 code p1361
paulie710
PostSubject: code p1361   Sun Mar 02, 2008 10:12 pm
code 1361. in the morning when i sometimes start my car up the check engine light comes on as well as the traction light and the button is inoperatable at the time.........if i shut it off and then resart it it sometimes goes out.............when i pull the codes i get 1361.any ideas on this?????????
PostSubject: Re: code p1361   Sun Mar 02, 2008 10:33 pm
Its a most likely a bad coil pack , wire or plug...When was the last time you replaced your plugs/wires?
paulie710
PostSubject: Re: code p1361   Mon Mar 03, 2008 4:04 pm
they were all changed last week
PostSubject: Re: code p1361   Mon Mar 03, 2008 4:19 pm
then i would test your coil packs. That is most likely the cause of the issue.
BillBoost37
Merit : 25
PostSubject: Re: code p1361   Tue Mar 04, 2008 7:53 am
What is a 1361?
PostSubject: Re: code p1361   Tue Mar 04, 2008 10:33 am
i assumed it was a typo for 0361...which is a bad coil pack... hmmm....
PostSubject: Re: code p1361   Tue Mar 04, 2008 11:31 am
P1361
Ignition Control (IC) Circuit Low Voltage (GM)
P0361
Ignition Coil K Primary/Secondary Circuit Malfunction
try cleaning the ICU. is the metal plate under the coil packs corroded?
BillBoost37
Merit : 25
PostSubject: Re: code p1361   Wed Mar 05, 2008 7:15 am
Thanks...Mr. Riv...
BTW there is no coilpack bad code to my knowledge. A bad coil pack will cause misfire and ignition problems on one or two cylinders. Each coil pack fires two cylinders, although only one tower can go bad on a pack.
This looks more like what it says, the pcm is seeing a low voltage issue that could be caused by corrosion under the packs/ICM and or maybe a bad wire to the ICM/Crank/Cam.
I'm not sure when, but at one point GM had the ground going through the plate/bracket only and later they added an additional ground into the ICM connector to improve the design.
paulie710
PostSubject: need diagnois help on code p1361   Sat Mar 29, 2008 10:53 am
on my 95 riv 3.8 s/c vin 1 i keep getting code p1361 usaully in the morning when rtemp is cold..........................any help or diagnois charts ??
PostSubject: Re: code p1361   Sat Mar 29, 2008 11:40 am
From 1998 GM shop manual:
DTC P1361 IC CIRCUIT NOT TOGGLING
Circuit Description: The Ignition Control Module (ICM) sends signals that the PCM requires for fuel control and spark advance calculations. At the start of engine crank, the ICM controls spark advance (Bypass mode). When the second 3X reference pulse is recognized by the PCM, the PCM applies 5 volts to the Bypass circuit. The 5 volts on the Bypass circuit commands the ICM to switch spark advance to PCM control (IC mode). At this time, the ICM will remove the ground it has applied to the IC circuit. When the IC pulses are not grounded, the ICM can use the IC pulses to control spark advance. A short in the IC circuit or an open or short to ground in the Bypass circuit will cause the PCM to monitor no IC pulses after the PCM has switched the Bypass circuit ON. The PCM will set DTC 1361 under either of these conditions. THe engine may be started but will run on Bypass mode timing.
Conditions for Setting the DTC: The PCM does not monitor IC pulses while IC mode spark advance is commanded.
Action Taken When the DTC Sets:
• The PCM will illuminate the MIL during the second consecutive trip in which the diagnostic test had been run and failed.
• The PCM will store conditions which were present when the DTC set as Freeze Frame and Fail Records data.
Conditions for Clearing the MIL/DTC:
• The PCM will turn the MIL OFF during the third consecutive trip in which the diagnostic has been run and passed.
• The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
• The DTC can be cleared by using the scan tool Clear Info function or by disconnecting the PCM battery feed.
Diagnostic Aids:
Check the following conditions:
• Poor connection at the PCM.
Inspect harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and poor terminal to wire connection.
• Damaged harness.
Inspect the wiring harness for damage. If the harness appears to be OK, disconnect the ICM, turn the ignition to ON and observe a digital connected between the IC circuit and B+ while moving connectors and wiring harnesses related to the ICM. A change ini voltage will indicate the location of the malfunction.
Reviewing the Fail Records vehicle mileage sinse the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
johnd89
PostSubject: Re: code p1361   Mon Mar 31, 2008 11:40 am
I have the same code ('95 riv s/c)
I swaped the ignition module, but I still get the code. The coil packs tested ok, but this error code is not related.
I'll bypass the two wires going from pcm to the IC. If it's not that, it's the PCM.
Problem with the PCM is that you cannot buy one, test it and bring back if the light doesen't go away... it's non refundable.
I've heard that the best bet is to get an original PCM from a low miles car, supposedly the remanufactured ones are crap...
Please post back w/results.
UPDATE: It was the PCM in my case.
paulie710
PostSubject: Re: code p1361   Thu Apr 03, 2008 1:59 pm
hey guys just some info on what i found .............my friend got my a diagnois chart off alldata.i followed it step by step and it led to a faulty ignition moulde..............changed it lasted week.................PROBELM SOLVED................
jenkkijussi
PostSubject: Re: code p1361   Sat Nov 01, 2008 2:02 pm
I had same problem P1361. It was faulty PCM. New PCM and everything is OK.
code p1361
