 Oil Pump pressure info wanted ?????
3 posters
roadstar99
Oil Pump pressure info wanted ????? Empty
PostSubject: Oil Pump pressure info wanted ?????   Oil Pump pressure info wanted ????? EmptyWed May 07, 2008 5:23 pm
1995 3.8 Super I finaly have about 1000 miles on my NEW engine and with warm weather getting here. It seems that my oil pressure at idle is getting down to 25 - 30 PSI in gear as soon as I start moving she goes right up to sixty. Is idle pressure usally that low. It is a NEW engine and NRW pump high volume. I will check Mitchell on Demand when I get to work but I was wondering what other guys are seeing in there cars
Merit : 251
PostSubject: Re: Oil Pump pressure info wanted ?????   Oil Pump pressure info wanted ????? EmptyWed May 07, 2008 5:39 pm
Gene, we'll assume this is a '99 supercharged Riviera?
roadstar99
PostSubject: Re: Oil Pump pressure info wanted ?????   Oil Pump pressure info wanted ????? EmptyWed May 07, 2008 5:42 pm
Sorry 1995
Fastbuick95
Fastbuick95
PostSubject: Re: Oil Pump pressure info wanted ?????   Oil Pump pressure info wanted ????? EmptyWed Mar 16, 2011 11:35 pm
That is plenty of oil pressure, as long as you have over 15-20 at idle you will be set, 60 is a very good pressure when under load so you should have nothing to worry about. In warmer weather I see between 20-30 at idle and 50-65 under acceleration so you are fine =)
Fastbuick95
Fastbuick95
PostSubject: Re: Oil Pump pressure info wanted ?????   Oil Pump pressure info wanted ????? EmptyWed Mar 16, 2011 11:37 pm
Hmm, guess I should have realized this was over two years ago...SORRY lol
» Fuel pressure and fuel pump
» FAQ: New Riviera Buyer Questions
» Auto level system pump replaced with after market pump
» A/C pressure?
» fuel pressure?
