| FAQ: Fuel Door Release Problems | |
+12albertj 97rivsc jax95riv SuperRiv07 Face deekster_caddy 98RIV7777 Chicken 99Rivman RhinoFLA Mr.Riviera 6spd 16 posters |
6spd Amateur
| Subject: FAQ: Fuel Door Release Problems Mon May 12, 2008 4:31 pm | |
| You can hear it try to disengage when you hit the button. All it does is click. Anyone know how to get the door open?
Thanks!! james | |
| Subject: Re: FAQ: Fuel Door Release Problems Mon May 12, 2008 4:38 pm | |
| pull the release in the trunk _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
RhinoFLA Aficionado
| Subject: Re: FAQ: Fuel Door Release Problems Mon May 12, 2008 5:31 pm | |
| This actually just happened to mine.. when I get the chance, i'm going to pull the release mechanism out, because only the little nipple at the end works, not the entire thing,, | |
99Rivman Aficionado
Chicken Aficionado
Name : Mark Age : 57 Location : Montana Joined : 2008-06-13 Post Count : 1296 Merit : 8
| Subject: Re: FAQ: Fuel Door Release Problems Sun Jun 22, 2008 9:43 am | |
| this happened to me too....I adjusted (bent) the catch a bit and it now works again, but I have to hit the release button several times before it pops....some fine tuning (bending) should get it working on the first hit | |
98RIV7777 Fanatic
Name : Anthony Age : 36 Location : Niagara Falls, NY Joined : 2008-06-01 Post Count : 274 Merit : 1
| Subject: Re: FAQ: Fuel Door Release Problems Sun Jun 22, 2008 11:14 am | |
| Ya you just have to play with it aliitle bit, and try using a little silicone spray and that should get it worrking like new again, I know thats what I usually do with mine, because it just seems to gunk up sometimes. | |
| Subject: Re: FAQ: Fuel Door Release Problems Sun Jun 22, 2008 8:19 pm | |
| If you go inside the door there is a little spring that loses it's springyness after 10 years. Pry it back out with a screwdriver and it will work again for a few months, but you can't buy it separately. I bought a new gas door to get a new spring... | |
Face Rookie
Name : Mike Location : Long Island, NY Joined : 2007-04-06 Post Count : 16 Merit : 1
| Subject: Re: FAQ: Fuel Door Release Problems Wed Jul 09, 2008 5:21 pm | |
| I hoped this thread would fix my problem. Well, it appears I may have a bad relay and will have to use the manual release till I fix it. | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Re: FAQ: Fuel Door Release Problems Mon Jul 21, 2008 6:47 pm | |
| that happened to mine also? should I just spray it with wd 40 | |
jax95riv Aficionado
| Subject: Re: FAQ: Fuel Door Release Problems Mon Jul 21, 2008 7:09 pm | |
| - Chicken wrote:
- this happened to me too....I adjusted (bent) the catch a bit and it now works again, but I have to hit the release button several times before it pops....some fine tuning (bending) should get it working on the first hit
Yep. That's what I did too. It works fine now. Every once in a while I'll have to hit it twice. - Quote :
- I hoped this thread would fix my problem. Well, it appears I may have a bad relay and will have to use the manual release till I fix it.
