Well i bought some used HIDs today only to get home to find out i was scammed. neither the ballasts or bulbs worked. Im short on money now but i feel the need for HIDs, im the only one in my "group" without them. Is there anybody that has working HIDs that would maybe cut me a deal, or would trade for them or something? i dont have money for new ones ATM.
T Riley Guru
Name : Travis Age : 34 Location : Minnesconsin Joined : 2007-02-08Post Count : 5127 Merit : 10
double check..... mine were messed up turned out i hooked them up wrong
well i tried pretty much every possible solution, the guy said he would try to hook them up for me, and if they still dont work he would give me my money back. hes actually a decent guy. i thought he purposely ripped me off
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6282 Merit : 119
Im short on money now but i feel the need for HIDs, im the only one in my "group" without them. i dont have money for new ones ATM.
Now that's some serious peer pressure. Spending money you don't have on something you don't need. Good Luck with hooking them up. Hope everything works out.
IBx1 Expert
Name : ILAN Age : 32 Location : College Station, TX Joined : 2007-12-30Post Count : 4304 Merit : 69
Be sure to read my write-up carefully. The part that the factory harness plugs into is reversed on the poles. You gotta flip it over and connect it that way. The tabs won't lock, they'll be on opposite sides, but mine haven't budged at all since installing them.
manofmany Addict
Name : manofmany Age : 39 Joined : 2008-07-26Post Count : 611 Merit : 5
I believe that is only on one side, the passenger side if I recall correctly.
IBx1 Expert
Obviously, any aftermarket mod isn't going to behave like stock. I'd like to see a shorter HID 'bulb' that would protrude the same length as a halogen, perhaps that would help fix some of the glare. I've been very lucky so far and my conversion has very little glare without me having to adjust the light aim down.
Personally I don't think there's any difference between the $100 and $500 kits besides pricing and brand names. Sure the more expensive one has a warranty and is more reliable, but for every one of the 4 Chinese ballasts I've had burn out, I got a free one for the cost of mailing the broken one to California. About $20 of shipping added to the $117 or so I paid, I'm still well below $500 and I get excellent, no-questions-asked service. Make sure the people you buy from are good in the customer service department and you should be fine.
Shintsu Expert
Name : Shintsu Joined : 2007-10-14Post Count : 2979 Merit : -16
Well, the good ballasts are made by Phillips (Ironic since their home electronics are subpar). The ballasts like those are what are used on cars that are factory equipped with HIDs. The $500 kits include projector housings as well as the quality ballasts. If there's one thing not to be trusted, it's Chinese circuitry and electronics. Consider if you will a lot of home audio equipment is made in China - the low end stuff. I have several pieces which are made in Japan, all the nicer models (and vintage) are made in Japan. I mean think how well something made in China in a sweatshop is compared to something that was carefully constructed in Japan. Given Japan's small size as a country, they don't have near the factory population like China does so they can't just toss people in a factory and pay them a dime a day or whatever. You have much lower chances of getting something just slapped together too quick since Chinese factories are all about speed and mass numbers than making high quality products.
IBx1 Expert
Oh, I thought you meant just the HID bulbs and ballasts, not the projector housings and stuff too! I agree about the quality, believe me I prefer non-Chinese stuff, but for the price it works out favorably. If anything goes wrong, I can swap the halogens back in place in about 10 minutes.
T Riley Guru
What's more important? Looking cool or actually lighting the road up better? Poor dispersion patterns put out by HID bulbs in the incorrect housings are not as effective as standard halogens. If you're interested in it only for looking cool then go get some blue painted bulbs. Doing stuff like this for looks only (And by looks I mean the looks of your car over the function) is really ricey. Like:
Think about it - if HID bulbs are closed off on the edges and all the light is reflected out the front through a rounded lens to provide an accurate pattern what do you think happens when you don't have that closed off enclosure to focus the light through or the lens? It turns the entire plastic lens into the same thing...except the lens isn't made for HIDs, it's made for halogens so the pattern is wrong and it's not evenly lit. On a car with true HIDs not the rice package, they go through the projector then they go through the plastic lens on the car. Think about how bright a flashlight is - now think about how bright it is if you remove the reflector inside. It's really common sense if you stop and think about it...
96RIVMANN Fanatic
Name : Paul Location : MN Joined : 2007-10-22Post Count : 253 Merit : 11
You dill weeds with HID'S should have your a$$ kicked! There is a reason why they are illegal as after market units. I can't tell you how many times I have been blinded by a cheap set of these units.
That hurt my feewings...
Shintsu Expert
Subject: Re: Write-Up: HID Conversion Sat Jul 25, 2009 2:01 am
'Tis not too late to go back to the dark side...Use the halogens, Luke - I mean Ilan.
Wait where am I again?
IBx1 Expert
Subject: Re: Write-Up: HID Conversion Sat Jul 25, 2009 9:39 am
Halogens really are the DARK side!!
Ryan from Ohio Fanatic
Name : Ryan Location : Toledo, Ohio Joined : 2008-11-16Post Count : 307 Merit : 7
Subject: HID Sun Sep 06, 2009 6:07 pm
Anyone switch to HIDs yet?
As a dealer I get and do sell them. Was thinking about tossing a set in the womans Rivi also.
Thoughts?
IBx1 Expert
i believe their store has stuff separate, but i dont think it is the bulbs that usually fail. i just had to warranty my 2nd ballast with them. they are taking forever to get it back to me too...
_________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily
IBx1 Expert
The ballast is what fails more often than not, but any HID light will work. Make sure it's a real HID bulb though, not a halogen painted with blue nail polish. Yes though, it is cool to have a pair of show bulbs like 30k's that you put in once you're at the parking lot. If you want spares go ahead, but if your ballasts go out just call up whoever you bought them from originally and they should replace them for the cost of you shipping out your bad ballast.
EatDirtFartDust Fanatic
Name : The Josh Age : 40 Location : Somewhere between Sullivan and Saint Peters Missouri. Joined : 2009-03-27Post Count : 284 Merit : 2
Yeah, I installed mine Saturday, and while I was letting them "burn in" for 10 minutes the passenger ballast went out. I sent a message Saturday night, and I received a tracking number a few hours ago.
