 LIM coolant elbow!
PostSubject: Re: LIM coolant elbow!   Sun Dec 09, 2012 8:17 pm
Last time I had one that was broken off I had to go in with a 90 degree pick and scoop the chunks out. A huge PITA. Get yourself a good lit inspection mirror.
Natesriv
PostSubject: Re: LIM coolant elbow!   Mon Dec 10, 2012 12:50 pm
I'd bet that grey comes right out, it's just a silicon I'm sure.
Fun stuff, take off alternator and the tensioner...be ready for a big gush of coolant. But then you can just pop the elbow out,... I'd also take the supercharger belt off the pulley so it's not in your way
good luck!
PostSubject: Re: LIM coolant elbow!   Mon Dec 10, 2012 1:07 pm
Well, my worst fear is that I take it all off and clean that grey putty out and find out that the bore is too big and have to use sealant to make it work.
I am actually considering to just seal over whats there now. The elbow doesn't look bad, just the seals.
PostSubject: Re: LIM coolant elbow!   Mon Dec 10, 2012 1:15 pm
Not a good idea, it'll never hold. There is no pressure on the surfaces of the seal to stop something from leaking by.
I guess it's worth trying, but don't expect it to work.
PostSubject: Re: LIM coolant elbow!   Mon Dec 10, 2012 1:33 pm
Why do you think the hole will be too big? What reason would someone have to alter the diameter?
My guess is, the grey stuff that's there is the result of someone trying exactly what you're thinking about doing - patching the leak from the outside.
PostSubject: Re: LIM coolant elbow!   Mon Dec 10, 2012 2:24 pm
I know what you mean.. but..
Ok, what do you think would happen if I do extract the grey putty stuff and find the bore to be enlarged? Do I try to get a thicker O ring? Do I try to seal it? Either way, my main transport will be out of commission for longer than i'd like. I guess I should prepare with all back ups in mind before starting this, huh?
PostSubject: Re: LIM coolant elbow!   Mon Dec 10, 2012 4:03 pm
I'd think the chances of the bore having been enlarged are about 0.00 %.
PostSubject: Re: LIM coolant elbow!   Mon Dec 10, 2012 5:09 pm
I have an extra LIM I could sell if you get to that point. If someone did actually mess up the hole, I'd consider it damaged, and probably the reason for your leak.
Swapping out the LIM isn't to bad if it came to that, but I don't think it will. Anything is possible, but I agree with Dave - VERY unlikely.
PostSubject: Re: LIM coolant elbow!   Tue Dec 11, 2012 8:36 am
Ok. I will go all the way this weekend. I will definitely get a well lit inspection mirror. Thats for dang sure. Thanks for the pro tips, guys.
Natesriv
PostSubject: Re: LIM coolant elbow!   Tue Dec 11, 2012 3:08 pm
I sure suspect they just gooped around the part and put it in...It's hard to get any room in there to modify.
It's not too bad a job, sloppy, but doable with basic tools.
PostSubject: Re: LIM coolant elbow!   Fri Dec 14, 2012 8:44 pm
I am about to start this job first thing in the A.M. tomorrow. I was thinking about it today. What if that grey sealant stuff falls into the LIM? Am I proverbially FUCKED? Or can I find it floating in the coolant tank or?
PostSubject: Re: LIM coolant elbow!   Fri Dec 14, 2012 11:47 pm
Repeat after me: "I will not fear the 3800 supercharged engine."
You can do this. Take your time.
Go in there and do what you have to. You won't screw it up because you know what you have to do, and you've got a good idea on how to do it. Now, GO AND DO IT.
Don't LET the grey stuff escape into the LIM, and if it does, make sure it's such a small amount that no one will ever know.
Ready. GO!
PostSubject: Re: LIM coolant elbow!   Sat Dec 15, 2012 2:57 pm
Had a late start today... so I might go for it tomorrow.. shut up! you all procrastinate too!
Anyways.. check this out. Robo mentioned this before. Tapping and fitting it with an NPT fitting but, how beautiful is this?!
when we do the swaps we drill and tap that hole and install a 3/4 NPT fitthing and run the hose from that some others have built tabs to hold them in and some others block them off.
I would not recomend the block off we have tested one that was and the intake was almost 60 deg. hotter on that side than the other due to no flow.
you can just see it in this pic. I will say it is not easy to drill and tap because the hole is large almost an 1"
D.
http://www.fiero.nl/forum/Forum2/HTML/117445.html
PostSubject: Re: LIM coolant elbow!   Sat Dec 15, 2012 3:16 pm
That is a beautiful engine, but the NPT thread doesn't add much, IMO. In a fiero, it might make sense for better exhaust and intake routing. For us, I don't see any advantage. The elbow isn't considered a serviceable part. But even so, it's pretty simple to replace - much simpler than drilling and tapping the LIM, which is aluminum, btw. Aluminum threads = soft, easily damaged threads. You could use a steel insert, but you have to ask: why?!!
