Name : Reese Age : 41 Location : StL Joined : 2007-09-20Post Count : 259 Merit : 4
Subject: Re: Write-Up: HID Conversion Sat May 17, 2008 2:08 am
well i jus bought my new hids i got the 10k color. the looks of it, i should have the kit by wed. cant wait
T Riley Guru
Name : Travis Age : 33 Location : Minnesconsin Joined : 2007-02-08Post Count : 5127 Merit : 10
Subject: Re: Write-Up: HID Conversion Sat May 17, 2008 11:44 am
i hope to get 10K too
palermocorey90 Expert
Name : Corey Age : 33 Location : Rome NY Joined : 2007-10-03Post Count : 2968 Merit : -24
Subject: Re: Write-Up: HID Conversion Sat May 17, 2008 12:26 pm
why 10000K ? there not even that bright.
'96reese Fanatic
Subject: Re: Write-Up: HID Conversion Sat May 17, 2008 1:27 pm
they jus look cool.........i'll prolly buy the 8k too on ebay
T Riley Guru
Subject: Re: Write-Up: HID Conversion Sat May 17, 2008 3:27 pm
i love the BLUE look...... and my riv's blue which is OBVIOUSELY the sexiest color known to man:]
IBx1 Expert
Name : ILAN Age : 32 Location : College Station, TX Joined : 2007-12-30Post Count : 4304 Merit : 69
Subject: Re: Write-Up: HID Conversion Sat May 17, 2008 5:25 pm
Cool, just so you know once you have the ballasts in you can put any color temp HID bulb in, and it should work, so you can use 8's for driving and 10's for show.
Subject: Re: Write-Up: HID Conversion Sat May 17, 2008 6:03 pm
ur such a ricer travis
Shintsu Expert
Name : Shintsu Joined : 2007-10-14Post Count : 2979 Merit : -16
Subject: Re: Write-Up: HID Conversion Sun May 18, 2008 3:27 pm
So you can't do a quick double flash of the brights to let someone go ahead or something? That's annoying. And sorry if I neglected to see where it said but where exactly is it that you swap out the 10A and 20A at? The fusebox inbetween the door and the dash right?
IBx1 Expert
Subject: Re: Write-Up: HID Conversion Sun May 18, 2008 9:39 pm
Yes, the one between the dash and the door. Also, you can flash your brights, just don't click the handle all the way back. If you pull it back before it, the brights will come on while the regular lights are on. I had to do this on Friday, actually.
Shintsu Expert
Subject: Re: Write-Up: HID Conversion Sun May 18, 2008 11:25 pm
Oh, huh. Never noticed I could do that, I always click it all the way back once or twice to let people have the go ahead. Thanks, I'll try and remember to do that and maybe get into that habit for a (Hopefully) eventually HID setup.
IBx1 Expert
Subject: Re: Write-Up: HID Conversion Mon May 19, 2008 6:08 am
Yup, just don't change the brights for HID's. They may be easier to reach, but you'd burn out the ballasts by flashing those at all like you would in a real world situation. Just stick with changing the regular lamps.
'96reese Fanatic
Alright, got them both in and working. The drivers side harness needed switched around.
Only thing is, neither are seated in the center of little metal housing inside of the headlight. The passenger side is to the extreme top and the drivers is to the extreme right. Is that how they are suppose to be or will it even matter?
Also, how hot do the ballasts get? Thanks
manofmany Addict
Name : manofmany Age : 39 Joined : 2008-07-26Post Count : 611 Merit : 5
Tested them out and they are nice, but not near as nice as the HID lights my RX8 had. I'm thinking I need to aim them up. Is that a possibility?
Name : Codith Age : 36 Location : Villa Park, IL Joined : 2007-02-08Post Count : 3671 Merit : 140
Subject: Re: Write-Up: HID Conversion Sat Aug 02, 2008 1:02 am
The housings can be aimed just as with the stock bulbs via the 2 adjustment knobs. Be nice to them because they do like to snap when they get old but I think it's more of a problem during the winter.
As for your uncertainty about the socket seating, I would check and recheck to make sure those boogers are in perfectly straight. Pull up to a wall to make sure the beams are even. and not scattered weirdly. I notice that it's pretty easy to put them in slightly crooked and not really notice it unless you're the other guy across an intersection facing you and you can see one light is normal and the other's beam is way too high or sideways.
Retrofitted HID's will not be like factory HID's, ever. The lenses are still designed for halogens.
manofmany Addict
Subject: Re: Write-Up: HID Conversion Sat Aug 02, 2008 9:16 pm
Good insight, turtleman.
I just wanted to personally thank IBx1 for taking the time to do the writeup. It helped me bigtime, especially when the drivers side decided not to light up. I'm very happy with the improvement and the looks. I would never go higher than 6k though.
Shintsu Expert
Subject: Re: Write-Up: HID Conversion Sat Aug 02, 2008 9:53 pm
Post a pic, let us see 'em!
Subject: more HID business Mon Sep 15, 2008 12:47 am
This is mainly for current HID users and especially for potential HID users. I decided to pick up another set of xenon bulbs to replace my existing set since the D2R style is now cheaply available.
Here's a link to a site that concisely explains what I'm talking about. It's not a big boring read so take a minute and check it out!
http://www.hidbulbsource.com/
Basically, they take the usual aftermarket style HID lamp and ceramic coat a section of it to better accommodate the reflector lens used with factory halogen lighting (like ours). The result is a more clear beam and less glare to those other drivers on the road.
Once I actually receive and install my new bulbs, I'll try to photograph the difference, assuming there is a noticeable difference.
Also, if anyone wants some seriously strange lights, I'm selling my 30,000k bulbs for $10+shipping. Note: You need to have the HID ballasts to use them.
If I'm happy with the new ones, I'll also sell my 10,000k set if anyone wants those. Those are as deep blue as you can get.
Just PM if you are ever interested. I'll probably have these laying around for a while.
IBx1 Expert
