 Write-Up: Installing SLP Exhaust Headers
Merit : 123
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Sun Jul 29, 2007 2:19 pm
so Pat, I see the down pipe comes down and the cat clamps to it. easy. the part i'm foggy on is what happens at the junction of the rear end of the cat and your pipe? Do you have your original pipe there?
Merit : 64
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Sun Jul 29, 2007 4:45 pm
did you use the O2 sensor extension? I'm not too sure if it is for the front or rear 02 sensor
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Sun Jul 29, 2007 11:17 pm
The downpipe goes right to the cat. There is no stock pipe there.
I'm pretty sure its for the front. I didn't do the install but I think I remember seeing it on the front. I'll check it tomorrow for you though. Unless Aaron chimes in before then.
Merit : 239
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Jul 30, 2007 9:10 am
I used mine. It's for the front sensor. The rear one isn't used if you delete the cat.
Congrats, Patrick. Did you get the ARP bolts? Have fun wrapping that flex pipe!
^^^ RIV IS FOR SALE! ^^^
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Jul 30, 2007 9:13 am
Thanks! Yeah I got the APR bolts. How did you get the wrap to stay on? I was looking at High Temp silicone spray that is supposed to keep it to stay on.
Merit : 239
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Jul 30, 2007 9:49 am
I used SS hose clamps at start and finish. Wrap from front to rear. The pipe already hangs low, so keep the closures to the sides or else could scrape. Be prepared to rewrap next year. Winter takes it's toll!
Have nothing against silicone, but I didn't use it. Thought it might get messy I guess. Maybe brushing it on would be better, just apply it after wrapping. You don't want that stuff getting in the braided flex.
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Jul 30, 2007 10:08 am
How much did you use? I got a roll of 2" x 50 ft.
Merit : 239
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Jul 30, 2007 10:13 am
I used exactly one roll of 1" x 50'. It wraps much easier than 2", imo.
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Jul 30, 2007 10:21 am
That was the only thing I could find around here. 2" x 50' for $44.99 or I could have ordered a 1" x 10' for $39.99 and it would be here by the end of the week. I opted for the 50' for $5 more. wink
Merit : 239
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Jul 30, 2007 10:30 am
97rivman
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Jul 30, 2007 11:13 am
Ive got a set of TOG extremes and so far, theyve been pretty good at keeping heat down, except I do want to wrap under the throttle body or get a heat shield. The only thing is that the 02 sensor is right up against the power steering shaft. Thats just poor R&D on their part.
dezorro
PostSubject: i want some   Mon Aug 27, 2007 7:24 pm
i would like to purchase some headers like yours where can i get some. thanks
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Mon Aug 27, 2007 8:15 pm
http://www.intense-racing.com/Merchant2/merchant.mvc?screen=CTGY&Store_Code=IR&Category_Code=EX
They aren't cheap. If you want something cheaper someone on here just recently purchased some on ebay for around $300 I believe.
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Fri Aug 31, 2007 2:14 am
i was going to get the knock off headers cus i have noooooooo money what so ever........ BUT......... when i look under my car at the rear manifold it llooks IMPOSSIBLE to get that rear mani out??????? idk......... how hard was it to get it out????
Merit : 239
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Fri Aug 31, 2007 10:08 am
It's not hard. Once you cut the pipe and loosen the bolts, it just slides out the bottom. It's more difficult to install the new bolts, as getting in with a torque wrench is near impossible. I jut turned them "good and tight".
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Fri Aug 31, 2007 10:42 am
Aaron, your pics sure seem to show a lot more manuevering room on the front side than I seem to have.... I want to install my front PEM at the same time I do my DP/Cat install. You didn't sneak the radiator out, did you? smile
Merit : 239
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Fri Aug 31, 2007 10:55 am
Nah, only thing I removed on the front side was the heat shield. After the write-up, I had the front side off again to seal it at the clamp. It only took about 45 mins.
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Fri Aug 31, 2007 11:03 am
I'm sure it won't be so bad once I actually start the work. Was just sizing it up the other day, and figuring out how I was going to get my long arms/big hands in there. scratch
Merit : 99
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Fri Aug 31, 2007 11:47 am
can you reach the rear mani bolts with a long (12" or longer) extension on the ratchet? you would need to use one of those swivel pieces too.
1996 with 254k miles, L324" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs.
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Tue Sep 11, 2007 2:04 pm
I am on my third day now of installing the SLP (not working straight through). Mostly due to my lack of having the proper tools and my fear of me being under the can just on jack stands. I have already had the car fall off one stand in a previous instance and I had an old Pontiac do the same (only with me under the car in which I was pinned). Now the car is on ramps and four stands in the front. makes me feel a little more comfortable. I did learn that if you pull the tranny tube while the car's front is in the air, 2 1/2 quarts of fluid will come out. If I had to put headers in all over again... yeh, I'd do it... but it is the biggest pain In the a I have delt with!!!
Merit : 239
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Tue Sep 11, 2007 2:14 pm
I have never had the car fall off a jack stand, but it is a fear of mine as well. Usually, I keep a stack of 1 ft long 2x6" boards stacked up under the control arms or somewhere nearby as a failsafe. Sometimes, I will transfer the car's weight into the stack of boards because I trust them more than stands. Never hurts to be too careful working under a car.
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Tue Sep 11, 2007 3:35 pm
I'm not real comfortable working under a car on jackstands, but have done it countless times. My biggest issue these days is my new garage, which has a significant slope to the floor. Makes me much less comfortable under a car. It's part of the reason I'm letting a shop do my DP/cat install this week.
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Wed Sep 12, 2007 9:29 pm
I'm never comfortable under the car. ;(
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Thu Sep 13, 2007 11:49 am
I am having a hard time with the tranny dip stick tube. The only local junk yard broke the bracket off theirs and welding shops said they can't tack it back together. I called Pontiac direct and they said they have three different part numbers for the '97 GTP Series II SC. What part number is it so I can order this and be done?!!
Merit : 64
PostSubject: Re: Write-Up: Installing SLP Exhaust Headers   Thu Sep 13, 2007 11:59 am
email ed morad (gtped@msn.com). It cost more to get one shipped to me than the actual part cost! Also, he's sure to get you the right one.
I'm tackling this this weekend with the slp knock-offs smile I spent a few hours grinding away the crappy welds inside, but am finally ready to go.
Page 2 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» Write-Up: Installing SLP Exhaust Headers
» Write-Up: Wrapping Exhaust Headers
» Write-Up: Installing Glasspack Mufflers
» Write-Up: Installing a Front Strut Tower Brace (STB)
» Write-Up: Installing KYB GR-2 Struts
