| Write-Up: Center Console Removal | |
+20BMD flyineagle96 albertj charlieRobinson stan 1998 Riv 98buickriv turtleman agrimm34 Rickw krazyfish palermocorey90 Chicken '96reese 97rivman 97Riv-Jon Jack the R 99Rivman AA BIGAL1128 24 posters |
99Rivman Aficionado
| Subject: Write-Up: Center Console Removal Tue Feb 26, 2008 9:02 am | |
'96reese Fanatic
| Subject: Re: Write-Up: Center Console Removal Sat Sep 06, 2008 3:12 pm | |
| how do you remove the shifter knob???????? | |
99Rivman Aficionado
| Subject: Re: Write-Up: Center Console Removal Sat Sep 06, 2008 6:32 pm | |
| There is a clip installed in the front side of the shifter knob about an inch from the bottom, you pry it out with a small screwdriver and the knob slides off | |
Chicken Aficionado
Name : Mark Age : 57 Location : Montana Joined : 2008-06-13 Post Count : 1296 Merit : 8
| Subject: Re: Write-Up: Center Console Removal Sat Sep 06, 2008 6:47 pm | |
| I've been waiting for this!!! Thanks!!! | |
palermocorey90 Expert
| Subject: Re: Write-Up: Center Console Removal Sat Sep 06, 2008 7:00 pm | |
krazyfish Enthusiast
Name : Jerred Age : 34 Location : Kentucky Joined : 2009-02-20 Post Count : 136 Merit : 4
| Subject: Re: Write-Up: Center Console Removal Thu Jul 02, 2009 12:52 pm | |
| Okay im seriously having some issues getting this sucker out. ive got the cd/ashtray panel out. and ive got the 2 nuts in the storage compartment out. i cannot figure out what else is holding this one. After all ive done the most i can do is make it wiggle a little bit. What am i missing here? How is the front section held on?
im really needing to get this thing taken apart to clean it and see if i can fix the cup holder lid. | |
| Subject: Re: Write-Up: Center Console Removal Thu Jul 02, 2009 2:24 pm | |
| Have you read from the beginning of this thread. What about the 4 screws mentioned earlier.??? | |
| Subject: Re: Write-Up: Center Console Removal Thu Jul 02, 2009 2:55 pm | |
| i have read and re read this thread. and i did not remove 4 screws from the front i have search and search and i do not see any. where exactly are they located. The only screws i see behind this panel are the two that are holding in the ash tray.
I have put it back together from the point i was at because i am taking the car to get window tint tomorrow morning and dont want to have my interior in shambles when i take it, but i am still trying to figure out how to remove it so i can do it tomorrow afternoon. give me 15 minutes and i can have pictures of where i am stuck at. | |
| Subject: Re: Write-Up: Center Console Removal Thu Jul 02, 2009 3:03 pm | |
| I've never tried to remove mine. Maybe someone who has will chime in and help out. Or try emailing or PM Randall (99Rivman) he has removed several and is the original one who posted here I think. | |
99Rivman Aficionado
| Subject: Re: Write-Up: Center Console Removal Fri Jul 03, 2009 7:44 am | |
| - krazyfish wrote:
- Okay im seriously having some issues getting this sucker out. ive got the cd/ashtray panel out. and ive got the 2 nuts in the storage compartment out. i cannot figure out what else is holding this one. After all ive done the most i can do is make it wiggle a little bit. What am i missing here? How is the front section held on?
im really needing to get this thing taken apart to clean it and see if i can fix the cup holder lid. When I posted the pictures it was more about taking it apart than removal, I'll see if I can look today and get more info posted later ... | |
99Rivman Aficionado
| Subject: Re: Write-Up: Center Console Removal Fri Jul 03, 2009 9:51 am | |
| I guess I should have started this from the beginning? I have figured out a little different way to do this so I figured I would start it from the first thing that needs to be removed. Aaron if you want to adjust/move these posts, feel free. With these additional items there should be NO questions about removing and disassembling the console of our Rivieras … well I hope anyway? I will start by editing this post and go from here … The Service Manual reads as follows: This would be the first step:
| Subject: Re: Write-Up: Center Console Removal Fri Jul 03, 2009 6:07 pm | |
| Awesome this helps alot. looking at the diagram it states to remove the shifter trim plate. how do i remove this.
The best i can tell is that the 4 screws on the trim under the armrest are attached to the same panel so those have to come out. but what about the rest of the shifter trim plate? is it just clipped in or are there more hidden screws?