The plastic elbow works fine the way it is. If you are paranoid, there's an aluminum version. I just don't see the point of altering the LIM for a zero gain. If you just replace the elbow, I doubt you'll never need to worry about it again.
PostSubject: Re: LIM coolant elbow!   Sat Dec 15, 2012 8:00 pm
No one told me I had to get that black bar off the alternator to get the alt off! jeez, what a headache. The old elbows came off with some 'convincing'. It was impossible to get all the grey sealant off so I did my best.
I saw chip marks around the LIM, i'd like to know how that happened. New elbows are in and the alternator is bolted back on. I lost a screw somehow that holds one of the coolant hoses on.. Not sure what I will do about that yet.
Im taking a dinner break now but after I will put the belt back on, fill the coolant, and power her back up. I swear to something if this does not fix my leak!!! Im gonna be PISSED.
that was a lot of work for a noob like me!
PostSubject: Re: LIM coolant elbow!   Sat Dec 15, 2012 10:10 pm
SUCCESS!!!
I found that last coolant hose mount screw inside a socket...
Anyways, I powered her back up. Crossed my fingers, toes, and eyes and turned the ignition!
Let her run for 15 minutes and did not see a leak anywhere!!! YES!
I notice my coolant res tank bubbling. Is that normal? Just air in the lines or what? After 15 minutes or so it did mild out so I'm guessing the air was flushed?
Also noticed that fat rubber tube that goes to radiator (next to intake air tube in the picture below) on the drivers side would collapse sometimes. Never saw it do that before!. Not sure what that was all about but it seems ok?
Anyways, HELL YEAH! NOOB SUCCESS PRIDE! YES! This is the biggest job I've done next to my shocks. Feels good!
PostSubject: Re: LIM coolant elbow!   Sun Dec 16, 2012 9:28 am
The upper radiator hose compressing is not a big deal. Once the system has purged all it's air and is full of coolant it will stop doing that. It won't block flow because it's the upper hose, which forces flow through it when the thermostat is open.
I didn't see you mention bleeding the thermostat housing. You may want to do that next time you warm it up.
PostSubject: Re: LIM coolant elbow!   Sun Dec 16, 2012 2:11 pm
woah, what? Bleed the tstat housing? How/where do I learn to do that? Any links on here?
96rivie
PostSubject: Re: LIM coolant elbow!   Sun Dec 16, 2012 3:43 pm
where are the 3 bolts for the alternater on my 96? what size?, im so confused
PostSubject: Re: LIM coolant elbow!   Sun Dec 16, 2012 4:40 pm
I winged it and unscrewed the screw above the tstat housing. The car was running and I wasnt sure if things were going to explode but I saw just a couple super tiny bubbles and that was it? Guess I got most of the air out last night. Cool.
PostSubject: Re: LIM coolant elbow!   Sun Dec 16, 2012 4:47 pm
it's that easy!
Natesriv
PostSubject: Re: LIM coolant elbow!   Sun Dec 16, 2012 5:38 pm
right by the bottle top in your pic...is the thermostat housing. You'll see a brass screw (flathead) on top of it. Warm up the engine, then when it's running, unscrew that screw a little bit until you see coolant come out (it'll be a small trickle)...then tighten it back up. You just purged the air out of the system at that point.
Easy brother! I just had to replace my elbow too recently (look for me in this post)..it wasn't too bad, but messy!
But it sure is nice to have NO LEAKS isn't it?
Now enjoy the riv!
PostSubject: Re: LIM coolant elbow!   Sun Dec 16, 2012 6:21 pm
Now enjoy the riv!
Got it. Thanks. In other news.. I think the upper manifold gasket is faulty. I am seeing some residue up top there. And goodness, that's a whole super charger removal job and other things I cannot comprehend at my level 3 noob status. dunce
Natesriv
PostSubject: Re: LIM coolant elbow!   Mon Dec 17, 2012 10:20 am
actually I posted on that a few years ago...you'll want gaskets and a new s/c gasket. Not really too hard... get new rubber gaskets for the fuel injectors...
PostSubject: Re: LIM coolant elbow!   Mon Dec 17, 2012 2:03 pm
Ha! Easy for you to say! I am getting the shakes just thinking about putting a new SC hub and MPS on. I cannot imagine actually take the blower off the manifold!!! Seems like brain surgery from where I'm standing! But I am leveling up with each job, so I will get there!
LIM coolant elbow!
» Pain in crook of elbow
» Coolant Leak
» Elbow Tendinitis (Golfers Elbow) - Any suggestions?
» redarc coolant alarm.
» armwrestling injurys
