| autotap | |
whit2285 Enthusiast
Name : Mike Age : 49 Location : Illinois Joined : 2007-12-20 Post Count : 127 Merit : 3
| Subject: autotap Fri Mar 21, 2008 1:17 pm | |
| anybody here use autotap 3.1 for vista? I have it but i cant get it to work properly. having a loss of communication error after it downloads dtcs and parameters. Tech support wasn't that much of a help any thoughts ? | |
| Subject: Re: autotap Fri Mar 21, 2008 1:42 pm | |
| There is a tech at AutoTap named John. He's pretty helpful. Call on Monday and ask for him (hope he's still there). I'm running version 2 on XP, works fine for me.
Are you able to detect the vehicle at all? Or is it just the DTCs you're haveing trouble with? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
whit2285 Enthusiast
| Subject: Re: autotap Fri Mar 21, 2008 1:48 pm | |
| in my explorer it works fine start to finish, on the riv just dtcs then parameters ( gathers vin # also)then loses conection i was talking with a joe seemed nice but not to helpful | |
| Subject: Re: autotap Fri Mar 21, 2008 1:57 pm | |
| Oh.. maybe his name was Joe. It's been awhile. I think that's the right guy.
Try manually entering the VIN# and/or software serial# for the Riv. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
whit2285 Enthusiast
| Subject: Re: autotap Fri Mar 21, 2008 1:59 pm | |
| thats the one thing i haven't tried yet good idea. K.I.S.S right ( Keep it simple stupid) | |
| Subject: Re: autotap Fri Mar 21, 2008 2:22 pm | |
| I had a lot of issues with mine, too. But once it works, it works well. I think you'll like it.
Did you get the GM extended parameters? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
whit2285 Enthusiast
| Subject: Re: autotap Fri Mar 21, 2008 3:31 pm | |
| ya i believe so , its the kit on there website for 399.00, it picks up around 150 diff. parameters | |
| Subject: Re: autotap Fri Mar 21, 2008 3:35 pm | |
| You got it! Let us know if you get it working or not. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
whit2285 Enthusiast
| Subject: Re: autotap Fri Mar 21, 2008 3:47 pm | |
| hey just went out hooked everthing up deleted almost all params except for about 10 and now its working! what param shoul i load 1st. also have you ever check the odom reading through autotap? its reading about 350 miles less then the car odom. | |
| Subject: Re: autotap Fri Mar 21, 2008 5:18 pm | |
| For general scans:
1) IAT 2) Throttle % 3) RPM 4) Timing ADV 5) A/F Ratio 6) LTFT 7) 02(sensor 1) 8) MAFF 9) MAP 10) KR
Also, if you can log: MPH, BAR Pressure, Coolant Temp, Gear... it's nice to have, but not required.
For tuning, you might want to only use a few so the data gets logged more densely. If you try to log 12 items at once, it logs each one more slowly. If you log only a couple, you get a finer resolution for those two. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
whit2285 Enthusiast
| Subject: Re: autotap Sat Mar 22, 2008 2:46 am | |
| as far as the kr goes its kr not sensor counter or active channel right, does anyone know normal trans temp | |
| Subject: Re: autotap Sun Mar 23, 2008 7:43 am | |
| Normally trans temp runs around or a little higher than your coolant temp. | |
| Subject: Re: autotap Sun Mar 23, 2008 12:56 pm | |
| right, it's just KR. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
whit2285 Enthusiast
| Subject: Re: autotap Sun Mar 23, 2008 2:30 pm | |
| thanks guys im going to get some good reads on the way to easter dinner later on. | |
whit2285 Enthusiast
| Subject: Re: autotap Tue Mar 25, 2008 12:16 am | |
| Ok im not sure how to transfer the data to here so ill just post one section
Rpm -4312 ig im adv - -10 iat- 46 F MAP- 45.5 MAF Rate- 22.387 lb/min 02 bank 1- 870 mV throt pos ang- 73.3 speed -99 air fuel Ratio 11.2:1 ltf1- 7.8 baro pres-29.5
any thoughts probably cant tell with such little info, i didnt see any kr till deceleration jumped to 2 then nothing once | |
| Subject: Re: autotap Tue Mar 25, 2008 8:51 am | |
| We need to see these parameters vs. time. A table or graph is needed to show this. I usually export into excel, but there are other ways. Tip: don't use hyphens to separate parameters from values. Looks like neg! - Quote :
- didnt see any kr till deceleration jumped to 2 then nothing once
Not sure what that means, but normally KR should be zero. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
whit2285 Enthusiast
| Subject: Re: autotap Fri Mar 13, 2009 5:21 pm | |
| [quote="AA"]We need to see these parameters vs. time. A table or graph is needed to show this. I usually export into excel, but there are other ways. I had troubles with v3.1 so im using 2.0 now, anyways, could someone explain how to export to excell or some other options . thanks im using a os with xp on it now also | |
whit2285 Enthusiast
| Subject: Re: autotap Sat Mar 14, 2009 3:15 am | |
| never mind just figured it out,..... now to post it so you guys can tell me how bad it is !!!! Any tips on that one would be great | |
| Subject: Re: autotap | |
| autotap | |
