 FAQ: Transmission Shift Modulator
96_Juggernaut
Name : Todd Balestrini
PostSubject: Re: FAQ: Transmission Shift Modulator   Mon Mar 10, 2014 6:42 pm
So I replaced all the vacuum line going from the modulator to the TB and SC. I have it 2-3 turns from closed and it still feels the same  confused
PostSubject: Re: FAQ: Transmission Shift Modulator   Mon Mar 10, 2014 6:44 pm
Turn it all the way in and then back it out incrementally until it no longer shifts harshly
96_Juggernaut
PostSubject: Re: FAQ: Transmission Shift Modulator   Mon Mar 10, 2014 6:50 pm
Thanks for the tip, however I wanted a more solid shift and it still shifts on the soft side.
PostSubject: Re: FAQ: Transmission Shift Modulator   Mon Mar 10, 2014 7:00 pm
dat sux. Get yerself one of these http://www.summitracing.com/parts/awr-tcet4618/overview/
just jam it in dere,piece o cake to make it work.
96_Juggernaut
PostSubject: Re: FAQ: Transmission Shift Modulator   Mon Mar 10, 2014 7:17 pm
Ordered smile
Animator
PostSubject: Re: FAQ: Transmission Shift Modulator   Mon Mar 10, 2014 9:29 pm
TonySmooth89 wrote:
ouch! return it and go to autozone
part # mv303
nervous
Yeah definitely get the new one from autozone.
I am so glad I stumbled on this thread. This forum is pure gold.
PostSubject: Re: FAQ: Transmission Shift Modulator   Mon Mar 10, 2014 9:38 pm
$2400.
Merit : 107
PostSubject: Re: FAQ: Transmission Shift Modulator   Tue Mar 11, 2014 3:49 pm
Todd,
Exactly what kind of modulator are you using? The small brass ones are made to be adjustable. The larger ones are not readily adjustable. They have sealant around the threaded stud at the end. Anytime you adjust that kind, you must reseal the threads or it will leak vacuum. In any case, the modulator only adjusts minimum and part throttle shift points (2-5 MPH), and to a minor degree, shift feel. Turning the screw in makes for later, firmer shifts, and turning the screw out makes for earlier softer shifts. Be careful with the adjustment when turning it out. It is possible to lower the transmission line pressure to the point where clutches slip and wear. If you want harder shifts, a shift kit is the answer. The modulator adjustment is limited.
96_Juggernaut
PostSubject: Re: FAQ: Transmission Shift Modulator   Wed Mar 12, 2014 10:37 am
I have the pioneer brand that everyone was recommending. After playing around with it alittle more I noticed the shifts do in fact feel slightly more crisp. It just took alot more turns then I was expecting to achieve it. Thanks for the help.
