 Front Cornering Lamp Bulb Replacement?
Go to page : Previous  1, 2
LaFlare
Front Cornering Lamp Bulb Replacement? - Page 2 Empty
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyThu Apr 05, 2012 12:46 am
Eldo wrote:
Eldo wrote:
Anyone know of a brighter bulb to replace these 3057's with?
LEDLight.com has a 3157 (p/n 44634) that is a direct replacement for the 3057 with 19 LED's and (p/n 84563) with 27 LED's that are not only brighter but have lower heat generation, shock and vibration proof. They claim virtually unbreakable. (others with 32 and 36 LED's)
They have a large catalog of 12v lights. Check them out.
Thanks for another tip, Rick
has anyone replaced their cornering lights with these? i need to do mines and these look like a good alternative, but i'd like to see how they actually look beforehand if anyone has pics or vids with these.... if not i'll prolly just replaced em with the regular bulbs
ironclyde
ironclyde
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyTue Mar 25, 2014 2:20 am
I took the l/f cornering lens out to make a ramp for cold air to get into the fender by the airbox. I don't know if it helps improve power, but I can hear the SC whine a lot better.
JR3800
PostSubject: cornering lamp question   Front Cornering Lamp Bulb Replacement? - Page 2 EmptySun Oct 05, 2014 8:42 am
Hey everyone one of my cornering lamps went out, got it replaced with another 3057 not a big deal. other than that stupid bolt under the housing. Anyways, I noticed when I was testing the light that only one filament would light up same as the other side? so why are these bulbs double filament scratch is there a way to get both of the filaments to light up wouldn't hurt having a little extra brightness to combat the haze !
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptySun Oct 05, 2014 10:17 am
Without going outside and take a look at it myself, I assume you could get a new socket that supports both filaments and switch it out for the existing socket. You might have to modify the tangs on the socket or housing though as many are keyed differently.
Then you'd just wire the other filament to a hot lead from the headlights.
I did something similar when 'enabling' the cornering lamps on my 95 Roadmaster. Mine is not the "Limited" so it didn't come with the cornering lamps enabled.
JR3800
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptySun Oct 05, 2014 5:15 pm
ahh I see, well good info thanks ! now to hunt for a socket...
Merit : 102
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyThu Oct 09, 2014 2:36 am
Hi Jake,
Believe it or not, this is classic GM bullshit!   wink
At a certain point, with 5 lines of automobiles, it actually makes financial sense to 'waste' parts or wires...  Your double-filament socket IS correct.   They simply used the higher-power "brake-light" for the cornering light, instead of a lower-power 1156 or 194...
I will tell you from my own experience that you CAN simply solder across the terminals of the bulb to make both filament light, but it really won't make much discernible difference in light...  Adding the 'tail light' to the 'brake light' doesn't help much.
In my own car, I bought either 1157 or 1156 HALOGEN bulbs for brighter cornering lights.
Merit : 152
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyWed Oct 15, 2014 7:57 pm
i wonder if it would be nice to wire the dim filament to the parking lights? Campaign to strike dumb ideas.
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyMon Apr 20, 2015 11:58 pm
nervous
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyTue Apr 21, 2015 12:51 am
JohnRedman
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyMon May 22, 2017 4:02 pm
How does now remove/replace the cornering light assembly? The front tab on my right side somehow broke leaving it floppy. I managed to get it far enough tilted out to apply JB plastic weld but now I cannot maneuver it back into position. Do I have to remove the entire front bumper to get at it (I sure hope not)?
Merit : 111
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyMon May 22, 2017 4:08 pm
Push down the bumper cover a bit. You'll see one little bolt. After that, it pulls right off. The lens has small spring clips.
PostSubject: Re: Front Cornering Lamp Bulb Replacement?   Front Cornering Lamp Bulb Replacement? - Page 2 EmptyMon May 22, 2017 4:26 pm
Merged thread. See page 1.
» RZR S sloppy frontend
» rzrs frame replacement
» rzr deluxe front brushguard for sale
» rzr front diff. rebuild
» Polaris Rzr Deluxe front Brushguard for sale
