 two problems with 95 rivi S/C
scoopy03
two problems with 95 rivi S/C Empty
PostSubject: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptyFri Feb 08, 2008 2:06 pm
while the car is running in park and in drive sounds like rocks are in it sounds like around the torque convertor. usually can only hear it up to around 1.5k-2k rpms. the 2nd problem that is occuring is the car wont read temp. changed out the coolant temp. sensor and still not reading.
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptyFri Feb 08, 2008 3:11 pm
The "rock noise" is probably a heat shield that is rattling around. There is a couple around the front manifolds and the one that gave me problems, is around the second O2 sensor. Don't know about the temp...
Merit : 153
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptyFri Feb 08, 2008 4:08 pm
"marbles in a can" sound is often the water pump dying. Or could be your supercharger coupler is worn (about worn out, actually). Or the heat shield mentioned above. (you'll have to put it on blocks and have a look)
No reading on coolant temp? Okay, did you just get the car and it's doing this or did it work before & quit after you did other work... or what?
By the way - also - how many miles on your Riv? Sometimes these problems are related to components reaching their, ahem, engineered lifetime.
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptyFri Feb 08, 2008 4:12 pm
My transmission made a similar sound, along with a whine (sounds like power steering), about 6-9 months (20k miles) before it failed. Do you have a modified air intake?
scoopy03
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptyFri Feb 08, 2008 6:24 pm
it is a stock rivi with 153,000 on her. just got her this week. no cold air intake yet. just stock airbox.
BillBoost37
Merit : 25
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptyMon Feb 11, 2008 7:15 am
You could name off a bunch of things this could be with rock noise.
My first thought was bottom end.
scoopy03
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptyWed Feb 13, 2008 12:05 am
only hear it in park neutral and drive. stands out most in neutral.
Merit : 153
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptyWed Feb 13, 2008 1:32 am
Ok scoopy03 - do u want to work on the sensor & gauge, or the rocks, first?
Guest
Guest
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptySat Apr 05, 2008 8:18 am
My 95 has the same knock(loud click) at idle right in the side pan of the trans, knocks a few times and goes away when i rev the engine, not real loud though. then i can make it knock by revving the motor twice back to back. ie: rev,...rev,.. idle down,... knock. guy at parts store said it might be the out put shaft bearing,? I told him it knocks coming into a parking lot, let off gas,... give it gas to move,..i get a knock, let off gas again and give it gas to keep moving,.. it's gone. and it's more of a loud click then a knock.
another thing is when i test drove it, i knew it had a trans issue, owner said it slipped going around corners once a week. so when i drove it
I did a full peddle take off . the car leap up and took off 1st, 2nd, half way through 3rd it kinda popped and lost power, till i backed off the peddle, trans reengaged fine, and shifted into overdrive. as long as i don't hammer it, it shifts fine. I'm sure it needs a trans service, but if it's not a switch in the trans doing this, I ready to put a newer trans in it. (CV's are in good shape) any thoughts???
Thxz guys J.
PostSubject: Re: two problems with 95 rivi S/C   two problems with 95 rivi S/C EmptySat Apr 05, 2008 5:32 pm
could be a cracked flexplate.
» RZR Wheel Hub Problems?
» 3500 still has problems
» GPX 4000 Problems
» Transmission problems
» Weber alternator problems
