 Error code
3 posters
Error code Empty
PostSubject: Error code   Error code EmptyTue Jan 08, 2008 12:26 pm
P0141.... O2 sensor heater circuit malfuntion.( bank 1 sensor 2). it came up a few weeks ago got the code and cleared it and it didnt come back for about two weeks...does this mean i should just replace the sensorr? i about 17-19 driving in town so my sensor probably isnt reading too badly.
Error code Empty
PostSubject: Re: Error code   Error code EmptyTue Jan 08, 2008 1:25 pm
I believe sensor 2 would be the one at the cat. It won't affect driveability. Should replace it though.
Error code Empty
PostSubject: Re: Error code   Error code EmptyTue Jan 08, 2008 2:17 pm
thanks...can anyone else confirm that it is the one on the cat before i go ahead and do it.
Error code Empty
PostSubject: Re: Error code   Error code EmptyTue Jan 08, 2008 2:22 pm
You can get a rear O2 simulator if you are ever going to do anything with an aftermarket cat, now's the time... and it's cheaper than a new O2 sensor.
Disconnect the battery when you are installing it if you don't have any way to clear the codes otherwise. Codes will 'clear' if the battery is disconnected for 20 minutes or so.
Error code Empty
PostSubject: Re: Error code   Error code EmptyTue Jan 08, 2008 2:27 pm
well i was thinking about getting a 3in dp with no cat so i might just do that and i have a cheap little scanner i got at autozone that reads and clears codes so thats not a problem... i had a 20 dollar credit and it was only like 60 bucks. the only thing with the 02 sim is that zzperformances says it only works with the 98-99 rivs and idk anywhere else that sells them.
Error code Empty
Error code
» Error Code
» Po442 Error Code
» Error opening .bin file with DHP
» Error Code P1870
» '98 trans needs new belt due to slippage ?
