GFoirce TA Drag Radials in a 275-50R16 but those are 26.8x10.5x16. I can do the 10.5 wide but 26.8 might be too tall... | |
| Subject: Re: Write-Up: F-Body Brake Mod Tue Sep 29, 2009 10:11 pm | |
| stock 16" riv wheels have about 1/4" clearance from the fins on the fbody's. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Sep 30, 2009 11:01 am | |
| It sound like the GForce Drag Radials don't expand as much as the bias ply ones so I should be fine running the 26.8x10.5x16's. They don't have too much left in them but should last about 3-4 track outings with 6-7 each outing which would last me a year and a half or so. Plus I think I can get them for $20 each. Now i need to find a lightweight stock 16x8 rim... I think the new mustang has the 15x8 aluminum five spoke rim and will fit the Riv. | |
'96reese Fanatic
| Subject: Re: Write-Up: F-Body Brake Mod Thu Oct 01, 2009 12:03 am | |
| has anyone figured out if the 97 knuckle eill fit on a 96? i really want to do this mod | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu Oct 01, 2009 6:33 am | |
| Read this thread from the beginning.. All you need to know should be in here. It has been done before, successfully. | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu Oct 01, 2009 9:51 am | |
| it's actually been done twice on a 96. (Oldsman and me) well worth the $1000 to stop like a race car from 120mph _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu Oct 01, 2009 10:20 am | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Nov 02, 2009 1:49 pm | |
| I have a pair of F Body caliper brackets with the correct mounting bolts and bushings for someone that is interested in upgrading to an F body dual piston caliper. They will bolt up without modification to the 97-99. 96 requires a lot more stuff as mentioned in this Write Up. PM me if you have a need for them.
EDIT: These are SOLD
KillaKeninaRiv Addict
Name : Kenneth Age : 41 Location : Roseville, MI Joined : 2008-05-17 Post Count : 709 Merit : 6
| Subject: Re: Write-Up: F-Body Brake Mod Tue Apr 27, 2010 9:44 pm | |
| I did find those calipers, $30 for the set. ..but I still want those F-Body ones. Tomorrow Im going junkyard hopping and see if I can find some. Im not sure what to take exactly, so Im going to take the entire thing from the strut down | |
| Subject: Re: Write-Up: F-Body Brake Mod Tue Apr 27, 2010 10:23 pm | |
| for the 97' you would need the caliper, bracket and pads. you would also need to but the bolt spacers to make the stock riv bolts fit the f-body brackets. i went to the junk yard today and there was a bunch of f-body calipers there but they were all under half a foot of dirt since they take the wheels off the cars to sell them. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 3:53 am | |
| Are the bolt spacers found on the F-Body calipers or is this something on the Riviera? Also, are there any other cars I can check for the F-Body brake system? | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 12:20 pm | |
| the C5 corvette has the same calipers and brackets as the f-body cars, but you will likely pay more cor the "corvette" paint on them. as for the spacers, take a look at the write-up. i believe it shows what you need to buy to make them work. they are not found on any vehicle, but something you must order from a machine shop online. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 3:55 pm | |
| I purchased the ones I needed from McMaster-Carr. The P/N and contact information is in this write-up somewhere, IIRC. It's better if you take the used F-Body brackets that your getting with the calipers at the boneyard and bring them to the machine shop for drilling and tapping. Then you wont need the bushings. The drilling spec's are also listed in this thread. This allows you to use the original bolts that are on your Riv now. They are larger in diameter and thread pitch. It's up to you, you can go either way. I had bushings and F-Body bolts on mine for about 7,000 miles and when I replaced them with a drilled and tapped set they had no wear on them at all. The only reason I changed over was that someone had mentioned a wear problem with the bushings that started to affect his braking. He could feel and hear the calipers and mounts moving. I did not have that problem, as it turns out. But I don't drive the brakes hard, most of the time. - KillaKeninaRiv wrote:
- I did find those calipers, $30 for the set. ..but I still want those F-Body ones. Tomorrow Im going junkyard hopping and see if I can find some. Im not sure what to take exactly, so Im going to take the entire thing from the strut down
What calipers are you talking about for $30.00.? Try E-Bay Motors for and F-Body set if you can't get them at a local junkyard. Any Camaro or Firebird from 98-02 will work. Then you need the front brake lines for a bonneville from ZZP. Again all this info is already in this thread or any other thread that discusses F-Body brakes. | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 4:35 pm | |
| IIRC AA had the bushing problem. | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 4:51 pm | |
| I did have this problem, and so did ewolfe and everyone else who's done the F-Body mod to Grand Prix or Regals. It's not bad at first, but after 10k miles or so it will happen. Member 99prixgt warned us about this on page 15 of this thread. Don't use the bushings, get your brackets drilled and tapped. The brake system is much too critical to skimp on this. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 5:06 pm | |
| I agree with the drilling and tapping, that's why I changed mine before I had any problems. Back when I initially did the F-Body mod and sold some rebuilt kits we were not aware of any potential problems with the bushing eventually wearing some and causing movement of the brackets on the bolts. Otherwise I would have added that step to the process, would have had to charge more but as we are finding out it is worth the extra step. It's no big deal to do. It's just having the right size drill and metric tap to finish things up and use the OEM Riviera Bolts. If you have a drill press at home and the necessary bits it won't even take an hour to do all 4 holes. | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 5:11 pm | |
