 PCM and fuse panel
PostSubject: PCM and fuse panel   Sun May 11, 2008 8:33 am
how do i get the PCM, and the fuse box out of a Riviera, i know the pcm is behind the glove box is there a way to take it down with out breaking it. also what should i do about the fuse box?
BillBoost37
Merit : 25
PostSubject: Re: PCM and fuse panel   Mon May 12, 2008 9:30 am
As I recall, pulling the glove box and maybe a kick panel were quick and easy to get at the pcm. I'm unfamiliar with the fuse block.
In your case Corey..changing from 95 to newer..you might have to consider some pcm holder that might be found on the 96+.
PostSubject: Re: PCM and fuse panel   Mon May 12, 2008 9:44 am
theres TWO bolts that hold the pcm up there as i recall..................... just remove stuff and be carefull
PCM and fuse panel
