| Planning a 4T60E to 4T65E conversion. | |
oldsman105 Junkie
| Subject: Planning a 4T60E to 4T65E conversion. Fri Dec 28, 2007 9:44 am | |
| Well my current trans is screaming uncle after I got my tuner.... " back story" What was funny is after this race I went to give another ricer in a eclipse a eaton salute . The transmission went from 2nd to 1st and slipped all the way to the Rev limiter. DAMN! Drove home that was the end of my night. This was a couple of weeks ago. I had the transmission shiftpoints at 5800 RPMs. I have lowered them to 5500 RPM since and threw in a bottle of lucas so now everything is Ok. So after talking to Billboost37. We decided I should upgrade to a 4T65E trans.Yesturday he put a down payment on a 4T65E-HD out of a 98 Regal. So now it is time to . We will keep this updated with new info as it comes along. P.S. anyone got 96 or 97 Service manuals for sale | |
BillBoost37 Junkie
| Subject: Re: Planning a 4T60E to 4T65E conversion. Mon Dec 31, 2007 2:41 pm | |
| Anyone ever found the firewall wiring harness from inside? I hear the pcm is inside the riv instead of in the engine bay. | |
BillBoost37 Junkie
| Subject: Re: Planning a 4T60E to 4T65E conversion. Mon Dec 31, 2007 5:42 pm | |
oldsman105 Junkie
| Subject: Re: Planning a 4T60E to 4T65E conversion. Sat Jan 12, 2008 10:39 pm | |
| Bump...
Picked up PCM and transmisson harness from case to firewall.
Hope to have the TC ordered soon . | |
'96reese Fanatic
| Subject: Re: Planning a 4T60E to 4T65E conversion. Sat Jan 12, 2008 10:53 pm | |
| i have a mitchell disk for a '96 riv, it only works pc not apple. the pcm i believe is in the inside on the passenger side. you have to take the black panel off. let me know how the swap goes. i wanna switch non hd tranny to a hd tranny. check out zzperformance. com and 3800performance.com they have race trannies.com | |
| Subject: Re: Planning a 4T60E to 4T65E conversion. Sat Jan 12, 2008 11:38 pm | |
| I have the full factory service manuals for the '98. The transmission is most likely the same for '97 You are close by, just LMK if you want to use it | |
BillBoost37 Junkie
| Subject: Re: Planning a 4T60E to 4T65E conversion. Mon Jan 14, 2008 8:59 am | |
| Close.. you bet. He'll be doing the swap in Enfield Ct and IIRC on 1/16 he'll be up toward Boston.
Although I figure all we really need is to confirm the pins from the trans connector to the PCM connector/pin location. I am assuming GM kept them the same for all 3.8's in 97. | |
| Subject: Re: Planning a 4T60E to 4T65E conversion. Mon Jan 14, 2008 9:06 am | |
| There is a full breakdown of the 4T65-E wiring harness connector in the FSM. I skimmed the transmission pages last night (hundreds of pages about the 4T65-E I did not have time to read them all). Every connector, each pinout, trouble code, ... well just everything is covered in there. It's very extensive.
I think somebody has hosted the GM FSM online thingy somewhere, that might have the pinouts in it. Not sure how detailed their online service manuals are. I'll see if I can find it. | |
matt270avian Expert
| Subject: Re: Planning a 4T60E to 4T65E conversion. Fri Apr 10, 2015 8:39 pm | |
| So has anyone actually done this yet? | |
Sir Psycho Sexy Junkie
| Subject: Re: Planning a 4T60E to 4T65E conversion. Sun Apr 12, 2015 7:39 pm | |
| AA, we need a zombie or mummy emoji for thread resurrections like this! | |
matt270avian Expert
| Subject: Re: Planning a 4T60E to 4T65E conversion. Sun Apr 12, 2015 7:58 pm | |
| Subject: Re: Planning a 4T60E to 4T65E conversion. Sun Apr 12, 2015 7:59 pm | |
| Subject: Re: Planning a 4T60E to 4T65E conversion. | |
