 How can I get the power antennae to lower ?
How can I get the power antennae to lower ? Empty
PostSubject: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptySat Feb 09, 2008 5:44 pm
The power antennae on my 99 Riv is stuck, it extended and will not retract.
I have tried pushing it down but it wont go.
I have connected the power, the electrical motor runs when the switch is turned on and again when the switch is turned to the off position but the antennae does not move...
If I can lower it I have bought a universal amplified antennae I am going to hook up and just leave the power antennae unhooked.
Thanks
Bert
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptySat Feb 09, 2008 11:30 pm
There's a cable of sorts inside the mast that pulls it down. If you hear the motor running but the mast doesn't move, the cable has had it's teeth stripped. Mine is starting to fail also, esp in cold weather. I'm planning on repairing mine instead of anything aftermarket.
Has yours been stuck in the up position since you bought the car? You should be able to force it down, unless it's been stuck up for a long time. I can push mine down, though it does take some force to do so.
PostSubject: stuck up   How can I get the power antennae to lower ? EmptySun Feb 10, 2008 9:36 am
Yes it stuck in the up position, I will get rough with it and see if it will go down.
I would like to repair mine.
Bert happy
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptySun Feb 10, 2008 10:27 am
sometimes just cleaning it real good can help. i used some pb blaster to do the kob and it worked good.
PostSubject: cable wont let it go down   How can I get the power antennae to lower ? EmptySun Feb 10, 2008 3:32 pm
It will move about a 1/4" and then stops, it sounds/feels like the cable that is supposed to retract/extend it is binding on something and will not let it be lowered.
I hosed it down with PB BLaster though, just in case.
Thanks
Bert
PostSubject: repair kit?   How can I get the power antennae to lower ? EmptyMon Feb 11, 2008 6:53 pm
I saw a repair kit today at the parts store.
It has the mast with a plastic cable attached that has teeth like on a gear.
That might work, anybody tried the repair kit.
Bert
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptyMon Feb 11, 2008 11:20 pm
Nope, but my plan is to buy the oem mast from my dealer. Does that repair kit give specific applications, or does it say "universal"? I'd be a little wary of a universal kit.
Merit : 155
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptyTue Feb 12, 2008 1:51 am
if the kit fits it should work great. the kit needs to have same mast as your antenna - same teeth on antenna plastic cable, same # of sections is preferable so it fits right in the shaft. Will be a little tricky install but OK once it engages. neutral
PostSubject: Repair kit wont work?   How can I get the power antennae to lower ? EmptyFri Feb 15, 2008 10:21 pm
The parts dude at the dealership said the repair kit would not work on the Riviera.
He also said the replacement was a universal kit...
I was not very impressed, might have just been me misreading these guys but I got the impression they could have cared less about helping me.
I am going to try again this weekend to lower the antennae to the closed position...
Bert
PostSubject: removed retainer nut...   How can I get the power antennae to lower ? EmptySat Feb 16, 2008 4:28 pm
Removed the rubber retainer nut on top of quarterpanel, pulled antennae out, cut off broken cable. Reinstalled. Problem solved.
Oh, and the universal repair kit would not work.
By the way, the GM parts dude claimed the only replacement power antennae they could get was a universal set up...
Bert
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptySat Feb 16, 2008 9:42 pm
There is a listing in my parts pages for an antenna, and parts thereof. Maybe it is discontinued. I'll have to try to look it up later tonight and see if gmpartsdirect has it. You could always grab one from a salvage yard.
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptySun Feb 17, 2008 2:01 am
http://rivperformance.editboard.com/audio-electronics-f7/i-am-guessing-this-is-not-the-stock-antenna-t509.htm
I can reconfirm this once I've found the numbers I'd written down. From what I recall the antenna mast is a separate unit that's about $15.
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptySun Feb 17, 2008 9:14 am
When I plug the wiring connectors up, the motor runs-when you turn the radio off/on.
If I could figure out how to change the mast that would be great.
Bert
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptySun Feb 17, 2008 12:45 pm
Bert
The factory manual says you should be able to unscrew the very top of the mast and then be able to pull it out. It's likely something wrong with something in the assembly rather than a mast issue.
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptySun Feb 17, 2008 1:15 pm
Bert
I unscrewed the nut and removed the mast, the wire.cable that retracts/extends the mast is broken.
The motor still runs.
Thanks for any tips or advice.
Bert
qprint
PostSubject: Re: How can I get the power antennae to lower ?   How can I get the power antennae to lower ? EmptyThu May 01, 2008 12:44 pm
Remove the motor and open it. You need to drill out the rivets holding it together. Then you can see the nylon cable wound up on the gear.
» Power Mods ????
» power chips or modules
» Power Plays
» Repairing power lead
» Duro Power-Grips ,25x8x12,25x10x12 $125.00
