| "Flop-flop" sound when turning | |
adri Amateur
Name : adri(95S1SC) Location : Athens, OH Joined : 2011-10-26 Post Count : 37 Merit : 1
| Subject: "Flop-flop" sound when turning Mon Oct 31, 2011 6:38 pm | |
| i have a question. i ran my car for a lil distance when my bolt tor my pulley broke and i took off my belts, just to get back to my house, it wasnt far. the power steering was gone and the water pump as you know, but now everytime i take a right turn i hear this flop flop sound at the left from wheel, why do i hear that? does it have something to do with when i drove it without power steering?im at a loss. | |
| Subject: Re: "Flop-flop" sound when turning Mon Oct 31, 2011 6:43 pm | |
| Does it happen at all speeds? Slow speeds? Try slowing down really slow and listen for the sound out the window. Drive next to a wall to help you listen. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
adri Amateur
| Subject: Re: "Flop-flop" sound when turning Mon Nov 21, 2011 3:46 pm | |
| the sound only happens a slow speeds and when i turn the wheel to the right. i can hear it pretty clearly even without driving next to a wall. | |
| Subject: Re: "Flop-flop" sound when turning Mon Nov 21, 2011 4:01 pm | |
| Maybe something is rubbing on the tire. Turn the wheel all the way to the right and use a flashlight to inspect the wheel well. Use your hand to feel around the inside edge of the tire. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: "Flop-flop" sound when turning Mon Nov 21, 2011 8:31 pm | |
- Maybe something is rubbing on the tire. Turn the wheel all the way to the right and use a flashlight to inspect the wheel well. Use your hand to feel around the inside edge of the tire.
Actually, if you look at the inner fender carefully you should find where it is rubbing. Probably lost one of the "christmas trees" that holds the inner fender in place, or you recently installed tires that rub for some reason (my winter tires rub a little) Albertj | |
| Subject: Re: "Flop-flop" sound when turning Thu Dec 01, 2011 10:10 am | |
| I wonder if this could be a failing CV joint. Is there any noise at all when rolling straight? Do the CV boots have any cracks or leaking grease?
I have a similar sound coming from the left side of my car, comes and goes. Sort of a grinding/chuffing sound. Also a slight howling noise from 70-80 mph. I'm leaning toward one of the CV joints at this point, but at first I thought it was something rubbing the wheel. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
adri Amateur
| Subject: Re: "Flop-flop" sound when turning Fri Dec 02, 2011 3:32 pm | |
| Ihavent been here for a while guys, sorry. But in response to you AA, my father in law mentioned to me that it could be a CV joint, but im still not sure. its been so cold outside lately that any thought of car work becomes a daunting thing. but i will take a look at it and let you know exactly what it is. | |
| Subject: Re: "Flop-flop" sound when turning | |
