 series I ECM/computer
zombiesarebad
zombiesarebad
series I ECM/computer Empty
PostSubject: series I ECM/computer   series I ECM/computer EmptyMon Feb 11, 2008 3:58 pm
hi. I've been told that the ECM is likely the problem I'm having with my Riv so I'm going to replace it. I called the junkyard though and they said that I have to find one with a matching serial # on it (???). I thought you could use a computer out of any '95 GM car with a 3800? Anybody know?
scoopy03
PostSubject: Re: series I ECM/computer   series I ECM/computer EmptyWed Feb 13, 2008 12:04 am
not just any. it has to be out of the same if it is supercharged has to be out of a supercharged one of 1994-1995.
Merit : 153
PostSubject: Re: series I ECM/computer   series I ECM/computer EmptyWed Feb 13, 2008 1:34 am
You were told it was the ECM. Were you just told or were you given an explanation as to why? Please comment, thanks.
BillBoost37
Merit : 25
PostSubject: Re: series I ECM/computer   series I ECM/computer EmptyWed Feb 13, 2008 7:28 am
94/95 GM ECU's were among the worst years for any computer ever.
You do not need to ensure the same type of car (supercharged) if you change the Eprom by removing the access cover. The Eprom has not been found to be bad and will ensure you have the correct programming and transmission information.
» Lucas Oil Off Road Racing Series Short Course---USTREAM TV Live
» Melton 400m Series - 22nd & 29th July
» hmf swamp series exhaust
