| Should I replace my OEM thermostat? | |
+20deekster_caddy ghpcnm Eldo curious riv captshiner Chicken EASHER Karma Rickw rivboy 1wickedninja SuperRiv07 lyonsperformance 1998 Riv manofmany 96riv robertwolf86 Mr.Riviera NO 4 EVR AA 24 posters |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Thermostat Mon Sep 08, 2008 12:51 pm | |
| So I ran into A guy At Napa Who had a 96 sc riviera and he had a 160 thermostat, Could I do that or is that a bad idea, | |
lyonsperformance Enthusiast
Name : Michael Age : 40 Location : Buffalo N.Y. Joined : 2008-08-02 Post Count : 178 Merit : 0
| Subject: Re: Should I replace my OEM thermostat? Mon Sep 08, 2008 12:54 pm | |
| Ive heard that a 160 stat may cause your engine to run too cool. i think it is best for race applications only. | |
1wickedninja Addict
Name : Josh Age : 35 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| if i were u i would stay with the 180 i herd the 160 isn't that good on your car unless u have major mods and tuning. u put autolight 104 spark plugs in it yet? | |
| Subject: Re: Should I replace my OEM thermostat? Mon Sep 08, 2008 1:00 pm | |
| - 1wickedninja wrote:
- if i were u i would stay with the 180 i herd the 160 isn't that good on your car unless u have major mods and tuning. u put autolight 104 spark plugs in it yet?
me? | |
| Subject: Re: Should I replace my OEM thermostat? Mon Sep 08, 2008 1:43 pm | |
| Read page one of this thread about 160º t-stats. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Should I replace my OEM thermostat? Tue Sep 09, 2008 9:20 am | |
| Use a 180 for a street driven DD. | |
rivboy Amateur
Name : Marc Age : 32 Location : Leech Lake, Minnesota Joined : 2008-07-22 Post Count : 41 Merit : 0
| Subject: T-Stat Sun Oct 12, 2008 4:25 pm | |
| i live in northern minnesota. i wanna run a 160 or 180 thermostat but dad says i will have no heat during the cold 9 months up here... i think i'll still get plenty heat...any input..thanks | |
| Subject: Re: Should I replace my OEM thermostat? Sun Oct 12, 2008 5:43 pm | |
| The lowest you would want to go is 180* and that's only if your PCM has been reprogrammed for that temp. | |
| Subject: Re: Should I replace my OEM thermostat? Sun Oct 12, 2008 5:48 pm | |
| A 180 is just fine up here in winter, I'm in ND. Had no heating issues last winter with a 180. DO NOT run a 160 in a daily driver. | |
Karma Aficionado
| Subject: Re: Should I replace my OEM thermostat? Sun Oct 12, 2008 6:54 pm | |
| 180 is even fine up here in CANADA! _________________ | |
| Subject: Re: Should I replace my OEM thermostat? Sun Oct 12, 2008 7:11 pm | |
| Marc, do you have your fan turn-on settings modified, with that "programmed ecm" in your sig? | |
| Subject: Re: Should I replace my OEM thermostat? Mon Oct 13, 2008 1:18 am | |
| - Rickw wrote:
- The lowest you would want to go is 180* and that's only if your PCM has been reprogrammed for that temp.
You do not need to reprogram your PCM to run a 180º T-stat. It's recommended for a stock car if you're planning on spirited driving, or doing repeated WOT runs. A 180º unit is fine for winter. It does not delay heating of the car on start-up, and should not cause less heat once warmed up, even when very cold. Maybe during extreme sub zero conditions you would notice it, but I haven't had any problem down to -5ºF. As suggested, do not use a 160º unit. Good luck. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Should I replace my OEM thermostat? Mon Oct 13, 2008 1:28 am | |
| Correct, no programming is needed. However, to take full advantage of the 180 t-stat, you would want your fans to turn on at a lower than stock temp setting. | |
rivboy Amateur
| Subject: Re: Should I replace my OEM thermostat? Mon Oct 13, 2008 8:07 am | |
SuperRiv07 Addict
| Subject: Re: Should I replace my OEM thermostat? Mon Oct 13, 2008 5:51 pm | |
| So How Do You go about changing the Fan Settings Cause I Installed a 180 thermostat and when im Sitting Im hitting close to 210 215 and driving Im At like 180 185 ish | |
| Subject: Re: Should I replace my OEM thermostat? Mon Oct 13, 2008 6:45 pm | |
EASHER Member
Name : ERIK M. ASHER Age : 55 Location : BLOUNTSTOWN, FL Joined : 2008-10-24 Post Count : 85 Merit : 0
| Subject: INSTALLED 180 DEGREE THERMOSTAT TODAY Fri Nov 14, 2008 1:41 pm | |
| I just got my 180 hi-flow thermostat from ZZP and put it in. I took the car out and noticed a nice difference in temp over the stock stat. It was very easy to do and took only 5 minutes. I want to know what to do next, any ideas? | |
Chicken Aficionado
Name : Mark Age : 57 Location : Montana Joined : 2008-06-13 Post Count : 1296 Merit : 8
| Subject: Re: Should I replace my OEM thermostat? Fri Nov 14, 2008 1:45 pm | |
| colder plugs would be my next mod.... | |
captshiner Junkie
Name : Andrew Age : 37 Location : Cincinnati, OH Joined : 2008-07-23 Post Count : 756 Merit : -1
| Subject: Re: Should I replace my OEM thermostat? Fri Nov 14, 2008 1:51 pm | |
| Subject: Re: Should I replace my OEM thermostat? Fri Nov 14, 2008 3:32 pm | |
| X3 on cooler plugs, AL104's are a good choice.
I'd also look into a 3" downpipe, Hogan Performance makes a good one, either by itself, or with their hi-flow Magnaflow cat. | |
EASHER Member
| Subject: Re: Should I replace my OEM thermostat? Fri Nov 14, 2008 4:38 pm | |
| Thanks for the advice, 104's it is for the next move followed by ported exaust manifolds and that Hogan 3" downpipe.
These are just to prep the car for a ported blower with a 3.4 pully, ported lower manifold, PCM reflash to get rid of that pesky 110mph speed limit and Stage 3 heads.
I so love my Riviera!!!!!!! | |
| Subject: Re: Should I replace my OEM thermostat? Fri Nov 14, 2008 5:52 pm | |
| May as well skip the ported manifolds and buy headers instead. | |
| Subject: Re: Should I replace my OEM thermostat? Fri Nov 14, 2008 5:54 pm | |
| Might want to look into an HP Tuners, considering the degree of modding you seem to be planning. At a minimum get a scan tool to monitor KR, before getting too far into making changes. | |
curious riv Addict
Name : Chris Age : 43 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
| Subject: Re: Should I replace my OEM thermostat? Fri Nov 14, 2008 7:24 pm | |
| YES... Definently scan before gettin to far... I think I'm going to skip the scanner and just get a tuner thats got scan/record capabilties. Wont be long and im gunna be buggin the hell out of you guys for tuning help | |
EASHER Member
| Subject: Re: Should I replace my OEM thermostat? Fri Nov 14, 2008 8:28 pm | |
| Subject: Re: Should I replace my OEM thermostat? | |
