 FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)
Merit : 122
FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 Empty
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyThu May 27, 2010 10:26 pm
I'll measure you one tomorrow afternoon when I get to the shop if you want...
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri May 28, 2010 11:06 am
Pulley Boyz have them, also ZZPerformance, and 3800 Performance. I got my 2.5 from ZZP. I think I will get my next 1 from Pulley boyz they have a better color variety.
Hows that SC project of ours coming Karma? I'm still wondering if I should go with the 2.3" or 2.4". If I get the meth injection, and knowing it hasn't got the teflon anymore will I be okay with the 2.3? Or u figure thats to much for the M62?
Merit : 122
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri May 28, 2010 11:56 am
Haven't had a chance to cut it up yet, got to get my riv back on the road in time for my sister's wedding.
Being a re-manufactured blower, with ALL new bearings, I expect physically it can handle the spinning down to 2.0", but the heat and lower efficiency at that speed would be more than you really want. Being that the re-man process had the rotors stripped, you can spay pre-blower to keep things cool, and the meth is supposed to help improve pumping efficiency too, so you you will be able to drop smaller than most would be able to normally. However, boost, even cool boost does not = HP. I'd stick with the 2.4" and the meth, until you know how much boost is actually being made with the setup.(and of course KR, every engine is different) And I think rockers should be top of your purchase list to get the air out again.
Cmurphy
Cmurphy
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri May 28, 2010 9:02 pm
if you could, theres a guy at my work who builds race cars and says he has a 2.5 i think he tryed it on a eaton 177 and he said it made way too much boost so he'd sell it to me if it would fit
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri May 28, 2010 9:15 pm
Have you been told the 2.5 is too small for the Series one engine.?
Do you have way of checking KR (Knock Retard) ?
Cmurphy
Cmurphy
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySat May 29, 2010 1:00 am
No, i was told it was a good size as long as you monitor your car regularly and with proper mods.
Yes i do, i got a Actron CP9145, my Knock Ret reading is 0
TheNewEra95
TheNewEra95
PostSubject: 2.5'' s/c pulley   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySun Jun 06, 2010 10:42 am
Was wondering what gains I would get from 180 drilled thermo, autolite 104s, 3'' exhaust and a 2.5'' s/c pulley? anyone have these mods for a 95?? let me know...
Thanks - Zach
95ParkAveUltra
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySun Jun 06, 2010 5:55 pm
you wont see alot of top end difference. series 1 motors seem to fall on there face top end wise. you will see a gain in your low end torque. i for one cant keep the tires from spinning under 45mph.
TheNewEra95
TheNewEra95
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySun Jun 06, 2010 6:08 pm
yah i kinda figured that, is it a big difference?? any effects on gas milage?
95ParkAveUltra
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySun Jun 06, 2010 7:09 pm
lol as far as gas milage... that all depends on your foot. i get about 19 city. i dont travel highway much so not sure on that. but ya there is a difference in the torque. but you wont notice much past 60-70. if you want to open up your top end. i suggest roller rockers. thats good for 10-15hp above 4k rpm. which is really where these motors need it.
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySun Jun 06, 2010 7:15 pm
I'd say, start with the rockers, 180*, 104's and 3" DP. (no need for a cat-back. stock is good for 12's) Those are all pretty safe mods. then if you want more later you can drop to a 2.5 you have the supporting mods to do so. do you have any way of scanning the car?
FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 Dsc_0110
95ParkAveUltra
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySun Jun 06, 2010 7:20 pm
i agree with mr.riviera. i totally forgot to mention scanning. what size pulley do you have on your car now? all stock? scan with every pulley drop. i dropped from 2.85 to 2.5 and it took about 100 miles for the computer to readjust fuel trims. i spiked to 7 degrees of knock instantly. after the 100 miles i have none. but with those mods including rockers you should have no problem
Merit : 122
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySun Jun 06, 2010 10:58 pm
Mr. Riv is right about the order, rockers are really up there to get the pulley drop to work correctly. The thermo and plugs are really supporting mods for the pulley drop and don't make power in themselves.
and Cmurphy, sorry this is late, but the shank for the m62 is .642". and its keyed.
