 FAQ: Sunroof (Moonroof) Questions
Go to page : 1, 2, 3  Next
FAQ: Sunroof (Moonroof) Questions Empty
PostSubject: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySat Apr 19, 2008 11:07 pm
So Corey and i were talking and one of the only disappointments we have in our Riviera's is that we don't have the optional sunroof   frown ...  well we got to talking and corey found this sunroof
http://www.zzperformance.com/grand_prix/products1.php?id=750&catid=164
He said it would be scary to cut through the roof BUT he could pull it off and make it look good.... Well i on the other hand am not so fortunate i would be scared as heck to cut through SO.   HAS anyone EVER heard of putting in a aftermarket moonroof? do bodyshops do this or what?  does anyone know anything about putting in a moonroof LET US KNOW thumbsup
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 12:14 am
I know nothing, but I think there are drain lines that run through the body of the car on factory installs, and the headliner is lower for the sunroof to retract into. Does the aftermarket kit incorporate those things? Does it push the window out over the roof of the car (those don't look as good).
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 12:54 am
yes there is indeed a drain line in each pillar on each side of the car FACTORY.......
Merit : 133
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 1:03 am
http://www.zzperformance.com/grand_prix/products1.php?id=750&catid=164thumbsup
I would easily pay that to get mine working again. My factory sunroof, like many other gm ones over some time, doesn't work anymore. It sounds like the chain is skipping on the gear. I see they have 2 sizes. Anyone have any idea if either fits a riviera? I'm 90% sure that a bonne, aurora, other buicks sunroofs are the same. Not sure about a GP.. I also understand that these assemblies are not servicable so I don't think an individual component swap is possible.
Kustom Kreationz
Kustom Kreationz
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 9:43 am
Aftermarket sunroof's are a breeze to install once you get the hang of it. It's gettin someone to let you practice that can be the hard part! happy
MOST aftermarket roofs wont be moonroof types like the factory one(moonroof as in drops down and slides inside). I say most, because there are a few folks out there that put the moonroofs in, but they are far from easy to install. When my factory roof fails me, I will find a aftermarket with a bigger cut out hole than the factory one and have at it! wink
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 10:20 am
thanks for the input, im thinking should be able to do this
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 10:23 am
FAQ: Sunroof (Moonroof) Questions 05targaupobl
FAQ: Sunroof (Moonroof) Questions DSC00458
travis how about a targa
Merit : 133
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 10:37 am
Wow that's goofy looking on a mustang and the second one doesn't look right to me at all.
BKRIV
BKRIV
PostSubject: to turtleman sunroof   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 12:45 pm
I recently read the sunroof motor sometimes will need to be re-syncronized. it can be done at a dealership by any sharp GM trained mechanic that can follow the instructions in the service manual. it sure would be worth investigating it's probably the best option to have this time of year since riv's never came as convertibles.
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 2:28 pm
correction there was 3 yes three 8th gen riv converts
BKRIV
BKRIV
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 3:19 pm
wow I've never seen one and someone I regard as a bigger riv enthusiast told me different and never questioned him, anyone have pictures?
learning every day...I stand corrected...thanks Corey!
BKRIV
BKRIV
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 3:25 pm
forget it...I'm just a dumbass that thinks only in terms of 94-99 model years like mine I do remember the 80-86 drop tops
Merit : 64
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 4:51 pm
I would pay not to have a sunroof.
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 5:50 pm
Kustom Kreationz
Kustom Kreationz
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptySun Apr 20, 2008 8:13 pm
This roof is a factory replacement roof. Just noticed that. This is to replace your factory one, and would take alot of skill to install into a car that never had a sunroof......
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyMon Apr 21, 2008 8:04 pm
I have the service manual for my '99 and plan on doing this when time allows, will be a while but I'll let you know how it turns out.
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyMon Apr 21, 2008 8:12 pm
I put one in a '75 Regal S/R I had several years ago, not really that big a deal after getting past drilling that first hole in the top to start! I also put one in a Camaro of a friend after that.
My next project for my '65 Riv is to install the sunroof that I just cut out of my '92 Riv.I'm sure it will be an interesting install.
No pictures yet, I'll try to get some this weekend of what I have torn up so far. thumbsup
Merit : -16
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyMon Apr 21, 2008 10:27 pm
Perhaps going a bit off on this but why do you so desperately want moonroofs for? I've got one but I swear I don't ever use it. I pop it up only once in awhile and that's just because I have it. Panoramic moonroof would be cool but eh, I don't see so much thrill in a regular one.
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyMon Apr 21, 2008 10:28 pm
Shintsu wrote:
Perhaps a bit off-topic but why do you so desperately want moonroofs for? I've got one but I swear I don't ever use it. I pop it up only once in awhile and that's just because I have it. Panoramic moonroof would be cool but eh, I don't see so much thrill in a regular one.
A more luxurious ride i guess thumbsup
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyMon Apr 21, 2008 10:48 pm
Shintsu have you no lust for life!?!?!?!
J/k
I just like the open air feeling of a sunroof sometimes , on a nice sunny day its really relaxing , i use it whenever i can , some prefer the quitness and sanctity of a car without any wind , and thats cool too , and i enjoy that sometimes as well. Its a good comprimise for those who like the open air feeling of a convertible , who dont wanna pay extra insurance ,comprimise the structural integrity of their car , or just don't like the look of convertibles ( me , although that converta)ble 8th gen riv looks awesome , but then again what riv doesnt?) its just gives the car a different feeling than just windows down.
Merit : 133
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyTue Apr 22, 2008 12:38 am
I'm a big fan of sunroofs. In my last car, I had it open all the time. I HATE not being able to open mine in the riv. I definitely like my open windows. If they made the side wind deflectors for the riv, I'd probably buy them so I could have the windows open in the rain without getting wet, despite my opposition to sticking pieces of plastic to my car.
Speaking of which, does anyone know where I might be able to pick up such an item for a riviera? Maybe it's out there and I just haven't seen it..
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyTue Apr 22, 2008 11:10 am
When I've owned a vehicle with a sun/moon roof, it was open ALL the time, unless it was raining or mid-winter. I love 'em, can't beat the more open feel it gives. Esp in spring. It's really the only option not on my Riv that I really want.
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyTue Apr 22, 2008 11:52 am
I use the moonroof as much as possible this time of year, mainly because I like being in the sun. It's the only way to soak up rays in a car. Windows are just a way to tan your forearms!
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyTue Apr 22, 2008 8:28 pm
Now that the warm weather has finally arrived, mine is open all the time. I only close and A/C it when I'm on the phone.
Merit : -16
PostSubject: Re: FAQ: Sunroof (Moonroof) Questions   FAQ: Sunroof (Moonroof) Questions EmptyTue Apr 22, 2008 8:44 pm
I don't think that'd be possible with the design of the door. Since the window is frameless there is nothing for the plastic to clip to and if you somehow put it in between the door and the window it'd hit that every time you closed the door unless you rolled the windows down every time you closed the door. I like the looks of the frameless design but I hate how rattly the doors sound when I close them with the windows down and the inside panels move some when I do.
Getting back on subject, I only pop the moonroof up - I almost never slide it back. It makes way too much noise if you're going over 35 mph. I don't see how some of you drive down the expressway with the windows down, far too noisy and loud especially since the speed limit on the expressway here is 70 mph. Not to sound like a nerd but it also makes more drag and kills some of your gas mileage.
» Sunroof Photos
» Garmin 610 Questions
» 2010 preseason trivia questions.
» Couple of questions about rumors...
» Pulley Question
