| Write-Up: HID Conversion | |
+57firefighter Jimdangello Mattwa denim Karma 69GSColorado RivieraParadise 2000ws6transam GM FIEND LT1Squirrel Rizz01 tanyue123 Jayrydingslab BigRay1125 nebstewart07 95rivy 7901mark TheNewEra95 Derek flyineagle96 KillaKeninaRiv Abaddon ZEP VJD2 BrianEsser DEMonte1997 GMFreak8 nigelf 97 park ave Eldo robotennis61 Ryan from Ohio 96RIVMANN Rickw texasfan010 Snowdog L8-2BNGO L67 EatDirtFartDust deekster_caddy manofmany Shintsu Natesriv TonySmooth89 Mr.Riviera T Riley albertj IBx1 '96reese palermocorey90 jax95riv SpaceBar RhinoFLA NO 4 EVR AA turtleman CeeKay 61 posters |
| Subject: Re: Write-Up: HID Conversion Thu Oct 27, 2011 9:33 am | |
| - GM FIEND wrote:
- Hi guys im new to the forum im 24 and i jus bought my 3rd rivy but anyway i wantef to put sum 6k hids in it my question is since i have daytime running lights do i need to purchase a relay harness along with the kit? My rivy is a 98
Yes, the DRL's are through the High Beams (half voltage). No need for the relay harness as long as you buy digital ballasts. Just plug right in to the factory headlight plug. | |
GM FIEND Rookie
Name : GM FIEND Location : baltimore,md Joined : 2011-10-16 Post Count : 14 Merit : 0
| Subject: Re: Write-Up: HID Conversion Wed Nov 02, 2011 7:08 pm | |
| HEY GUYS ME AGAIN IVE JUS RECEIVED MY HIDS IMMA INSTALL THEM THIS WEEKEND BUT I WANTED TO PUT HALO LIGHTS IN MY RIVY AND OF COURSE NO ONE HAS HALOS FOR THE 8TH GENERATION RIVY SO I WANTED TO KNO WAS THERE A WAY TO REMOVE THE LENSE ON MY HEADLIGHTS? SO I CAN INSTALL A HALO RING IN THEM....... THIS IS WHAT I WAS GONNA USE!! I APPRECIATE YALL HELP SO MUCH THANKS IN ADVANCE!!!!! http://www.ebay.com/itm/2x-Car-Angel-Eye-Light-Headlight-CCFL-Halo-Ring-90mm-/190573668728?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2c5f136978#ht_2370wt_1270 | |
IBx1 Expert
| Subject: Re: Write-Up: HID Conversion Wed Nov 02, 2011 8:30 pm | |
| I believe I heard there was a way to remove the lens. If you can pull this off, I think it'll look great with one halo per side. | |
| Subject: Re: Write-Up: HID Conversion Wed Nov 02, 2011 9:08 pm | |
| Heat gun. See page 9. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
GM FIEND Rookie
| Subject: Re: Write-Up: HID Conversion Wed Nov 02, 2011 10:06 pm | |
| OHHHHHHHHHHHHH I SEE BUT IMM SCARED AS HELL TO ATTEMPT THAT!!!! LOL I GUESS ITS THE ONLY WAY!!!!! I MIGHT JUS SEE IF I COULD KICK SUMBODY A FEW BUCKS TO DO IT FOR ME!!! THANKS THO GUYS!!!
| Subject: Re: Write-Up: HID Conversion Wed Nov 02, 2011 10:17 pm | |
| - GM FIEND wrote:
- OHHHHHHHHHHHHH I SEE BUT IMM SCARED AS HELL TO ATTEMPT THAT!!!! LOL I GUESS ITS THE ONLY WAY!!!!! I MIGHT JUS SEE IF I COULD KICK SUMBODY A FEW BUCKS TO DO IT FOR ME!!! THANKS THO GUYS!!!
