 Spark Advance (Timing, Retard)
Goto page : 1, 2, 3  Next
Merit: 9
PostSubject: Spark Advance (Timing, Retard)   Thu Mar 13, 2008 12:20 am
I put this on the Powertuner board but got no help.
There is a table modifier timing program available which I have used. But being familiar with it doesnt matter in relation to this question.
I put in a scan that really only included idling/cruising and the program only changes the timing of those setting. But it simply raises every cell used in the scan 2 degrees (by default).
When I do this, the cells in the higher mg/cyl settings, the timing numbers are lower. But the timing modifer still raises those cells timing by 2* and the powertuner highlights the cells since the changes exceed 10%. IS THIS OKAY?
I understand the damage of raising the MAF numbers more than a few %, but still unsure about timing.
Another thing, I have no EGR so my engine temps tend to stay cooler than normal. How does this effect settings??
BillBoost37
Merit: 23
PostSubject: Re: Spark Advance (Timing, Retard)   Thu Mar 13, 2008 5:38 am
I'm far from an expert as I haven't jumped in and done what I'll call the necessary reading yet. As we all know, being able to tune a car shows a relationship between effort put into learning and working with the car.
Depending if you are getting knock at the higher cylinder airmass would be the biggest determination for me if you should allow 2* to be added up there. Personally...I'd make small changes in only certain areas and come back for the top fo the rpm range.
Merit: 9
PostSubject: Re: Spark Advance (Timing, Retard)   Thu Mar 13, 2008 6:18 am
well I haven't touched anything in the upper RPM range. Like I did with my fuel trims... first got idle/cruise then partial throttle then WOT tunings.
But as the cylinder mass increases in the lower RPM range (and all RPM ranges actually), the timing numbers drop considerably. 2* timing added on top aint nothing, but what about 2* added to single digit stock timing numbers?I just dont wanna drop into OD, have the RPMS fall/cylinder mass increase, and then the extra timing hurt something. Guess if anything, I would see knock and know to remove 1or 2* of timing huh?
Merit: 172
PostSubject: Re: Spark Advance (Timing, Retard)   Thu Mar 13, 2008 8:13 am
I don't understand. Please explain.
- John R. White, Boston Globe
Merit: 83
PostSubject: Re: Spark Advance (Timing, Retard)   Thu Mar 13, 2008 8:45 am
Before you start tuning your timing table, give this a try - they recommend downloading the .bin from an '05 GTP and taking it's GFS table, as it's a bit more agressive overall and a better starting place for your tune.
-Derek
Merit: 9
PostSubject: Re: Spark Advance (Timing, Retard)   Thu Mar 13, 2008 11:56 pm
MAF increases are done in percentages. Usually 1 or 2% at a time. Timing increases can only be done in 1/2* timing increaments (despite what the chart says....16.453 = 16.5* timing)
-Derek
Im kinda leery on this because everyone says "you shouldnt use another vehicles .bin because those settings aren't made for your car". I also know the 04+ vehicles were quite different from the 97-03's and mine is a 96'. Guess I could get that pin on the powertuner board huh? Do you know anyone who has done this with a riv?
anyone know what their crusing timing is? mine wont exceed 31* or so.
Merit: 172
PostSubject: Re: Spark Advance (Timing, Retard)   Fri Mar 14, 2008 1:55 am
Okay, 1-2% at a time.I thought you meant it was dangerous to raise the MAF values more than a few % period. As long as you watch your a/f, O2, and LTFT, you can increase them 10% over stock... in 1-2% increments, of course.
You don't have to use the actual GTP bin, just export it's timing table and then import it into your timing table. You keep your bin, but use the GTP's values. I'm betting this is safer than trying to adjust them yourself. It would at least be interesting to compare the two tables to see the differences. There are lots of variables that make a '96 Riv different from an '04 GTP, but timing may not be one of them. You have to check before you can assume the tables are very different.
Merit: 83
PostSubject: Re: Spark Advance (Timing, Retard)   Fri Mar 14, 2008 9:04 am
Aaron is correct. You can't use another cars complete bin, but you can use a particular table from that bin. If you compare the two timing tables in an excel graph, for instance, you'll find the '05 GTP GFS spark table is a smoother table, and a little more agressive than your Riv's GFS spark table. Just import the one table before you start tuning.
You should tune for fuel before timing, IMHO.
Merit: 172
PostSubject: Re: Spark Advance (Timing, Retard)   Fri Mar 14, 2008 9:32 am
Agree. I've not played with timing at all. Still trying to get rid of that last bit of KR. Advancing the timing is the last thing on my list right now.
Merit: 9
PostSubject: Re: Spark Advance (Timing, Retard)   Sat Mar 15, 2008 2:21 pm
i am KR free except blip KR during shifts. I have worked on tuning fuel for what seems forever now.
Merit: 83
PostSubject: Re: Spark Advance (Timing, Retard)   Sat Mar 15, 2008 4:58 pm
Okay, then you are ready to start playing with timing. Start with the '05 GTP GFS table though... and go from there.
I'm really not comfortable with the way the timing table is set up. The last advanced system I worked on, the timing table was two-dimensional, MAP vs RPM, it made a lot of sense and was easy to follow. This one I'm not so sure about.
The tuning thingy program seems to do a good job overall, but I still don't really know what it's changing.
Merit: 9
PostSubject: Re: Spark Advance (Timing, Retard)   Sun Mar 16, 2008 7:28 pm
I am currently running the 05 GTP timing tables. Be careful beacause your max timing at WOT will go from 15* to 21* . I had to make some adjustments. I am currently running 19* with KR only at shifts with my 3.4 pulley.
Merit: 83
PostSubject: Re: Spark Advance (Timing, Retard)   Sun Mar 16, 2008 8:53 pm
hmm, mine didn't go that high. I only hit 14-15 at WOT.
Merit: 9
PostSubject: Re: Spark Advance (Timing, Retard)   Sun Mar 16, 2008 9:14 pm
Hmm! I have to admitt adding those tables really did bring a smile to my face.
I noticed the engine sound a little diffrent.
Idle spark advanced went up +10*
noticed a little more pep leaving the light.
Took me a while to fine tune to a point where I was comfortable about it but I think it is worth it.
Merit: 9
PostSubject: Re: Spark Advance (Timing, Retard)   Mon Mar 17, 2008 12:20 am
can you send me that 05 GTP file for the timing table?
Page 1 of 3Goto page : 1, 2, 3  Next
» Timing for combat?
» Query regarding Festival Advance
» CS501 Quiz (Advance Computer Architecture) Quiz#1
» Spark Advance (Timing, Retard)
» Timing retard
