| FAQ: Supercharger Noise (Bad Coupler) | |
+6497rivman1 AlienShoe charlieRobinson th3fr4nchi5e LaFlare matt270avian designer1962 Z-type highwaywarrior The Roadmaster crstump RidzRiv GEAREDUP robotennis61 ejeraser Cmurphy Lenrapkins BMD 97 park ave Abaddon Natesriv Eldo LARRY70GS Hometown Hero crosss3 T Riley rivman96 Rickw curious riv captshiner gotboost? lyonsperformance manofmany riviera2454 Lucas ibmoses TonySmooth89 1wickedninja Karma Chicken albertj baynes72 RhinoFLA ZEP 1998 Riv sburch23 overownt deekster_caddy IBx1 ewolfe0050 Buapo dreww Shintsu BillBoost37 Jason shrek90 Mr.Riviera oldsman105 turtleman urbsnspices 98riv AA NO 4 EVR robertwolf86 68 posters |
gotboost? Amateur
Name : Brandon Age : 37 Location : Michigan Joined : 2008-11-12 Post Count : 25 Merit : 0
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Sun Nov 30, 2008 11:45 pm | |
| It's strange because it only does it when the motor is fully warmed up and at idle. It is a grinding type clunking noise. Has anyone had this before, the riv just went past 149xxx miles. I am also getting a lot of pully noise that I beleive is coming from the water pump. THanks. | |
curious riv Addict
Name : Chris Age : 44 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Mon Dec 01, 2008 12:03 am | |
| Im sure that mine needs a new coupler but it (sometimes)only rattles when cold at idle. nevr when warm at idle or any time else | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Mon Dec 01, 2008 12:31 am | |
| Alternator bearings will sound like that when warmed / hot when they are worn out. Next time you hear it put your hand on either end of alternator and see if it very hot to the touch. Should not be. Doing this with engine running and bad bearings you can almost feel the bearings growling in the case. Worth looking at before you start condemning the supercharger. Also, put your hand on the end of supercharger snout while running and see if you can feel what your hearing. Just be careful of rotating pulleys and belts. An inexpensive mechanics stethoscope can be helpful sometimes if you you know what your listening for otherwise you'll just hear a bunch of magnified noise. If you know you have a bad water pump, while changing it out check the play on all other rotating pulleys as well. It's worth the time and money to replace any questionable pulleys or tensioners while your in there. Noises from that side of the engine can be difficult to pinpoint because of all the different rotating components. Have someone else that is mechanically inclined also listen. Two sets of ears can be better than one sometimes. Good Luck. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Mon Dec 01, 2008 1:34 am | |
| Our idler and tensioner pulleys are known to fail at half your mileage. Might be a good time to change your belts, too. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
gotboost? Amateur
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Mon Dec 01, 2008 2:04 am | |
| Belts have been changed. I put my hand on the topside of the supercharger and felt the "noise" if that makes sence. I will have my mechanic check it out while he is doing the hazard switch. Thanks guys. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Mon Dec 01, 2008 9:24 am | |
| FYI most mechanics just say 'you need a rebuilt supercharger' when in reality you only need the coupler replaced. Just make sure you and he are aware of it. | |
gotboost? Amateur
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Tue Dec 02, 2008 10:42 pm | |
| Hey Derek, thanks man. I know mechanics don't really like to fix a little thing, they would rather get their hours in by replacing the whole assembly. I will pull the belts off tomorrow night and check and see what is causing the noise. | |
Karma Aficionado
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Wed Dec 03, 2008 9:21 am | |
| another good way to zero in on the coupler if thats whats making the sound is to use a "poor mans auto stethoscope", a paper towel tube held to your ear.. good for closing in on engine sounds.... _________________ | |
captshiner Junkie
Name : Andrew Age : 37 Location : Cincinnati, OH Joined : 2008-07-23 Post Count : 756 Merit : -1
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Wed Dec 03, 2008 3:45 pm | |
| Another way is to use a long screwdriver with the head on the subject and the handle on your ear. The coupler is at the base of the stount. | |
gotboost? Amateur
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 05, 2008 2:29 am | |
| what types of noise will the coupler make if its bad. It sounds like something is almost clunking around in the s/c... | |
ewolfe0050 Aficionado
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 05, 2008 2:38 am | |
| a rattling sound like rocks tumbling around... a coupler cost $25-$30 at ZZP, Intense, WbodyStore, etc and is fairly easy to replace. When mine went out at 140k mi, it was most noticable when cold and would go away after warming up and at speed. | |
gotboost? Amateur
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 05, 2008 11:44 am | |
| Yeah, it is def my coupler. I will have to order one. If nothing else, now would be a good time to replace the s/c fluid. Thanks guys. | |
rivman96 Enthusiast
Name : Cameron Age : 35 Location : Asheville, NC Joined : 2008-09-15 Post Count : 100 Merit : 1
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Mon Oct 26, 2009 8:37 pm | |
| I have a noise coming from my supercharger as well but I only hear it when I turn off the car. Is this likely my coupler? | |
T Riley Guru
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Mon Oct 26, 2009 8:38 pm | |
| - rivman96 wrote:
- I have a noise coming from my supercharger as well but I only hear it when I turn off the car. Is this likely my coupler?
