 LIM coolant elbow!
96rivie
PostSubject: Re: LIM coolant elbow!   Thu Dec 20, 2012 5:25 pm
Just did mine on the 96'. It took 15mm for the belt. Three 13mm bolts for the alt. Two 13mm bolts for the bracket, and some pulling and pushing, but I finally got it in the hole. Filled with antifreeze, purged system. The old part had broke of at the o-rings on both ends.
PostSubject: Re: LIM coolant elbow!   Thu Dec 20, 2012 7:04 pm
Hell yeah! High fives all around! cheers
Natesriv
PostSubject: Re: LIM coolant elbow!   Fri Dec 21, 2012 2:31 pm
that black plastic doesn't hold up to heat very well (over the years)
On my 95 contour SE...the waterpump impeller was black plastic like that...and it broke...thankfully the Contour forums helped...
Contour..was a good looking car, but JUNK...
sorry, off subject smile
96rivie
PostSubject: Re: LIM coolant elbow!   Sat Dec 29, 2012 12:59 pm
yeah...I should of changed stat over while messing around headshot
PostSubject: Re: LIM coolant elbow!   Mon Jan 07, 2013 5:12 pm
Had to change the coolant elbow for the second time because of the faulty o-rings that flatten on the Dorman 47065. Went with an AC Delco from the dealership this time. Here is the part number 24503423. More expensive than the Dorman, but it is worth it if it doesn't have the same problem.
PostSubject: Re: LIM coolant elbow!   Mon Jan 07, 2013 5:27 pm
I recommend the aluminum elbows ZZP sells. I think Intense has the same ones. Perfect fit and no leaks.
PostSubject: Re: LIM coolant elbow!   Sat Mar 30, 2013 11:43 pm
just did this and all was well till the housing neck broke off in my water pump! temp fix of rtv to last for two weeks ugh then new pump and tensioner and hoses for me. come on friday the 12th!
crstump
PostSubject: aluminum coolent elbows plus another question   Wed Apr 24, 2013 11:11 pm
i bought some aluminum coolent elbows and not goin to put it on until i have other goodys to put on, but has anybody tried these? if so they work well? and i was researching and found out that cant put a manual in these but has anyone ever though about paddle shifters? my trans is gettin worse, sometimes it hesitates to go to first when i mash the gas and tachs out a couple times b4 i catch it. then when it switchs to 2nd its rough ( already check the fluid) actually changed the fluid and filter about 2000 miles ago... and also when i first start it in the morning and its still idleing high and put it in reverse it does some horrible jerking. then put it into drive it does another jerk, but once the idle is at normal, it doesnt do it.
PostSubject: Re: LIM coolant elbow!   Thu Apr 25, 2013 2:52 pm
I used aluminum elbows on the last two 3800s I've worked on and they've been great so far.
bmcd9179
PostSubject: Elbow leak in manifold   Tue Dec 10, 2013 5:57 pm
Hi guys, my coolant elbow on the intake manifold, near the alternator is leaking when the car is cold, anyone know how I can fix this? I was thinking of puting some rtv around it but anything else without to much labor would be nice?
96_Juggernaut
Name : Todd Balestrini
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 6:01 pm
I have the same leak, however mine is a VERY small leak. Did you upgrade to the aluminum elbow? Either way I have tried putting RTV on and it did not help, I think the last option is to take it out and re-install it with RTV on the o'ring itself.
bmcd9179
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 6:04 pm
That's stupid, I just did my intake manifold gaskets, damn, how about that weld stuff at Walmart? JB weld I think it is
bmcd9179
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 6:06 pm
Or is there a easier way to get the elbo off without taking of the manifold, I'm new at these engines.
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 6:39 pm
replace the elbow. If I did this solo with no help, it means ANYONE can do it.
CAUSE IM A ULTRA NOOB.
96_Juggernaut
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 7:24 pm
You should be able to take just the alternator bracket off and get it off that way. But you will also need to drain the coolant.
bmcd9179
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 8:07 pm
Yah thanks guys! And I do everything solo, have to
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 8:44 pm
Todd , is that a Maserati Forged decal ?