if you follow the instructions it works -- get some junkyard headlights as backup and do it... if you search using Google you will find people offering to do it for about $450/pair, you supply headlights and parts. | |
GM FIEND Rookie
| Subject: Re: Write-Up: HID Conversion Wed Nov 02, 2011 10:22 pm | |
| $450 DOLLARS JUS TO HEAT UP MY LIGHTS AND TAPE A HALO RING IN MY HEADLIGHTS AND I GOTTA USED MY OLD ONES AND SUPPLY PARTS 0_O WHT A FREAKIN RIP-OFF I MIGHT JUS TRY IT AFTER ALL CUZ ILL ONLY HAVE TO DO HALF OR LESS OF THE THINGS IN THE VIDEO... I JUS GOTTA HEAT UP THE HEADLIGHT TO GET THE ADHESIVE OFF AND WHT KIND OF ADHESIVE WOULD I NEED TO BOND IT BACK TOGETHER AGAIN????? | |
| Subject: Re: Write-Up: HID Conversion Thu Nov 03, 2011 12:03 am | |
| Bet those guys charging $450 know what kind of glue to use. Maybe give them a call and ask? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: HID Conversion Thu Nov 03, 2011 6:12 am | |
- Bet those guys charging $450 know what kind of glue to use. Maybe give them a call and ask?
If you do a web search you'll find the names of the sealant (I forget what it is) that's used. It works kind of like the craft shop glue sticks in that it melts at temperature just below the melting point of the lexan-type polycarbonate the lenses are made of. But I think it comes as a liquid in a tube. I don't remember details now but I remember the details were easy to find on a web search. I think the goop is available from McMaster-Carr. I think there are pointers to all that stuff earlier in this thread - GM FIEND should consider reading this thread from the beginning. Part of the point was that if you do the melting right you won't need additional glue, you can remelt what's on the lenses and it will stick back together. Can only do this a couple - three - times or so, glue gets somewhat brittle-er with each remelt. | |
| Subject: Re: Write-Up: HID Conversion Thu Nov 03, 2011 3:00 pm | |
| Just stopping by with a random update. My HID system which I've had since early 2007 is starting to suck. It's difficult to really say why because I've switched to different color bulbs a few times so I don't know if it has more to do with the balasts or the bulbs. I wanna say different bulbs were better than others about igniting but that could be my imagination. Basically though when I start the car and they turn on, one or both of them cut off before they power up. In the beginning, this would happen on a seldom occasion and wasn't a big deal but now it's very rare that I don't have to restart them and when I do it, it often takes more than one additional try to get them both on - sometimes as many as four times.
So far, I've added a wiring harness like what WBS sells that has a relay and new grounds and whatnot. This didn't help my issue at all. I've got another set of balasts that are, as far as i know, new that I'll try now but I need to do something. This gone beyond annoying now. | |
| Subject: Re: Write-Up: HID Conversion Thu Nov 03, 2011 5:57 pm | |
| - turtleman wrote:
- Just stopping by with a random update.
So far, I've added a wiring harness like what WBS sells that has a relay and new grounds and whatnot. This didn't help my issue at all. I've got another set of balasts that are, as far as i know, new that I'll try now but I need to do something. This gone beyond annoying now. Did you look at the cases of your installed ballasts for discoloration or heat deformation? Yea, I'm thinking ballasts but I have no info to back that up. | |
GM FIEND Rookie
| Subject: Re: Write-Up: HID Conversion Thu Nov 03, 2011 8:31 pm | |
| Guys im glad you all r discussing hids i jus got mine in the mail i undersyand i have to take the bumper off to remove the headlights is this tru? And how do i do this? Thanks | |
| Subject: Re: Write-Up: HID Conversion Thu Nov 03, 2011 11:13 pm | |
| - GM FIEND wrote:
- Guys im glad you all r discussing hids i jus got mine in the mail i undersyand i have to take the bumper off to remove the headlights is this tru? And how do i do this? Thanks
not the bumper, just the bumper cover. Some pushpins and screws, pretty obvious if you get on the ground and look up under it. Albertj | |
| Subject: Re: Write-Up: HID Conversion Thu Nov 03, 2011 11:34 pm | |
| Must you remove the headlights to install? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: HID Conversion Thu Nov 03, 2011 11:39 pm | |
- Must you remove the headlights to install?