With it in the way there are 2 screws i cannot remove.
Thanks abunch for the info you have already given! | |
99Rivman Aficionado
99Rivman Aficionado
| Subject: Re: Write-Up: Center Console Removal Fri Jul 03, 2009 8:23 pm | |
99Rivman Aficionado
| Subject: Re: Write-Up: Center Console Removal Fri Jul 03, 2009 8:24 pm | |
| Then back to the original post: Console (Buick)Figure 44 Remove or Disconnect1. Shifter trim plate, refer to procedure in this section. 2. Nuts (3), bolts (2). 3. Electrical connectors from console. 4. Console (5). Install or Connect1. Console (5) to vehicle. 2. Electrical connectors to console. 3. Nuts (3), bolts (2). 4. Shifter trim plate. Pictured below: There are 4 bolts (2) in red, 2 going into the front of the console, and 2 going into the bottom, near the shifter. There are 2 nuts (3) in green, under the access cover near the rear of the console. Hope this helps. | |
| Subject: Re: Write-Up: Center Console Removal Fri Jul 03, 2009 11:56 pm | |
| thanks alot! i believe i shouldnt have any trouble doing this tomorrow. i really appreciate the help. | |
agrimm34 Amateur
Name : Andy Grimm Age : 31 Location : West Virginia Joined : 2009-09-29 Post Count : 30 Merit : 0
| Subject: wood trim (gear shifter) Sat Oct 10, 2009 9:30 pm | |
| Anyone know how to remove the piece of wood trim that surrounds the gear shifter? and also how to remove the whole center console piece? | |
| Subject: Re: Write-Up: Center Console Removal Sat Oct 10, 2009 11:18 pm | |
| The wood trim itsself is glued to a metal plate which is secured to the top of the center consol with pushnuts. You have to remove the top piece of the center consol which is pretty easy, then remove the pushnuts un the bottom. | |
| Subject: Re: Write-Up: Center Console Removal Tue Oct 20, 2009 3:09 am | |
98buickriv Special
Name : AJ Gee Age : 30 Location : Lovington, IL Joined : 2011-07-10 Post Count : 2 Merit : 0
| Subject: Re: Write-Up: Center Console Removal Mon Jul 11, 2011 12:04 am | |
| ok i seriously cannot find the clip to take the shifter knob off can anyone help me or put some pics on of where it is real pics instead of a diagram | |
| Subject: Re: Write-Up: Center Console Removal Mon Jul 11, 2011 12:17 am | |
| As I recall, it's on the front side of lower handle grip, the side that faces your dash. May need a needle nose pliers to pull it? Pull your shifter all the way back and you should be able to get a good look at it. | |
99Rivman Aficionado
| Subject: Re: Write-Up: Center Console Removal Sun Jul 17, 2011 8:30 pm | |
| - 98buickriv wrote:
- ok i seriously cannot find the clip to take the shifter knob off can anyone help me or put some pics on of where it is real pics instead of a diagram
Slight delay but ... as requested: I use a pocket screw driver to get the clip loose from the shifter knob, something very small because it is usually into the leather wrap pretty tight, then I use some plyers to finish the removal. Hope this helps | |
| Subject: Re: Write-Up: Center Console Removal Sun Jul 17, 2011 8:45 pm | |
| ohh thanx for the pics Randall,i myself knew where the goddamn clip is but never looked to see for myself now i know the exact location.Thanks. | |
charlieRobinson Expert
| Subject: Re: Write-Up: Center Console Removal Fri Sep 16, 2011 7:36 pm | |
| I am trying to take the console out but I am having some screw problems. They keep turning but not rising. they just spin in place. Anyone have this problem? How do you get a screw out that won't rise!? | |
| Subject: Re: Write-Up: Center Console Removal Fri Sep 16, 2011 9:20 pm | |
| - charlieRobinson wrote:
- I am trying to take the console out but I am having some screw problems. They keep turning but not rising. they just spin in place. Anyone have this problem? How do you get a screw out that won't rise!?
Try putting a magnet on the screwdriver. Try using pliers (needlenose maybe dep on screw) to grab it by the head and ease it out. Try a little wad of sticky-tak or strip-calk to stick to the screw head and pull it out. Try pulling back on the screw while turning if it's just the case that the speednut the screw is in has stripped from its mounting. | |
| Subject: Re: Write-Up: Center Console Removal | |