Yes | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Mon Oct 26, 2009 11:57 pm | |
That's almost exactly the symptom I had too. I could hear it a little bit at idle, but when I turned off the ignition it was very noticeable as the engine came to a stop. New coupler from ZZP and it's been purring perfectly for 2 yrs now. | |
crosss3 Amateur
Name : Steve Joined : 2009-11-18 Post Count : 38 Merit : 0
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Thu Dec 03, 2009 9:21 am | |
| Quick question guys. While stopped at a light or at idle I am hearing what sounds like a golf ball hitting the roof coming from under the hood. Any idea what this might be? When I bought the car I could hear a small growling noise coming from the alternator. I had the dealer look into it and they said they ran a line through the alternator and it's putting out full power. Let me know. Thanks. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Thu Dec 03, 2009 9:26 am | |
| The most common reason for this "marbles in a can" sound is a worn supercharger coupler, but it can come from other sources. You may want to loosen the SC belt, then move the SC pulley back and forth to see if there's any play. Read through this thread for more info. Good luck! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Thu Dec 03, 2009 3:55 pm | |
| Common source for 'marbles in a can' sound is the water pump. As often as not they will get a bit noisy before they fail.
Also look for weak/broken rubber in the motor mounts and loose metal shields on engine and exhaust. Also look at the palstic engine "sight cover" to see if the little rectangular cup at the back is snug against the bracket on the engine; if not it may knock around a little.
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 18, 2009 6:43 pm | |
| Do you and any other people here experience that mechanical noise emanating from the intake / supercharger when the engine is cold. I've been hearing it for a while but didn't correlate it to the 3.4 pulley drop I made after putting on the rockers. I wasn't sure if it was a supercharger making the noise it will make at 100,000 miles and a coupler with about 1/8" play or not. Figured I'd live with the noise until I put a New Gen 5 on it next year. But if this noise is normal then I'm relieved. It goes away shortly after the SC warms up, and before the engine is up to normal operating temp. I had gutted the air cleaner housing a long time ago and didn't get this noise then.
Hometown Hero Junkie
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 18, 2009 6:46 pm | |
| Whens the last time you changed out your SC oil? | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 18, 2009 6:47 pm | |
| Less than 10,000 miles ago. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 18, 2009 6:53 pm | |
| Hmm, this growl, is it a humming noise or grinding? I have heard the bearings do make a grinding noise in the snout when they start to go, also like you stated the coupler is a common issue. But that doesn't sound like the problem here. I woodn't lose to much sleep over it if everything is working fine. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 18, 2009 6:59 pm | |
| Yeh, I'm not losing sleep or getting too excited about it. It was just the first time I heard someone else mention noise from the supercharger, with a gutted airbox mention the type of noise I am hearing. I had a certain noise from just gutting the airbox that's expected, now I hear the SC make noise when cold for a short time and then goes away. Like I said it will dissipate before the engine comes up to 1/4 it's normal temp. Generally by the time the HVAC blower starts to come on in the extreme cold weather we have been having.
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 18, 2009 7:00 pm | |
| - Rickw wrote:
- Eldo wrote:
- And you know what, except perhaps for the cold-supercharger-growl in the morning,
Do you and any other people here experience that mechanical noise emanating from the intake / supercharger when the engine is cold. I've been hearing it for a while but didn't correlate it to the 3.4 pulley drop I made after putting on the rockers. I wasn't sure if it was a supercharger making the noise it will make at 100,000 miles and a coupler with about 1/8" play or not. Figured I'd live with the noise until I put a New Gen 5 on it next year. But if this noise is normal then I'm relieved. It goes away shortly after the SC warms up, and before the engine is up to normal operating temp. I had gutted the air cleaner housing a long time ago and didn't get this noise then. I know exactly what you mean Rick. I've always noticed that when my engine is cold. I'm not sure it is the supercharger. Might it be the Idle air control? | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) Fri Dec 18, 2009 7:05 pm | |
| Good point, I wasn't sure if it was the SC while in Bypass mode or something else. All I know is that became much more noticeable this year and that is when I did the 1.9:1 rocker change as well as the 3.4" pulley change. | |
| Subject: Re: FAQ: Supercharger Noise (Bad Coupler) | |
