| Write-Up: F-Body Brake Mod | |
+40bigdave matt270avian highwaywarrior charlieRobinson Jamax Karma #1BearsFan J. Chris Davis robotennis61 GMFreak8 helodown66 VJD2 Eldo KillaKeninaRiv 99prixgt Snowdog 98riv vendetta Rickw SuperRiv07 Supercharged TonySmooth89 Shintsu '96reese albertj Kustom Kreationz ewolfe0050 Buickman104 palermocorey90 jax95riv turtleman dreww Jack the R RivMan deekster_caddy T Riley AA racinfan oldsman105 Mr.Riviera 44 posters |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Apr 27, 2008 11:05 pm | |
| I saw blue, red, yellow, black, silver, at the store. You could also use engine paint, or any hi-temp paint. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
TonySmooth89 Aficionado
| Subject: Re: Write-Up: F-Body Brake Mod Sun Apr 27, 2008 11:10 pm | |
| - Mr.Riviera wrote:
- on a side note, one of the worst pedal feels has to be in the chevy/gmc suburbans. absolutely horrible.
Idk , my sister had an 04 or 05 impala , and its brake pedal feel was pretty terrible too. | |
Shintsu Expert
| Subject: Re: Write-Up: F-Body Brake Mod Sun Apr 27, 2008 11:13 pm | |
| What store did you see it at? | |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Apr 27, 2008 11:14 pm | |
| Autozone. Duplicolor brand. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: F-Body Brake Mod Sun Apr 27, 2008 11:44 pm | |
I'll second that. They feel like they despirately need to be bled and you can actually put your foot down on the brake and hit the floorboard if you want. I did this while it was in park. I think part of the blame has to go to the adjustable pedals most of those models have. | |
| Subject: Re: Write-Up: F-Body Brake Mod Mon Apr 28, 2008 1:22 pm | |
| WARNING: check SS brake hose clearance AFTER installing tires. I neglected to do this, and noticed a slight rubbing sound when turning the wheel for parking and slow cornering. Not much wear, but it's evident the tire has made some contact with the brake hose.
I think I can turn the nut on the end of the hoses to "aim" them away from the wheel. Will try to do this tomorrow. Until then, guess I'll not turn the car! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
'96reese Fanatic
| Subject: Re: Write-Up: F-Body Brake Mod Mon Apr 28, 2008 9:29 pm | |
| what year f body calipers do you guys suggest | |
| Subject: Re: Write-Up: F-Body Brake Mod Tue Apr 29, 2008 9:35 am | |
| 1998-2002 2-piston aluminum calipers. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Shintsu Expert
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 01, 2008 1:07 am | |
| So what all would be necessary to do this swap on a '96? | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 01, 2008 8:12 am | |
| see page 1 _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 01, 2008 10:45 am | |
| Fixed the hose problem last night. First I tried to rotate the hoses at the fitting in the bracket. This didn't work, as they would just rotate back with the wheel straight. I didn't want to use zip-ties, but it seems to be the best way for now. Tried going around the strut, but didn't like the way it bent the line at max turn, so I used the hole for the stock strut bracket to loop the tie through. I left some slack for the line to flex, and just enough so that the line and tire can't touch. Here's a view of the passenger side with wheel turned left: Here's a view with wheel turned right: Another view showing clearance with wheel turned right: So far, there are no more contact issues. My only concern at this point is how long the zip-ties will hold up. Will check them for wear next time the wheels are off. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Shintsu Expert
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 01, 2008 2:47 pm | |
| Wow, lots of work and parts and possible contact issues and other stuff. Yet another area where the Riv fails at being modded simply. Eh, no thanks mine already stops good so I'll just leave them alone. On a side note, could they have made the Riv any more mod unfriendly? | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 01, 2008 3:17 pm | |
| See it how you like, but the hoses are the only real issue here. Zip-ties are not the best-looking fastener, but they do the job. There's no reason for anyone to make custom brake lines for the Riviera application. Only a dozen people at most are going to do it.
This is an inexpensive, easy to do, and noticeable performance mod. If anything, the Riv is mod-friendly in this regard. GM makes a Buick lux-cruiser that allows bolt-on compatibility with 2-piston SS Camaro brakes with near 20% more pad area than stock. Can you bold on Mustang Cobra brakes to a Mark VIII? Can you put Lambo brakes on an Audi? Porsche calipers on a VW? Maybe, I don't know.
