 A/C
3 posters
riv91
A/C Empty
PostSubject: A/C   A/C EmptyWed Apr 23, 2008 6:39 pm
Sense i got the car the a/c has never worked.. With warm weather here i would like to get it to work. the compressor does not engage only engages with a paper clip in the relay box from 30 to 87 ... my question could it be the low cut off switch or a leak in the system cause i did have it filled awhile ago but the compressor wouldn't engauge.. And were abouts is this cut off switch located ?
A/C Empty
PostSubject: Re: A/C   A/C EmptyWed Apr 23, 2008 6:47 pm
On my '92 there is a way to reset the system using the buttons on the controls, that is with the automatic climate control. I'm not sure if the '91 would be the same or not? On mine the compressor went bad and started making noise and the system read this and locked it out, resetting it might be what you need too?
riv91
A/C Empty
PostSubject: Re: A/C   A/C EmptyWed Apr 23, 2008 7:00 pm
99RivMan what buttons did you have to push to reset the system? Also i think i know were the low cut off switch is how do i test it to see if its bad, or is there way to bypass it just to see if it is bad
riv91
A/C Empty
PostSubject: Re: A/C   A/C EmptyWed Apr 23, 2008 7:11 pm
Allright so i pull the sensor on the low cutoff switch and ran a paperclip in the sensor and the compessor engaged and a/c light went off so it has to be the low cut off switch right ??
A/C Empty
PostSubject: Re: A/C   A/C EmptyThu Apr 24, 2008 9:32 pm
I'm out of town for the next couple of days, I can look and see where I got my reset info and let you know as soon as possible.
riv91
A/C Empty
PostSubject: Re: A/C   A/C EmptyThu Apr 24, 2008 10:53 pm
ok but i think i have locked in on the problem but it would still be good to know how to reset it ..Thanks
dscott2000
dscott2000
A/C Empty
PostSubject: Re: A/C   A/C EmptyFri Oct 03, 2008 11:19 am
Well, I just had this problem with my '90. I recharged the system and reset all of the electronics. (Which includes undoing the positive battery terminal.) After I did that, my AC works great!
http://www.cardomain.com/ride/3061543
A/C Empty
A/C
Riv Performance ::   N/A 3800 Tech :: Pre-Series I Engine & Transmission-
