 meziere electric water pump
meziere electric water pump Empty
PostSubject: meziere electric water pump   meziere electric water pump EmptyWed Feb 13, 2008 7:24 am
question; does anybody know if a meziere electric water pump for the 97-gps, or the 90 and up bonnies ,will work on a series 1 s/c rivi? it looks like a trick instal!
BillBoost37
Merit : 25
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyWed Feb 13, 2008 7:29 am
As I remember the WP is different from S1 to S2 and will not interchange. You may want to check the two gaskets side by side at the parts store to ensure that is correct though.
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyWed Feb 13, 2008 11:01 am
wow! thats a great idea BB37! now why dint i think of it?? scratch thanks.....
BillBoost37
Merit : 25
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyFri Feb 15, 2008 7:12 am
I spend too much time at the parts store.
For example I happen to know that Parts America aka Checker/Advance prices clearnance items with a price that ends with "5"
And said items are 75% off the listed price for employees since they are clearance.
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyFri Feb 15, 2008 10:47 am
wow! you are the man!
Merit : 122
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyWed Sep 17, 2008 9:41 am
did anyone ever check this one out?
edit:
hrm, rockauto lists both gaskets as: FEL-PRO Part # 35351
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyTue Jul 07, 2009 4:01 am
spoke to a guy at meziere, and hes almost certain that theire wp140hd will fit a 95 s/c rivi. i looked at the gaskets and they apear to be the same. only question is. is there enough space to run a shorter belt? it routes awfully close to the engine mount....
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyTue Jul 07, 2009 4:03 am
and i did a physical check at the vato zone and youre right karma they are the same! only difference is the water pump is different for the 2 years...
Merit : 122
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyTue Jul 07, 2009 1:44 pm
good info! One day I will give this a try. If it doesn't work, the WP can always go on the wife's 98.
BillBoost37
Merit : 25
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyTue Jul 07, 2009 2:55 pm
Shave a chunk off the mount. That'll give the belt a place to go. Check your routing. On the S2 the belt would usually come up from the water pump to the tensioner and then power steering.
You get a 4" longer than stock and leave the water pump out of the loop. So the belt goves from power steering to tensioner to crank.
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptyTue Jul 07, 2009 4:42 pm
I have a Meziere electric wp and it fit with no problems however I have the SII and OD ballancer, OD pulleys, and one very, very small SC pulley. Because of those, it might have given the belt just enough room from clearance from everything.
PostSubject: Re: meziere electric water pump   meziere electric water pump EmptySun Jul 12, 2009 11:11 pm
have you guys heard of the davies-craig water pump? totally awsome. it is a flow controled pump.
» ThunderCat Water Pump Recall
» Another water pump seal gone bad
» Highbanker + water pump legal?
» RZR Water Pump Seal Leaking
» Water pump seal
