 FAQ: Automatic Leveling Control (ALC) Concerns
Go to page : Previous  1, 2, 3, 4, 5, 6 ... 11 ... 18  Next
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Fri Mar 21, 2008 3:15 pm
BTW, I usually have plenty of the 1/8" OD black air line in stock, that this coupler is used with.
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Fri Mar 21, 2008 3:16 pm
Yes, only one more needed (one for each side). I managed to squish both of them somehow, but one lets a little air through. It's no big deal, except my driver's side is 1" higher than my passenger side rear!
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Fri Mar 21, 2008 4:15 pm
On the way!
Merit : 83
PostSubject: Electronic Leveling Control (ELC) Problem   Sun Mar 23, 2008 9:51 am
Where's the fuse for the air ride compressor? I asked on regalgs.org a looong time ago and didn't get around to pulling it. Now I can't find the thread. What a dumbass. I'll do it this time lol
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Sun Mar 23, 2008 10:27 am
my 96 manual shows it is fuse #2 under the rear seat. labeled ELC (electronic level control)
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Wed Apr 02, 2008 1:17 am
Dave, I received both fittings. Thanks again, you're a life saver!
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Wed Apr 02, 2008 8:26 am
Happy to be of service. smile
Merit : 83
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Sat Apr 12, 2008 3:06 pm
Help out an idiot, which one is #2?
'96reese
PostSubject: rear air ride problem   Sun Apr 27, 2008 5:15 pm
the problem is the title. my air shocks are not inflating. sumtime this week im gonna replace all the air lines and the air drier and see if that works. i know the air compressor works, but i didnt test it to see if it leaks before i reinstalled it. if it is a leak in the compressor assembly.....does anyone know if you can take the compressor from a new car and clip the connectors to hook it up to our cars??? and secondly has anyone tried to open the cylinder head or compressor to try and rebuild it???
i'll let you know what happens when i replace the air lines. i hav to fix this problem before i put 22 on my baby!!!!!!!!
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Sun Apr 27, 2008 5:54 pm
before you change out all the air lines check the schocks themselves. maybe there is the prob?
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Sun Apr 27, 2008 10:06 pm
Is the compressor running? All the time? Does it ever shut off? How do you know the compressor works if the shocks are not inflating?
These systems are really simple. Shouldn't be tough to diagnose. Usually it is the shocks being old and leaking, but if that's the case the compressor should be running nearly all the time.
96RIVMANN
PostSubject: ELC problems!   Tue Jun 03, 2008 1:16 am
So I was sick of hearing the elc pump run and run everytime I would turn the car on and decided to look into it this past weekend. The pump barley puts out any psi and I am wanting to convert the shocks over to just a manual process but was wondering how I would go about it? I have monroe's installed and want to put some type of a fitting on the shocks and run airlines to a schrader valve. Has anyone done this or somthing similar. Thanks
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Tue Jun 03, 2008 1:26 am
http://rivperformance.editboard.com/suspension-handling-f6/write-up-rear-shock-air-compressor-elc-t1280.htm
yes, its been done. The problem is that I believe the shocks will eventually will leak air. The leveling system and pump corrected this by re-adjusting the height whenever you start the car.
my pump ran until it timed out, and I realized that was due to my shocks being blown out and not holding any pressure. I replaced my pump with an switch controlled manual airpump in the trunk for my airshocks.
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Tue Jun 03, 2008 12:51 pm
Does your pump run all the time? It's supposed to run for a few seconds right after startup, that's part of a normal system check.
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Tue Jun 03, 2008 6:40 pm
Mine ran all the time when I had a leaking rear shock. The pump eventually burned out.
96RIVMANN
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Tue Jun 03, 2008 7:03 pm
The shocks are only about 6 months old so I think I can rule them out. It just doesn't seem to be producing enough air to maintain constant pressure. It runs everytime I turn the car off then on again. It might be the lines were they connect but I just installed new o rings on each end. The pump runs until it times out. dreww, how did you connect the air lines to the shocks?
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Tue Jun 03, 2008 7:58 pm
My shocks were 6 weeks old when they leaked. It was a damaged air connection where it meets the shock. I needed to buy new connection lines and fittings, not much $ at all.
96RIVMANN
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Tue Jun 03, 2008 9:06 pm
Where did you pick up the lines and fittings?
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Tue Jun 03, 2008 11:27 pm
exactly, mine lasted about 1-2 yrs max until they went. rolleyes
these got about a year on them.
Merit : 133
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Wed Jun 04, 2008 12:17 am
You may not want to do this - but - when I replaced my air shocks I noticed pump ran awful long - so I took the air lines off the shocks and jacked the rear up so the wheels hang down. In the service manual it shows where you can use a floor jack on one of the chassis members to jack up the back.
Anyway, the point is to fill the shockes with air, attach the fittings, then lower the car and turn the key to 'on' - the system will then bleed out air to the right level, and if there are no leaks will not have to work so hard to pump up shocks.
if you do need replacement lines, try Ed Morad or actually, the tubing assembly is $13.60 from gmpartsdirect.com, I think it is p/n 25632302. Double check with them before ordering.
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Wed Jun 04, 2008 12:16 pm
What do you mean, runs until it times out? How long does it stay running for?
96RIVMANN
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Wed Jun 04, 2008 3:50 pm
I think it runs for about 5 minutes then shuts itself off. The problem that I am having is that when it is done running there is no air in the shocks so I think my pumps shot. Maybe I will go the manual route with the Monroe kit.
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Wed Jun 04, 2008 11:18 pm
for what its worth, my pump put out very little pressure too. But the sound of it never changed so Im pretty sure you dont need alot of pressure. The point is to slowly inflate them until level.
my aftermarket airpump is alot stronger (and a decade newer), but also louder. You know how Buick is about noise.
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Thu Jun 05, 2008 9:10 am
agree The air lines are very narrow so that it requires only a little bit of air to inflate the shocks. I doubt the pump needs to move much air at all.
PostSubject: Re: FAQ: Automatic Leveling Control (ALC) Concerns   Thu Jun 05, 2008 9:28 am
Definitely a low volume/low pressure application. I'm surprised the oem compressor isn't even quieter. I replaced my original shocks with new Monroes last year and hardly EVER hear it run anymore. Probably because it no longer runs when I start up or shut down, since the new Monroes are holding their air.
Page 5 of 18Go to page : Previous  1, 2, 3, 4, 5, 6 ... 11 ... 18  Next
