 Write-Up: Installing a Rear Strut Tower Brace
Goto page : 1, 2  Next
Merit: 61
PostSubject: Write-Up: Installing a Rear Strut Tower Brace   Wed May 14, 2008 10:56 pm
I got a STB to fab for the rear today. Before going any further I'd like to give a big WTF!! to GM Parts Direct for charging me $10 shipping and handling and not bothering to put my STB in a BOX.
mad mad mad mad mad mad mad mad mad mad mad mad
Now that that's out of the way . . .
Session 1 -
After pulling the plugs that give access to the top of the shock mounts, remove this piece of carpetting from behind the seat. This will let you fold the side carpetting down low enough that it won't get in the way of your bar. You'll have to cut the carpetting later, but this will do for now. Put some weights on the carpet sides to hold it out of your way.
I used a nail to mark the area that needs to be removed to fit around the top of the strut mount, then used a hack saw and a cutting wheel on a dremel to cut the area out.
An extension will need to be welded on at each end of the STB.
Next step - find better drill bits.
Session 2 -
I got my bits. I'm not sure but maybe all bits are good for metal and wood both, after all. BUT, I got a special set of split head bits that do not walk, how pimp is that? Finding them was an interesting experience in itself, they were in a semi-abandoned part of an old mom and pop store, the owner didn't even know he had them. I couldn't resist the old part of the store, it has the feeling of a forgotten ruin. I'm not sure but I think I got them at the price they cost 15 years ago. I love that store. I think it will soon be wiped out by a bypass.
Anyway, I drilled my holes in 3 stages because steel is frickin' tough. The instructions with my drill said to use "cutting oil" when working metal. I used motor oil from my last change. I don't know if it helped with the drilling, but the metal shavings stuck together in a more manageable pile.
Here's what the finished extensions look like.
The pilot holes. I did the curve part of the cut out with the drill, used a hacksaw on the sides, and then the bench grinder and a dremel to clean up the sides of the cutout.
Test fitting - it turns out the cut out I made in the STB is not too large after all, as it allows for the rubber caps to be installed. This not only looks pro, but the caps help hold the STB in place while test fitting.
Session 3 -
I bolted the extensions down where they should be, and glued the bar into place with JB weld. I used a couple pieces of wood to wedge the STB down good on the extensions. When the JB weld dried I removed the assembly - one of the extensions broke off because of the tight fit. The JB Weld served as a guide to get the extension lined up right again on the bar. I superglued it back on.
This ain't Monster Garage, but I did get a FREEBIE!
FREEBIE!
FREEBIE!
(And I'm related to that Jesse James guy through Frank James, if family lore is true)
Anyway, free welding. WOOT!
The install was a PITA, because the shocks slowly retracted under the weight of the tops, and I did not figure out what the deal was until the end. But if you, dear reader, decide to try this mod, know that all you have to do is reach into the wheel well and push those puppies back up where they belong. You don't have to do like me and throw dead bodies in the trunk until it's sunk down onto the shocks again.
Here's the finished result -
It's clean looking if you cut the carpet in the right place.
For those worried about trunk space, there's plenty left, due to the way the brackets push the crossbar forward.
Driving Experience -
1st drive with the rear STB installed - IMO it's as good as the reinforced front STB. If you remember my comments following the addition of the reinforced front STB, I felt like the front handling was stronger than the back, and the back had become a bit squirrelly. I dialed my shocks up from 3 to 5, which was better but only a partial fix.
Now, the rear is most definitely quicker than the front again. The squirrelishness is completely gone. The back end is just fucking tight. Overall the car responds pretty quick, with the back and front starting to rotate instantly but the front going into a hard lean and plow. I say a "hard lean" to compare it to the marshmallow soft roll of the stock front suspension - it's not bad bad but it needs a big boost to catch up to the rear.
2nd drive - Dialing the Rancho's down took half the fun out of the suspension frown I couldn't feel any squirrels in the back though - I turned the shocks up to 4, looking for a better balance.
For the 50-60 bucks it takes to do this mod, I don't think anyone will be disappointed in it.
BillBoost37
Merit: 23
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Thu May 15, 2008 7:46 am
GMPD's shipping costs and methods do leave a lot to be desired.
What is that STB from?
98riviera98
Merit: 7
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Thu May 15, 2008 8:24 am
your daddy's caddy razz
but really its from a STS
Merit: 61
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Sun May 18, 2008 10:39 pm
It's the same STS bar we've been putting on the front. It only needs a little stretching to fit on the back.
Merit: 23
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 9:18 am
How much difference do you think a rear STB will make?
1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks
http://rivfaq.bravehost.com/
98riviera98
Merit: 7
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 3:27 pm
i like my tribal drums in mah trunk
Merit: 172
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 3:40 pm
agree I've only got one small bongo, but I'm not givin' it up for a brace. I like the idea a lot, though. Anything to stiffen up the ride is great.
- John R. White, Boston Globe
98riviera98
Merit: 7
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 4:01 pm
shocked lmfao lmfao lmfao lmfao lmfao lmfao
Merit: 172
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 4:33 pm
Hey, it's not large in diameter, but has one hell of a stroke! cool
Merit: 61
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 9:22 pm
I kinda think the STB will be useful for keeping things from sliding around the trunk. The cargo net doesn't do much.
Obviously not. Look what I found on my brace today -
Small world, ain't it?
I'm more interested in ever to see what you come up with for a front STB, since you didn't think the STS unit was up to snuff.
98riv - No idea, but I intend to find out tomorrow.
Part of me thinks it will help out a lot, because the rear shock towers aren't tied to anything substantial like the firewall the way the strut towers are. But there's already a brace under the package shelf which might be doing the job. I kinda doubt it though, it doesn't look very strong.
As little as it costs, I figured it was worth a try, and at least I can say I was the first to do it. A little balm for my suffering ego while everyone else is doing cams and intercoolers bow
Merit: 172
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 10:20 pm
You've got to be kidding me... I've been waiting on that bar for over a month now, paid for it even. There better be a bar with the name "Jeremy Ray" laying on my desk this week, or GMpartsdirect is going to be hearing from me.
It is a small world indeed, Jack. There were two people in this country who ordered that bar last week, and they manage to mix them up.
98riviera98
Merit: 7
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 10:51 pm
if you don't mind me asking how much did you guys pay for the bar and shipping and handling?? im gonna buy another one from the Cadillac Dealer soon...... just to mess around with for the front
smile
i paid 33$ even at the stealership! for my first front one
Merit: 172
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 10:58 pm
$37 shipped to Jack's house.
Merit: 61
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 11:01 pm
Oh man - here I was thinking the bar was most likely a return, but in the back of my mind, as I was taking that tag off, I was thinking - what if? What if it wasn't a return, and here I am, having just hacked Aaron's bar all to pieces (I didn't notice the name on the tag until today)?
shocked Oops, sorry about that!
Maybe they'll send you my box to make up for it. dunce
FWIW, I've been waiting for the bar for a month too. I'd nearly forgotten about it when the Fed Ex guy showed up a few days ago.
Merit: 61
PostSubject: Re: Write-Up: Installing a Rear Strut Tower Brace   Mon May 19, 2008 11:05 pm
Be a pal and let me know when you order an intercooler, o.k.?
Page 1 of 2Goto page : 1, 2  Next
» Thanatos Tower Quest
» Ignition and Rear Lights
» REAR DISK BRAKE SET RM450
» EVO UPGRADED BRAKE KIT REAR - USE WITH 17x8J ET25 TOMBINOS
» Write-Up: Installing a Rear Strut Tower Brace
