| magnasteer adjustment not possible | |
+9Eldo GMFreak8 Rickw 99Rivman albertj ibmoses 1998 Riv Mr.Riviera Jason 13 posters |
| Subject: Re: magnasteer adjustment not possible Sat Feb 04, 2012 5:23 pm | |
| Absolutely.Instead of pucks you can use a 3 x 1" alu puck that you will drill a 3/4 " hole in and place on the body side(on top the cradle) For the bottom of the cradle where the isolator would go,you would weld a steel round plate in its place with a 3/4 " hole for the through bolt.You can do this to all the 6 isolators if you want.sharpens steering up quite a bit.the rubber or poly motor mounts do a good enough job dampening vibrations so as to do away with what I see as essentially as an engine cradle moving around concentrically on itself ..f.....g ugh! | |
Karma Aficionado
| Subject: Re: magnasteer adjustment not possible Sat Feb 04, 2012 5:32 pm | |
| Wouldn't steel be better since I believe that you will get galvanic corrosion having aluminum against the steel cradle? _________________ | |
| Subject: Re: magnasteer adjustment not possible Sat Feb 04, 2012 5:43 pm | |
| Living in Canada,yes.If you have some DOM 3" tubing laying around you can cut it to roughly the same diam as the OEM bushings and weld plate onto both sides making it a steel puck.drill the hole for the through bolt and voila! done.for the underneath of the cradle,where the through bolt would go through,you would just weld a same dia steel plate,closing the hole where the stock isolator goes, with a hole for the bolt.The reason why you cant just remove the isolators and push the cradle flush up against the underside of the body is because of clearance issues.the cradle bumps up against the body. you really have to go underneath,if you havent allready,and take a look.to get an idea of the mod.really easy,only takes a couple hours.I will replace the pucks with steel real soon.looking forward to that. | |
Karma Aficionado
| Subject: Re: magnasteer adjustment not possible Sat Feb 04, 2012 6:35 pm | |
| Cool. Thanks for the info Robo. I'll be working with this when I have the cradle dropped. _________________ | |
| Subject: Re: magnasteer adjustment not possible Mon Feb 06, 2012 1:37 pm | |
| - robotennis61 wrote:
- Alot of the vagueness that comes with the Riv steering is atributed to the engine support frame isolator bushings.If you've replaced your rear motor mount you'll know what I'm talking about.
You can experiment if you want.All you have to do is,Remove the two front engine cradle donut isolators,passenger side and driver side.no need to fabricate anything.Take 4 pucks,drill a 3/4" hole in the middle,place 1 puck on the top of the engine cradle and the other on the bottom, sandwiching the engine cradle in the middle,run your stock bolt through the 2 and tighten.do the same for the other side.now do the same for the rear inner isolators,leaving the rearmost isolators alone.take for a test drive.big difference.
Im going to try this as soon as i get 8 hockey pucks. If i recall correctly i have to drop the subframe pretty far down to be able to pull out the bolt and slide something in right? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: magnasteer adjustment not possible Mon Feb 06, 2012 1:47 pm | |
| I am going to create a tutorial this afternoon detailing how its done.I found a few extra steel cups that I am going to use instead of the pucks. I just need to check engine clearances before I post,tomake sure everything lines up and that there are no clearance issues. with this new mod,all you will need is 4 pucks. | |
| Subject: Re: magnasteer adjustment not possible Tue Feb 07, 2012 9:31 pm | |
| None of the local sporting goods stores have hockey pucks lol. Seriously that all the the hollow ones and street pucks but not the real ones. guess ill have to order some. any luck with the write-up? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
rk0ehn Enthusiast
Name : Christian Rolf Köhn Age : 34 Location : CD Juarez, MX Joined : 2011-08-11 Post Count : 148 Merit : 14
| Subject: Re: magnasteer adjustment not possible Tue Feb 07, 2012 11:25 pm | |
| Woah, this sounds interesting nice info you got there Robo, looking forward for more updates on this because the streets here in Juarez are in a totally bad shape that sometimes you just wish to have a truck , they say that if you already know how to drive in Juarez you can drive anywhere in the world Any improvement in drivability here will be great, and this seems to be not 'that' complicated | |
| Subject: Re: magnasteer adjustment not possible | |
