| FAQ: Riviera Hoods | |
+17IBx1 robotennis61 Z-type Riv95SC Andysdorm Jason TType_Riviera T Riley TonySmooth89 98riv 1998 Riv jax95riv palermocorey90 99Rivman gosloriv AA Mr.Riviera 21 posters |
jax95riv Aficionado
| Subject: Re: FAQ: Riviera Hoods Fri Jan 11, 2008 5:22 pm | |
| That does look cool, but I bet you can fry up some bacon in the summer time! | |
T Riley Guru
| Subject: Re: FAQ: Riviera Hoods Sat Jan 12, 2008 12:10 pm | |
| - jax95riv wrote:
- That does look cool, but I bet you can fry up some bacon in the summer time!
wow if we ever have a riv meet, we wont need to worry about a grill........ | |
palermocorey90 Expert
| Subject: COWL HOOD update with pics now Fri Jan 18, 2008 6:47 pm | |
| http://www.e-bodyparts.com/Car-Hoods/Product-Pages/TMCH-95.htm ooo my word im jealous. time for me to pull out the fiberglass and body filler and the plasma cutter i just pulled out the CS3 for this and the paint scheme i like
T Riley Guru
| Subject: Re: FAQ: Riviera Hoods Fri Jan 18, 2008 9:42 pm | |
| ill do it to urs give me 500 bucks and i will even make you a fancy fiberglass one | |
T Riley Guru
| Subject: Re: FAQ: Riviera Hoods Fri Jan 18, 2008 10:44 pm | |
| - palermocorey90 wrote:
- ill do it to urs give me 500 bucks and i will even make you a fancy fiberglass one
NO thanks man im still waiting for those top secret bumpers to come out | |
| Subject: Re: FAQ: Riviera Hoods Sat Jan 19, 2008 8:54 am | |
| there coming along havent worked on it in like 3 weeks tho | |
TType_Riviera Fanatic
| Subject: Re: FAQ: Riviera Hoods Sat Jan 19, 2008 12:55 pm | |
| do the hoods come with the matching mullet? | |
Jason Aficionado
| Subject: Re: FAQ: Riviera Hoods Sat Jan 19, 2008 1:18 pm | |
| I'd have to say no on a cowl hood. A subtle dual scoop hood, if well made, would look nice though | |
| Subject: Re: FAQ: Riviera Hoods Sat Jan 19, 2008 4:14 pm | |
| im talkin joe dirt style...LOL | |
| Subject: Re: FAQ: Riviera Hoods Sat Jan 19, 2008 5:01 pm | |
| keep that skoal baby even tho im a Copenhagen kinda guy | |
| Subject: Re: FAQ: Riviera Hoods Sun Jan 20, 2008 12:36 am | |
| Subject: Re: FAQ: Riviera Hoods Mon Jan 21, 2008 4:21 pm | |
Andysdorm Aficionado
Name : Andrew Age : 39 Location : Worcester, MA Joined : 2007-01-17 Post Count : 1394 Merit : 6
| Subject: Re: FAQ: Riviera Hoods Mon Jan 21, 2008 5:26 pm | |
| could you do another with the black/red combo but stop the red where the front bumper trim pieces end?
I think it would give it a sharp look. | |
| Subject: Re: FAQ: Riviera Hoods Mon Jan 21, 2008 5:33 pm | |
Riv95SC Enthusiast
Name : Riv95SC Location : Nashville, TN Joined : 2010-05-30 Post Count : 115 Merit : 6
| Subject: Deterioration of aluminum hoods? Wed May 30, 2012 11:59 pm | |
| Has anybody ever had their aluminum hood (95-99) deteriorate? I haven't seen any signs on mine, but I was surprised to run across a series of complaints on another board about Ford aluminum hoods "oxidizing" to the point of perforation.
I would have thought that was impossible, since aluminum doesn't rust (which is another name for oxidization, if my high school chemistry serves). Does this ever happen to Rivs? (Hope not!!)
Z-type Aficionado
| Subject: Re: FAQ: Riviera Hoods Thu May 31, 2012 12:10 am | |
| When I got my '95 some years ago, small areas around the grille were starting to 'bubble', or oxidize. My 2000 SSEi's front hood lip was really bad when I got it. Common problem for the Bonne's, the Riv's aren't as bad, but it can happen. I've never personally heard of them completely 'rusting' through though! | |
| Subject: Re: FAQ: Riviera Hoods Thu May 31, 2012 12:11 am | |
| It's a Ford! what ya expect!? It can happen.If the elements and grime chemicles and what not are allowed to live under say..peeling paint, then yes. | |
| Subject: Re: FAQ: Riviera Hoods Thu May 31, 2012 12:36 am | |
| Aluminum does oxidize (rust), but it's different than steel in a couple ways. First, we don't see aluminum oxidation as easily, because it's metallic white in color, not red or brown. This makes it much less noticeable. Second, aluminum's oxidization forms a protective barrier, like some forms of stainless steel, in that the rust actually prevents further corrosion (passivation phenomena).
In the case of the Ford's hood oxidizing all the way through, it may have been formed from a type of aluminum alloy, some of which are vulnerable to attack from oxidation. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
IBx1 Expert
| Subject: Re: FAQ: Riviera Hoods Thu May 31, 2012 7:28 am | |
| Aluminum oxide: | |
96riv Fanatic
| Subject: Re: FAQ: Riviera Hoods Thu May 31, 2012 9:27 am | |
| No rust here in Phoenix, just lots of paint fading if no covered parking. | |
| Subject: Re: FAQ: Riviera Hoods Thu May 31, 2012 12:14 pm | |
| The biggest problem with our Rivieras is the paint, not the aluminum hood. The paint starts to look like someone took steel wool to the car, then it lifts and flakes off. The only remedy is to take it down to bare metal and refinish it. Doesn't seem to matter how well you take care of the paint. I've seen this on just about every Riviera I've come across. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
IBx1 Expert
| Subject: Re: FAQ: Riviera Hoods Thu May 31, 2012 12:28 pm | |
| - LARRY70GS wrote:
- The biggest problem with our Rivieras is the paint, not the aluminum hood. The paint starts to look like someone took steel wool to the car, then it lifts and flakes off. The only remedy is to take it down to bare metal and refinish it. Doesn't seem to matter how well you take care of the paint. I've seen this on just about every Riviera I've come across.
The primer GM used dried too fast for the paint to adhere properly. The bubbling is a problem with the paint, not so much rust, as you said. | |
| Subject: Re: FAQ: Riviera Hoods | |