TheNewEra95
TheNewEra95
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyWed Nov 17, 2010 9:06 am
Sorry been away for a bit, my cars been off the road for a while due to hitting a massive pot hole in my city and I fought them to pay for the damage(Finally won, 2700 bucks in damage)
I actually dont have a way of scanning the car....on that note, how do you scan a OBD1? Same way as OB2? Newb question but yah...thanks guys.
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyWed Nov 17, 2010 10:55 am
for a series 1 you have a obd 1.5 . A , Actron cp 9145 scanner will work. its a obd1 with a obd2 connector. if you have the same set up as my 95 riv s/c of course.
congrats on kicking the citys ass!
Merit : 17
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri Jun 24, 2011 11:34 am
I scanned my riv and have not found any KR. I am running the stock pulley now, i am considering changing pulleys, but i'm not sure if i should go for the 2.7 or 2.6. I want to be as safe as possible, but i don't know if 2.7 will yield any gains. Any input?
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri Jun 24, 2011 11:53 am
With Series I, because the OEM pulley dia is small to begin with, any decrease at all is significant. If you want to be safe with no other mods, go with the 2.7". This will give a little added boost, maybe gain 10 HP. You will notice it as low end torque. This would be like dropping to a 3.6" on our Series II SC engines.
If you do the 2.6", it's a more significant gain, probably in the 20 HP range. This is when you should start thinkng about adjusting fuel delivery, either with a custom PCM tune or using a Mini AFC inline with your MAF sensor. Additional mods like 3" downpipe and/or high-lift rockers will let the added boost breath better, giving you even more gains, and lowering KR.
PS - when you scan for KR, make sure you are really testing WOT under different load conditions, like after the 2-3 shift point at WOT, and during a sudden downshift while driving. Even stock you should be able to get a blip or so when you try. This is okay, and tells you where to look for it next time you scan.
Merit : 17
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri Jun 24, 2011 11:57 am
Okay i think i will buy a 2.7. I am also trying to decide weather to get the autolite 605's or the 104's? My mods are pretty low, but has anyone had problems with the 104's?
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri Jun 24, 2011 12:11 pm
as long as you get on the gas occasionally there is very little chance you will have plug fouling with 104's.
If you dont plan on changing them often (for me the copper plugs seem to last about a year) you might want to get the iridium 104's. they will run slightly hotter than the copper 104's but last a lot longer.
Merit : 17
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri Jun 24, 2011 2:03 pm
So would the Iridium 104's be like the range of the copper 605's?
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri Jun 24, 2011 2:23 pm
Hard to say exactly. And at your mod level, it's not going to make a huge difference, imo. Buy the iridium if you have the cash and are looking to get 50k+ miles out of a set of plugs. I like the using normal copper plugs because they're cheap, and changing them out once per year lets you inspect for clues on your engine's condition. I discovered my LIM gasket was leaking by identifying the residue on 2 of the back plugs.
Merit : 17
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyFri Jun 24, 2011 2:50 pm
Alright i will buy the iridium 104's along with a drop in K&N filter and a 2.7 supercharger pulley. With my 180* thermostat and these mods maybe i'll be able to add 10-15 horsepower.
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptySun Jun 26, 2011 10:44 pm
I am starting to do some "soft mods" on my 57k mile Series 1.
I am considering a 2.7" pulley and I need to know if this will fit before I order...
Eaton M62 Keyed Pulley
http://www.pulleyboys.com/store/product.php?productid=39&cat=9&page=1
Merit : 122
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyMon Jun 27, 2011 9:57 am
yep. It'll fit.
Merit : 17
PostSubject: Re: FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)   FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I) - Page 4 EmptyMon Jun 27, 2011 1:05 pm
That is the same one i am going to order
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» Easy Belt Length Calculation: Pulley Swap Only
» MTD Variable Speed Pulley system: GOOD OR BAD?
» selecting the right authentic NFL Jersey size
» Pulley And Belt Calculator
» what belt size should i need
