| Water sounds behind the dash... | |
jax95riv Aficionado
| Subject: Water sounds behind the dash... Fri Feb 08, 2008 5:50 pm | |
| OK, call me crazy, but when I turn a corner I can here liquid moving back and forth behind the dash. I don't see any leaks and no anti freeze smell so I don't think it's the heater core. Has anyone else noticed this issue or does anyone have a guess as to what it might be? Thanks. | |
Dj Brady Enthusiast
Name : Brady Age : 49 Location : Wilmore, Ky Joined : 2008-02-04 Post Count : 150 Merit : 0
| Subject: Re: Water sounds behind the dash... Fri Feb 08, 2008 6:35 pm | |
| Does the fish tank have a leak? :O
is there any chance condensation is pooling in your heater vents or firewall tray? | |
Natesriv Addict
Name : Nate Age : 54 Location : KCMO Joined : 2007-01-18 Post Count : 509 Merit : 16
| Subject: Re: Water sounds behind the dash... Fri Feb 08, 2008 7:42 pm | |
| I wonder if it's behind the cowl...When water runs down the windshield by the wipers where does it go? Is it possible to remove the wipers, remove that plastic cowl and there's room under there? | |
| Subject: Re: Water sounds behind the dash... Fri Feb 08, 2008 7:44 pm | |
| Air bubble in the coolant? Not sure, just throwing that out there. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
jax95riv Aficionado
| Subject: Re: Water sounds behind the dash... Fri Feb 08, 2008 10:44 pm | |
| Not sure, I'll have to look around this weekend. It sounds like it's up high on the dash (like radio level). I was thinking along the same lines as Nate. It's a good amout of fluid from the sound of it. | |
ewolfe0050 Aficionado
| Subject: Re: Water sounds behind the dash... Fri Feb 08, 2008 11:20 pm | |
| If you have a sunroof, sometimes the channels get clogged and you hear a gurgling effect. Mine does it in heavy rain. You can hear it down the A pillar. | |
jax95riv Aficionado
| Subject: Re: Water sounds behind the dash... Sat Feb 09, 2008 12:19 am | |
| Subject: Re: Water sounds behind the dash... Sat Feb 09, 2008 2:10 am | |
| CHeck the conensate drain for the a/c evaporator. If you open the hood and look at the firewall not far to the right of the passenger-side strut tower you should find it.
Might need to use a pipe cleaner to clean it out. Might have to do that from under the car.
A hint this might be a problem - a humid or musty smell from the HVAC especially the dash vents.
| Subject: Re: Water sounds behind the dash... | |
