 knock sensor location
zerg1024
PostSubject: knock sensor location   Thu Apr 10, 2008 9:58 pm
hey was wondering if anyone could tell me where the knock sensor is locate on my 95 riv. i have been looking for it and i cant find it.
zerg1024
PostSubject: Re: knock sensor location   Fri Apr 11, 2008 3:58 pm
i guess no one can help me out with this?
'96reese
PostSubject: Re: knock sensor location   Fri Apr 11, 2008 10:33 pm
if you have a non supercharged riv it's located "on both sides of engine under exhaust manifold" and if it is supercharged then it is located "on lower right side of engine, near oil filter" at least that is what my mitchell repair disk says. good luck
zerg1024
PostSubject: Re: knock sensor location   Sun Apr 13, 2008 12:35 am
ok so i went to go change the back knock sensor and i dont have a wiring harness for it can someone help me out here dont know what to do now
'96reese
PostSubject: Re: knock sensor location   Tue Apr 22, 2008 12:02 am
sorry i dont know what the hell i was looking at when i wrote that. whether is super or non the knock sensor should be under exhaust manifold. looking at the elec location map, its showing that its the front manifold. make sure you have a manifold gasket, you might have to pull the manifold off to get to it
