 Good news!
PostSubject: Good news!   Wed Feb 28, 2007 11:30 pm
so i was at the local club meet and had a friend scan my car several time. one run was 0-75 or 80 (on 30mph roads nervous ) and the few other runs wer from a roll to about 50 or 60mph.
i dont have the data but it was 65* out and i only peaked 2.4* KR at WOT happy most spikes were under 2*. with my mods i am very impressed that i am not seeing more knock than that. once i get my DP installed i shouldn't see ANY knock. but i dont plan on droping past the 3.4 without first getting a tuner.
i plan to scan again during the day when it is hot and see where i stand.
btw he has a 95 riv and a 99 silver arrow...he will be joining soon. thumbsup
PostSubject: Re: Good news!   Thu Mar 01, 2007 10:40 am
Cool! I think I mentioned in a previous thread that your KR situation may not be as bad as you think. smile Glad to hear that's the case.
A couple things for next time you scan: 1) Log a scan when downshifting (WOT) from a 45-55 mph roll. The downshift can cause a higher spike of KR. Good to know what that number is... 2) Try to run up past 100 mph if you can do it safely. At the track, I usually run through 1st gear with near 0 KR, then if I see any at all it will be a small blip right after the shift into 2nd, and then again at the top of 2nd above 80 mph it will start building again. Nothing serious, but I know where my problem areas are. Your problem areas could be in different areas, but good to know where they lie.
PostSubject: Re: Good news!   Thu Mar 01, 2007 1:03 pm
but if it shows KR at a shift or a double downshift then wouldnt it be false knock from the tranny?
PostSubject: Re: Good news!   Thu Mar 01, 2007 1:12 pm
My worst KR is at the top of 2nd gear. Haven't taken it up to the top of third yet smile
PostSubject: Re: Good news!   Thu Mar 01, 2007 1:23 pm
quote: "but if it shows KR at a shift or a double downshift then wouldnt it be false knock from the tranny?"
Possible I guess on the downshift, but I believe the blip after a WOT upshift is real. At lower RPM, there is more load put on the engine while accelerating, so I believe it tends to knock more. I've seen KR in cruise at 1700 RPM while going up a hill.
PostSubject: Re: Good news!   Wed Mar 07, 2007 11:09 am
Good news!