If you see this too difficult, I don't know why. I couldn't see how it could get much easier. I put these on and changed my brake fluid in 4 hours! I drove the car 250 miles the next day. Take your car up to 95 mph and slam on the brakes, then tell me how it stops good. I did this yesterday and was amazed at how fast the car slowed down. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
ewolfe0050 Aficionado
| AA- I didn't have that problem but then again I'm running much larger wheels. If you don't like the ziptie you could always go to 20" rims | |
Shintsu Expert
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 01, 2008 3:22 pm | |
| Because most everyone here has a '97 or newer. If not, they have a '95 (The oddball year). For some reason the '96 is the odd year out on here with not too many around here. I'm totally inexperienced at any car modifying so at this point most everything looks intimidating to me. I like the idea that cars that have mods made for them (i.e. Civics, Mustangs, etc.) have instructions or just bolt in easily with no confusion.
You all claim that sway bar makes a big diffrence too but some of you said they didn't fit and had to do some other work to make them fit. I just don't think this car is suited for mods too well. As long as there wasn't anything else special between persay an Audi and Lambo like extra connectors or something you probably could fit one on there but the issue then is the price (Aren't the high end brakes that are optional on Lambos like a 16k option?). | |
oldsman105 Junkie
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 01, 2008 7:19 pm | |
| Thanks Aaron for showing that problem. Thats one less problem to surprise me during my upgrade. | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 9:21 am | |
| Update: after 3 weeks of the daily grind with the new brakes, I started noticing a few things odd. First, about a week ago, I heard a popping sound that seemed random, but then noticed it happened when braking in reverse, then braking for the first time going forward. After a day, this sound went away.
Not long afterward, I noticed my pads would screech at some odd times, like when taking curves, or just whenever they wanted. Once they just started on the freeway, then stopped. Strange.
For the next couple days, it went pretty well, but I noticed the front end felt a bit sloppy. Thinking it was in my head, I ignored this, but it got worse. It just felt like something was loose, like a stabilizer bar, or a strut, or a control arm... or a caliper.
So last night I cranked my wheels left and right, found that both calipers could be wobbled by hand! All four of the 18mm bolts that hold them on were just past finger tight. I tightened them up pretty good this time. Car is now back to normal. Yes, I'm sure I tightened them 3 weeks ago. It's the last thing I did, I remember very well.
This surprised me, because the old bolts seemed to get tighter as time went on. I had to use an impact to get those suckers off - every time. I actually considered using anti-seize, but never did. The new F-Body bolts are narrower, don't use the iron spacer ring, but have an 18mm head instead of Buick's 15mm. I will check them in a couple of weeks. Maybe some thread locker will be needed. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 9:26 am | |
| AHHHHHHHHHH.... that wouldn't have been much fun for you AA!!!!!!!! | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 9:30 am | |
| No, not fun. Good news was, they were nowhere near coming all the way out... yet. Also, you can check/tighten them with the car on the ground. Takes about 2 mins.
Still, it's something to be aware of. Everyone doing this mod should check these bolts after a couple thousand miles. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 9:34 am | |
- No, not fun. Good news was, they were nowhere near coming all the way out... yet. Also, you can check/tighten them with the car on the ground. Takes about 2 mins.
Still, it's something to be aware of. Everyone doing this mod should check these bolts after a couple thousand miles. Makes me think to check my stockers before the tranny goes in btw about less than 2-3 days before the riv is ROLLIN again | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 9:40 am | |
| Check them, but I've never had a problem with the stock caliper bolts. Always snugged them up tight after doing the brakes, but not too tight. I was afraid of them seizing. Without an impact gun, mine were near impossible to break each time I took them off. PB Blaster is a dear friend! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
T Riley Guru
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 9:44 am | |
- Check them, I have never had a problem with the stock caliper bolts. Always snugged them up tight after doing the brakes, but not too tight. I was afraid of them seizing. Without an impact gun, mine were near impossible to break each time I took them off. PB Blaster is a dear friend!
1/2 inch breaker bar.......... we dont have air tools at my house........ but A TON of wrenches and sockets ............. | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 9:54 am | |
| Before I got the impact, I used a 1/2 ratchet. First time, I'm not kidding, on driver side, I put the ratchet handle on a hydraulic jack. Could see it compressing the suspension as I jacked it up. Thought I was either going to break the wrench or lift the car off the stand! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 3:41 pm | |
- Thought I was either going to break the wrench or lift the car off the stand!
When did you start taking steroids?
Last edited by 98riviera98 on Thu May 15, 2008 4:53 pm; edited 1 time in total | |
| Subject: Re: Write-Up: F-Body Brake Mod Thu May 15, 2008 4:04 pm | |
- I put the ratchet handle on a hydraulic jack.
| Subject: Re: Write-Up: F-Body Brake Mod | |
