 pulled a code......... :(
3 posters
pulled a code......... :( Empty
PostSubject: pulled a code......... :(   pulled a code......... :( EmptyWed Feb 06, 2008 3:21 pm
i drove the car through first gear hard all the way through first and into second and all of a sudden i got a code.......... first code in 3-4 months KINDA jinxed myself by telling a freind that i havent had a problem for awhile today.......... ANYWAYS the code is something about the front bank running lean AND ALSO i got a camshaft position sensor code.............. why at the same time?? suspect i'll keep driving spirited and see if it decides to pop up again. grimace
PostSubject: Re: pulled a code......... :(   pulled a code......... :( EmptyWed Feb 06, 2008 5:01 pm
you dont have the actual codes? did you feel a misfire when it happened?
pulled a code......... :( Dsc_0110
BillBoost37
Merit : 26
PostSubject: Re: pulled a code......... :(   pulled a code......... :( EmptyThu Feb 07, 2008 7:06 am
Odd..I literally posted the lean bank code in another thread.
P0171 Lean Bank 1 sound familiar?
Typical causes of this code (I always find new ways to have it pop up bonk )
1. Check your battery connectors to be clean, tight and in good condition. Pull the cable, check under the boots.
2. Check to ensure your evap lines are properly routed to the evap switch/soleniod. Reversing them will cause this code.
3. Check your maf, the fsm loves to blame the maf for this code...I've yet to see it be the cause on my car.
I can't stress #1 quite enough. My cables were replaced from being corroded internally and causing the problem.
PostSubject: Re: pulled a code......... :(   pulled a code......... :( EmptyThu Feb 07, 2008 3:28 pm
THANK YOU man....... i reset the light........... BUT i did reconnect the battery under my rear seat........... and you know what shocked loose positive cable.
BillBoost37
Merit : 26
PostSubject: Re: pulled a code......... :(   pulled a code......... :( EmptyFri Feb 08, 2008 6:47 am
Glad to help others after having suffered pain and agony to that code.
» Error code
» FAQ: Mass Air Flow (MAF) Sensor Issues?
» New code, what is it? Please help if possible!!!!
» P0440 code??
» FAQ: Riviera Paint Colors/Codes