| I have a tap if anyone wants to use it - just pay shipping. It's a cheap tool, probably not good for more than one more pair of brackets. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 5:23 pm | |
| PM Sent Have to do one more set that I've sold, before shipping. | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 9:48 pm | |
| Thanks! Rounding up the parts shouldnt be hard, but finding a Camaro is the thing... | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed Apr 28, 2010 10:23 pm | |
| Finding a 98 to 2002 Firebird or Camero is no problem what so ever at almost any junkyard in the US. They made shit loads of these cars and I only had to look for 15 minutes on Ebay Motors and had 3 sets delivered. At the time I didn't even think to look in my local yards, and I live in the middle of nowhere and there were 2 in that yard I could have picked from. They can be your most basic 6 cylinder car and they have the same 2 piston aluminum calipers with cast iron brackets, that's all you need. Take off the 2 bolts that hold the brackets and calipers on and your done. Have you read this thread.? I thought it was all spelled out quite clear. Maybe not, I haven't had to read it since I did my thing. Just DO IT. | |
| Subject: Re: Write-Up: F-Body Brake Mod Tue May 04, 2010 10:10 pm | |
| Not around here. All the Camaros I found at the lots around here are early 90s models. I would rather have the option of pulling them myself than paying $100 for a pair on ebay, along with high shipping. | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed May 05, 2010 1:32 am | |
- Not around here. All the Camaros I found at the lots around here are early 90s models. I would rather have the option of pulling them myself than paying $100 for a pair on ebay, along with high shipping.
The ones i found on EBay were not $100.00 with high shipping. And i bought used with the intention of completely re-building before selling or using them myself. So for me it wasn't that big a deal. The other thing you can do is get a rebuilt pair from one of your friendly parts stores, install them with the correct front brake hose and then a couple of days later return your old ones as cores and get your core fee back. Then you will have rebuilt units with a warranty for about $60.00 each. Is that a little easier for you. | |
| Subject: Re: Write-Up: F-Body Brake Mod Wed May 05, 2010 6:58 pm | |
| Now lets see...as far as pricing, I guess what you could call an ''affordable'' set of calipers ends up costing a grand total of $203.60 shipped, not to mention the $109.99 +shipping for the brake lines from zzperformance. Now, in all fairness, a week ago I saw a caliper on ebay for roughly $80 apiece, so maybe thats where your savings come in at- $25.
We all arent mechanical masters here. We also dont have anything better to do with our time than rebuilding calipers either. There are people here with REAL lives and livelihoods who have better things to do than blow $400 on calipers. Maybe the answer is in here, maybe it isnt. However I can think of better things to do than read through 22 pages of 75% chit chat to find a simple answer, such as thump my nutsack! | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 06, 2010 12:31 am | |
...We all aren't mechanical masters here. We also don't have anything better to do with our time than rebuilding calipers either. There are people here with REAL lives and livelihoods who have better things to do than blow $400 on calipers. All name-calling aside, which is currently being purged, I have a purely mechanical (and polite) observation... In Ken's quote above, his implications are that he: -does not have unlimited time for wrenching, -is not an expert mechanic, and -doesn't have a lot of money to blow on F-body brakes. Given these stated limitations, why would someone want to pursue such a relatively major modification? | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 06, 2010 4:48 am | |
| I have plenty of money to blow, I just wont blow it on something that APPEARED to be a quick mod and has little for me to get out of it. For instance, the machining part. I have to save my money for buying a house and my honeymoon, so to just jack off an easy $400 for me wouldn't make sense, just to stop 20 ft faster? That would be absolutely pointless for my cars setup. My thinking was that it was something SIMPLE not so in depth. The trouble comes in, not with the mod itself, because if I wanted to I could, but in the lack of respect for others through TWO separate posts which shows scorn and contempt. But....that was yesterday, and I'm off that. He said his piece, I said mine, so everyone knows where we stand on that.
Now to make things a little easier, there could be a scale in the maintenance section that allows you to see the relative ease or complexity of the certain mod/maintenance that you are doing. This way, you don't run into the problem of a novice attempting at installing a turbo kit and looking for answers on here. Then you'd know whether or not you were out of your league before you even attempted it, and there would be no instances of name calling. Similar to buying a Transformer for a kid. If it says 10+, you probably wouldn't buy it for a 4 year old and expect him to be able to operate it. I believe they do that on zzperformance? I mean, you probably wouldn't want someone who only has experience in oil changes and brakes giving you advice on a installing a cam now would you? I ran into that problem with my Bonneville. When I asked a guy about the differentials and gear ratios for an SLE, I got 4 different answers from 4 different people. And only one was right. What were the others? ROOKIES! | |
| Subject: Re: Write-Up: F-Body Brake Mod | |