96_Juggernaut
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 8:56 pm
Lol I never looked at it like that. No it's a decal from http://www.forged.com/  It's a clothing store founded by a Navy Seal ( hence the trident). From their site:
"Forgedฎ was born on the Battlefield of Iraq in late 2006 by its co-founder and CEO. During an intense fire fight in the streets of Ramadi, Iraq, a teammate and close friend sustained catastrophic injuries that left massive burns, and later led to the amputation of one of his limbs. When the team returned stateside, Forgedฎ and a few teammates decided to create a tribute shirt to honor their wounded Brother, and to raise some much needed money to help with his recovery. This is where it all began… "
PostSubject: Re: LIM coolant elbow!   Tue Dec 10, 2013 9:00 pm
But the emblem.....haha....Maserati....I LIKE.
brutusk1
PostSubject: Re: LIM coolant elbow!   Tue Apr 29, 2014 3:44 pm
Howdy Folks,
The Dorman ("Help!") black plastic coolant elbow that I installed no more than 5000 miles ago failed and started leaking recently.  The elbow cost about $7 but the coolant that was lost probably cost twice that - and then there was the time to do the replacement.
I replaced it with a Dorman aluminum elbow which looks better anyway.
I inspected the failed plastic elbow to find out why it failed so soon and discovered that the O-ring groove has a square profile and it cracked right at the inner corner of the groove which obviously provides a feature to concentrate stress due to thermal expansion and/or vibration.
If I had a plastic elbow that I was thinking of installing, I wouldn't.  Not unless it was an OEM part and the O-ring groove was radiused and not square like the Dorman.  The original part lasted almost 200k miles so it wasn't a bad part.
The aluminum Dorman part had a radiused groove and I suspect it will work just fine. That's my two cents.
PostSubject: Re: LIM coolant elbow!   Tue Apr 29, 2014 3:58 pm
Nice catch, and good report. It goes to show how plastics can vary in quality. The Help! products are fine for some things, but don't trust them for critical areas like this. I paid a little but more for the OEM plastic version and haven't seen any leaks for 35k miles. My original lasted 246k and never failed - I broke it removing the manifold. The aluminum versions look nice. If my plastic version ever breaks, that's what I'll be getting!
3.4" pulley • AL104 plugs • 180บ t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails
PostSubject: Re: LIM coolant elbow!   Tue Apr 29, 2014 4:12 pm
I have personally seen 2 Dorman coolant elbows fail (one catastrophically - split open at the seam) and read about many others. Now I will only use the OEM plastic or aftermarket aluminum version.
Please please please don't buy this part from Dorman (Help!). It's total junk.
bunchabuix
PostSubject: '97 SC Coolant Leak @ Plastic Bypass Pipe, Intake Manifold/Htr. Hoses    Thu Feb 12, 2015 7:24 pm
I checked the Write-Ups, I found info.changing the water pump, great photo of the bypass pipe! Nothing on the bypass pipe.
Has anyone changed this pipe, any shortcuts, what about availability of the pipe?
Many thanks for any assistance!
Bunchabuix
PostSubject: Re: LIM coolant elbow!   Fri Feb 13, 2015 5:57 pm
They are the coolant elbows you're talking about. Try and get the aluminum coolant elbows. They should be available at you're parts store. There's a write up on here somewhere just use the search feature. You need to remove the alternator and belt tensioner assembly. It might be a good time to replace the belt tensioner if it looks crappy. I think the coolant elbow is included with the tensioner.
KnottyEagle
PostSubject: Re: LIM coolant elbow!   Fri Feb 13, 2015 7:34 pm
I'd like to say a word of caution about removing the belt tensioner assembly. When my uncle and I were doing my lower intake manifold gasket, we forgot to put the coolant elbow in the lower intake manifold before setting it in place and tightening everything down. Instead of taking the lower intake manifold off again, we opted to remove the belt tensioner assembly. After double and triple checking for any bolts we might have missed, we attempted to remove the belt tensioner assembly with just our hands and it would not budge! We checked for bolts again and attempted with just our hands to free the belt tensioner assembly. Again, it wouldn't move. We grabbed a rather long pry bar, set it up against something solid and started prying. We could see it finally start to move and then "BANG!!" We removed it, but upon further inspection, the coolant passage built into the belt tensioner assembly actually sheared right off. My guess is that it corroded together and there was nothing we could do about it. Now, I know the ideal fix is to get a new belt tensioner assembly, but we put a dab of RTV around the mating surfaces and I haven't seen any leaks from that area or noticed any ill effects. I do plan to replace it soon, and if I wasn't in a hurry to drive my car again, that's what I would've done the first time around.
LIM coolant elbow!
Page 5 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Pain in crook of elbow
» Coolant Leak
» Elbow Tendinitis (Golfers Elbow) - Any suggestions?
» redarc coolant alarm.
» armwrestling injurys