If it's clicking...your relay is working. | |
jax95riv Aficionado
| Subject: Re: FAQ: Fuel Door Release Problems Mon Jul 21, 2008 7:10 pm | |
| - RhinoFLA wrote:
- This actually just happened to mine.. when I get the chance, i'm going to pull the release mechanism out, because only the little nipple at the end works, not the entire thing,,
I haven't looked at it in a while, but I think that's all that does work. At least on mine. | |
SuperRiv07 Addict
| Subject: Re: FAQ: Fuel Door Release Problems Tue Jul 22, 2008 3:44 am | |
| So i sprayed mine down and cleaned it works great | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: FAQ: Fuel Door Release Problems Tue Nov 18, 2008 9:35 am | |
| for some reason now my fuel door release button on the driver door doesn't make that clicking sound. I think it might be because of the cold, it was working perfectly like two days ago but since we dropped to 25 it stopped working, any insight? | |
97rivsc Fanatic
| Subject: Re: FAQ: Fuel Door Release Problems Tue Nov 18, 2008 9:36 am | |
| I think the relay might also be out cuz the button no longer does anything, not even a click like most other people | |
| Subject: Re: FAQ: Fuel Door Release Problems Tue Nov 18, 2008 10:37 am | |
| What happens when you pull the release in the trunk? Does the door spring open? | |
| Subject: Re: FAQ: Fuel Door Release Problems Tue Nov 18, 2008 12:12 pm | |
| When you are washing the car, consider using a sponge or some such with a spray-on cleaner (like Simple Green, or teh Castrol stuff in teh purple bottle/can) to wash the gunk off the gas door hinge, then use WD-40 or lubri-plate (a spray on lube that clots up in the air and stays where you spray it) to re-lube the hinge. If your hinge is rusty you may want to use some steel wool to clean it off, then when it's dry apply a rust converter (makes it a black primer in a day or so) and then schmeer it with axle grease (squeeze some from your grease gun) or spray with the lithium stuff used on garage door hardware.
97rivsc Fanatic
| Subject: Re: FAQ: Fuel Door Release Problems Tue Nov 18, 2008 1:01 pm | |
| ya it springs open when i pulled the release in the trunk, so its the switch that isn't working | |
DEMonte1997 Aficionado
| Subject: Re: FAQ: Fuel Door Release Problems Thu Nov 26, 2009 1:57 pm | |
| I have this same problem. Door clicks with I hit the button so it's just binding somewhere. Will try a little more bending of the tab that sits against the rubber stopper in the door. I'm guessing that piece gets bent the wrong way over time so that it sticks. Will also clean everything in there with WD-40. | |
| Subject: Re: FAQ: Fuel Door Release Problems Thu Nov 26, 2009 3:19 pm | |
| - DEMonte1997 wrote:
- I have this same problem. Door clicks with I hit the button so it's just binding somewhere. Will try a little more bending of the tab that sits against the rubber stopper in the door. I'm guessing that piece gets bent the wrong way over time so that it sticks. Will also clean everything in there with WD-40.
Open it up and get someone else to hit the button. The solenoid that opens the plunger might be sticking or worn. Maybe get replacement from Ed Morad if that is the case. Albertj | |
Hard4unot2 Amateur
Name : Herb Location : Detroit Joined : 2009-12-18 Post Count : 41 Merit : 0
| Subject: Gas Tank Cover Wed Jan 13, 2010 3:44 pm | |
| And this morning I must have pulled the gas tank cover release in the trunk too hard and now it won't close... how hard is that fix? (95 Riv sc) (I don't know why my Signature won't show) | |
| Subject: Re: FAQ: Fuel Door Release Problems Wed Jan 13, 2010 3:51 pm | |
| I suspect grime in the gas door area, the release is just a small plastic pin that gets retracted by a cable. The cable is frozen or the pin is stuck closed. There is also an 'emergency release' cable in the trunk, right behind the gas door. Make sure nothing is pulling on that.
In your user prefs you need to 'enable' your sig. Go to your Profile page, click on the Preferences section and "Always Attach My Signature" | |
brians74x Enthusiast
Name : Brian Age : 50 Location : Hanoverton Ohio Joined : 2010-02-25 Post Count : 100 Merit : 1
| Subject: Re: FAQ: Fuel Door Release Problems Tue Mar 23, 2010 10:39 pm | |
| All else fails use a slightly bent platic card like a debit card and insert were the latch and the lid meet and presto | |
| Subject: Re: FAQ: Fuel Door Release Problems Wed Mar 24, 2010 12:12 am | |
| All I had to do to mine when it wouldn't open was: #1 Open it manually #2 Clean and lube with WD-40
That was several months ago and no problem yet.
Have added lubing the mechanism to my Preventive Maintenance items. | |
| Subject: Re: FAQ: Fuel Door Release Problems | |
