| pulley help | |
palermocorey90 Expert
| Subject: pulley help Thu Apr 24, 2008 8:27 pm | |
| ok its time to order parts good buy cash flow. im looking at a 3.4 or a 3.3 pulley, the current mods i will be running on the S2 will be, ported blower, ported LIM, front/rear plog ,ZZP 3" catless DP, 104s, 180* t stat,FWI. which pulley will work for me 3.3 makes more power so i cant to run that can i | |
Buapo Addict
| Subject: Re: pulley help Thu Apr 24, 2008 8:54 pm | |
| If you're going to run a 3.3" pulley, I would have to recommend a tune just to be safe. I'm not the expert on the subject, but I know that the 3.4" pulley is pushing the limits of the stock fuel tables (from reading the FAQ) and you would have to go with a tune. You're well on your way with all those mods, and in my opinion, if you have a FWI, T-stat, ported/plog'ed manis, and 104's, that's enough to safely run the 3.4" ....
My advice? Get the modular pulley system, and buy both pullies - then, when you get your tune done (where, I have no idea) then you can tune for the 3.3" and see where you go from there. Plus you should be able to sell the 3.3" to someone if you have to get some money back. | |
| Subject: Re: pulley help Thu Apr 24, 2008 8:57 pm | |
| - Buapo wrote:
- If you're going to run a 3.3" pulley, I would have to recommend a tune just to be safe. I'm not the expert on the subject, but I know that the 3.4" pulley is pushing the limits of the stock fuel tables (from reading the FAQ) and you would have to go with a tune. You're well on your way with all those mods, and in my opinion, if you have a FWI, T-stat, ported/plog'ed manis, and 104's, that's enough to safely run the 3.4" ....
My advice? Get the modular pulley system, and buy both pullies - then, when you get your tune done (where, I have no idea) then you can tune for the 3.3" and see where you go from there. Plus you should be able to sell the 3.3" to someone if you have to get some money back. im running a walbro 255lph fuel pump , i was lookign at the w-body stroe 3.3 MPS | |
| Subject: Re: pulley help Thu Apr 24, 2008 11:10 pm | |
| I hope you've done a lot of research on the parts you are bolting together. You are going to use S2 heads with ported manifolds? | |
Buapo Addict
| Subject: Re: pulley help Fri Apr 25, 2008 2:25 am | |
| I thought your Walbro was a waterpump... whoops.
Anyway, as Derek was saying, you might want to think about headers instead of ported, especially with that nitrous (I imagine the headers would help in this department). | |
| Subject: Re: pulley help Fri Apr 25, 2008 7:47 am | |
| - deekster_caddy wrote:
- I hope you've done a lot of research on the parts you are bolting together. You are going to use S2 heads with ported manifolds?
im not use the S2 heads for a couple months i need to get the money after i get em i will be running headers | |
BillBoost37 Junkie
| Subject: Re: pulley help Fri Apr 25, 2008 9:30 am | |
| Corey...are you posting because you are looking for some of these parts?
I have some of the stuff you posted.
LMK | |
T Riley Guru
| Subject: Re: pulley help Fri Apr 25, 2008 9:56 am | |
| - BillBoost37 wrote:
- Corey...are you posting because you are looking for some of these parts?
LMK oooh do you have injectors? 42.5 lbs or 65 lber's? | |
BillBoost37 Junkie
| Subject: Re: pulley help Fri Apr 25, 2008 10:23 am | |
| OMG..sorry Corey..I didn't read the title that closly. I do have a couple pullies with an MPS hub on the way to me.
42 or 60lb. Nope. sorry. | |
SpaceBar Aficionado
| Subject: Re: pulley help Fri Apr 25, 2008 10:51 am | |
im not use the S2 heads for a couple months i need to get the money after i get em i will be running headers You are better off waiting then and buying the part you are going to end up with. Why spend $200 now to spend another $900 later and get rid of the $200 part? Makes no sense. If you know where you want to end then wait till you have enough money for what you want to end up with. | |
| Subject: Re: pulley help Sat Apr 26, 2008 7:44 am | |
| Sorry, for some reason I was thinking S2 meant Stage 2 heads. Are you just going for a stock series II build? | |
| Subject: Re: pulley help Sun Apr 27, 2008 8:26 am | |
- Sorry, for some reason I was thinking S2 meant Stage 2 heads. Are you just going for a stock series II build?
for right now, i dont have that much cash flow. so im going to just enjoy the S2 do some light mods full exhaust, intake pulley shit like that | |
| Subject: Re: pulley help | |
| pulley help | |