To just replace the capsules, not really. To install clear lenses, projectors and angel eyes, yes you do -- and you have to cobble together an alignment rig. Albertj | |
IBx1 Expert
| Subject: Re: Write-Up: HID Conversion Fri Nov 04, 2011 6:47 am | |
So far, I've added a wiring harness like what WBS sells that has a relay and new grounds and whatnot. This didn't help my issue at all. I've got another set of balasts that are, as far as i know, new that I'll try now but I need to do something. This gone beyond annoying now. That sounds like bad ballasts. Are you saying your original ballasts have lasted you since '07? Mine went out all the time; it's the reason why I chose Nokya bulbs instead of 3k HID's for my Si. | |
| Subject: Re: Write-Up: HID Conversion Fri Nov 04, 2011 8:25 am | |
| Yep, it's your ballasts dude. This happened to me on my very first set of HID's. I had one ballast that wouldn't come on all the time. I got them both warrantied and upgraded to "better" ballasts. Haven't had a problem since.... | |
GM FIEND Rookie
| Subject: Re: Write-Up: HID Conversion Fri Nov 04, 2011 5:02 pm | |
| hey guys i have a question i jus tried installing my hids(6000k 9006). they are "xentec" plug in plays i connected everything and plug them into lowbeams socket(this is wht im supposed to do right? not plug them into high beams..correct?)and i started the car and NOTHING.....also i have DRLs my rivy is a 98..they came with sum kinda extra harness will i have to use that for them in order for them to work(i was told i didnt) or does anybody know what i did wrong???btw neither headlight is coming on......plz help?thanks | |
| Subject: Re: Write-Up: HID Conversion Fri Nov 04, 2011 5:18 pm | |
| Try testing the new HID system off the car first. Hook it up to 12V and see if they light up. You can use the car's electrical system, making sure everything is grounded correctly. If they work, try installing one piece at a time, testing as you go. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: HID Conversion Sat Nov 05, 2011 2:39 pm | |
| I took a look at those spare ballasts and it looks like they're 55 watt. The system on my car now is a normal 35watt. I just took a look at a few different ebay vendors selling replacement HID bulbs only and there's no mention of wattage in regards to the bulb options... So I'm thinking you don't need to have a 55watt bulb to pair with a 55watt balast. Anyone know? | |
IBx1 Expert
| Subject: Re: Write-Up: HID Conversion Sat Nov 05, 2011 5:15 pm | |
| - GM FIEND wrote:
- hey guys i have a question i jus tried installing my hids(6000k 9006). they are "xentec" plug in plays i connected everything and plug them into lowbeams socket(this is wht im supposed to do right? not plug them into high beams..correct?)and i started the car and NOTHING.....also i have DRLs my rivy is a 98..they came with sum kinda extra harness will i have to use that for them in order for them to work(i was told i didnt) or does anybody know what i did wrong???btw neither headlight is coming on......plz help?thanks
Happened to me, just reverse the polarity of the connections to the factory harness. It's in the beginning of my actual writeup on page 4. The clip's locks wont engage but it should work fine. - IBx1 wrote:
- I ran into a problem trying to install the lights. The wiring is straightforward and simple, but some of them have a problem with the connection to the factory harness. If your lights do not turn on, this is why! The bit of plastic on the outside that the clip fastens around is on the wrong side. Just flip it over and reconnect it and it should work.
LT1Squirrel Enthusiast
Name : EB Joined : 2010-05-14 Post Count : 122 Merit : 2
| Subject: Re: Write-Up: HID Conversion Sat Nov 05, 2011 5:56 pm | |
Yup, same exact problem with mine, i just threw some zip ties around them and went on my way | |
manofmany Addict
| Subject: Re: Write-Up: HID Conversion Sat Nov 05, 2011 8:16 pm | |
| ^ What they said.
I just want to report that I've been running with the same bulbs for 3 years now. Never been flashed, had a cops attention, or had one burn out. | |
| Subject: Re: Write-Up: HID Conversion Sat Dec 03, 2011 5:30 pm | |
| My driver side HID ballast took a crap last night. Came home and noticed the light output was maybe 10% of what it should be. This morning it only flickers and then goes out. Could be the bulb but im ordering a new kit. DDMtuning.com seems to have about the best price avail. I paid $65 shipped for 2 new bulbs and 2 ballasts. I also got the slim versions and 55w so they are brighter. My buddy has ordered from them and they seem legit. the full size kits (looks to be the same as ZZP's) start at $30. Really cant beat that and they have a lifetime warranty. I'll post some pic when i get them installed. They should be a little brighter than the ones i have now (35w ballast) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
2000ws6transam Enthusiast
Name : steve Age : 47 Location : Indy Joined : 2011-10-29 Post Count : 181 Merit : 6
| Subject: Re: Write-Up: HID Conversion Sat Dec 03, 2011 8:20 pm | |
| i had the same problem, flipped the plug over and hooked it up , upside down and it worked! lol i think the germans dont know how to wire!! i got the phillips bulbs with forget the name of the balast makers and its so damn bright it hurts my eyes to drive the car!!!!! Question thought how did you disable the day time running lights ? they said to not use them with the bulbs and balast, | |
| Subject: Re: Write-Up: HID Conversion | |
