| Write-Up: Replacing Supercharger Belt Tensioner | |
+183.8 Riviera LARRY70GS wee-one BoattailBob 1998 Riv ibmoses ewolfe0050 T Riley deekster_caddy Jason zombiesarebad RhinoFLA albertj Mr.Riviera BillBoost37 96RIVMANN AA allfalldown 22 posters |
allfalldown Member
Name : Adam Location : Renton, WA - 1996 Riv Joined : 2007-07-12 Post Count : 98 Merit : 0
| Subject: Write-Up: Replacing Supercharger Belt Tensioner Thu Dec 20, 2007 5:23 pm | |
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Thu Dec 20, 2007 5:54 pm | |
96RIVMANN Fanatic
Name : Paul Location : MN Joined : 2007-10-22 Post Count : 253 Merit : 11
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Thu Dec 20, 2007 7:44 pm | |
| If you are talking about the lower super charger tensioner I wish you luck. What a royal PITA! | |
allfalldown Member
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Thu Dec 20, 2007 9:18 pm | |
| SHIT! Hahaha.. Yeah, the big one.
Uh, this is easily worth the money! | |
BillBoost37 Junkie
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Dec 21, 2007 8:38 am | |
| This is the front tensioner?
Shouldn't be bad at all. 3-4 bolts and a ground it's off. | |
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Dec 21, 2007 9:32 am | |
| yea the front tensioner comes off easy, i've never taken the rear off, but it shouldnt be too hard once you get the belts out of the way. about 1/2 way down the page on the write up AA posted, there is a engine pic with #'s for pulleys. which one are you looking at replacing? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
allfalldown Member
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Dec 21, 2007 12:17 pm | |
| The main one is part of the water way of the engine - has all kinds of passages through it. It appears that I need to take the motor mount off, thus I need to support the engine.
I can do all this stuff, but I have 3 burst discs and would rather not put my body through all that contorting. Just seems harder than I thought it would be. | |
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Dec 21, 2007 3:19 pm | |
| You could try quoting it out. More than twice I've been offered to have my belts changed for $99. Some mechanics don't see the challenge until it's upon them. If you can hold them to their quote, it would be worth paying for, especially this time of year. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
allfalldown Member
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Dec 21, 2007 9:07 pm | |
| I need the whole tensioner, not just the belts! It is making noise and I know better than to let it go much longer! | |
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Wed Dec 26, 2007 8:22 pm | |
| You're right. Mine just seized. Sudden death to tensioner and an unplanned diversion. Yuck. Was about 178,000 miles. Should have seen it coming, I guess.
allfalldown Member
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Feb 01, 2008 4:13 pm | |
| Actually, now that I look at it, it is the front tensioner (Supercharger). It is very confusing to look at: I looked at the link above... and it appears as though this is for the Alternator belt (rear).
Does anyone have any advise for the front (small) tensioner? It also appears that the pulley is broken down by the engine bolt (which makes me think I'm going to have to take everything out anyway).
Thanks,
Adam | |
RhinoFLA Aficionado
| Subject: S/c Tensioner Fri Feb 01, 2008 6:33 pm | |
| Matt mentioned that you needed a 15mm socket to loosen the tension on the s/c belt.. but the bolts on mine are this crazy star shape.. am I just an idiot, or am I missing something It IS number 3 correct? even the bolts on those look to be 15mm metric sizes.. look at mine in the picture.. any help is greatly appreciated as i'm trying to figure out if I need to order a coupler or not, since i'm placing an order with intense and might as well pick the coupler up if I do in fact need it.. | |
RhinoFLA Aficionado
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Feb 01, 2008 6:36 pm | |
| amigod.. I thought I was viewing the engine/tranny thread.... my bad Aaron | |
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Feb 01, 2008 6:50 pm | |
| yes # 3 is right. mine is a 15mm along with the one of the engine diag.
i guess 97+ rivs have a star screw instead?? does the new pulley come with a new bolt too? if you're ordering the coupler might as well get some s/c oil from intense. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RhinoFLA Aficionado
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Feb 01, 2008 6:56 pm | |
| well the coupler itself is 30, but they sell the install kit for 40 which includes the oil, so i'm just going to do that.. I don't want to order this if I don't really need it.. but I hear that sort of rattling noise and when I put my hand on the snout I can feel the vibration.. what do u think | |
zombiesarebad Member
Name : Brian Age : 40 Location : Maine Joined : 2007-12-04 Post Count : 97 Merit : 0
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Feb 01, 2008 11:15 pm | |
| i think you might be looking on the end that bolts it on rather than the end you are supposed to pull on??? | |
Jason Aficionado
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Fri Feb 01, 2008 11:59 pm | |
| so use a torx bit. T- 45 IIRC | |
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Sat Feb 02, 2008 12:03 am | |
| IIRC mine needs a T50 torx. But yes some cars have a hex-head bolt there. Mostly GTPs. All the buicks I've seen have Torx heads. | |
T Riley Guru
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Sat Feb 02, 2008 12:15 am | |
| - deekster_caddy wrote:
- IIRC mine needs a T50 torx. But yes some cars have a hex-head bolt there. Mostly GTPs. All the buicks I've seen have Torx heads.
i used a allen wrench of some sort | |
RhinoFLA Aficionado
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Sat Feb 02, 2008 11:13 am | |
| i'll have to pick one up.. I haven't had the need to buy one yet lol | |
ewolfe0050 Aficionado
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Sat Feb 02, 2008 11:23 am | |
| I used an allen wrench too... | |
Jason Aficionado
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Sat Feb 02, 2008 12:11 pm | |
| perhaps it is a t-50... It's one of the larger ones. I'd go for the torx bit before a hexhead, which can strip out the hole. | |
RhinoFLA Aficionado
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Sat Feb 02, 2008 12:14 pm | |
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Sat Feb 02, 2008 12:26 pm | |
| I'm pretty sure it's T50. They used to have a cheap set of 4 at autozone that was T40, T45, T50 and T60 that comes in pretty handy. Just get a couple. You'll find some other sizes of Torx on your Riv from time to time. | |
RhinoFLA Aficionado
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner Sat Feb 02, 2008 12:35 pm | |
| Yeah, i'm slowly putting together another tool set, because I have a stand up toolbox at work, filled with just about every tool you could need.. but it gets annoying having to bring home this size wrench, or that size socket just to work on the riv. | |
| Subject: Re: Write-Up: Replacing Supercharger Belt Tensioner | |
