 Transmission swap
3 posters
Merit : -16
Transmission swap Empty
PostSubject: Transmission swap   Transmission swap EmptyThu May 22, 2008 5:48 pm
Okay, as I was looking through Ed Morad's parts I saw the tranny from a newer Riviera ('97 I think) and that got me to thinking - can I swap my current transmission with that one? Would I have to buy a PCM from a '97 Riv as well? I'm just thinking, if my tranny ever goes out I could just replace it with a newer one that I could actually use a tuner with instead of my current one that I cannot.
Buickman104
PostSubject: Re: Transmission swap   Transmission swap EmptyFri May 23, 2008 12:21 am
Yes you can. Oldsman is doing it. You would need the PCM, driver's side axle, maybe spindles. That is all I can remember off the top of my head.
BillBoost37
Merit : 26
PostSubject: Re: Transmission swap   Transmission swap EmptyFri May 23, 2008 7:01 am
Close Buickman.. great info.
Actually it's the passenger side axle that is different. The number of splines are different from 4T60 to 4T65. I think Olds said spindles will stay the same.
PCM, and some minor wiring will be needed to change the connector for the trans. I think it adds 2-3 wires. You would need to run those extra wires into the cabin to the pcm.
Transmission swap
» Transmission swap
» Transmission swap upgrade
» I think I might actually go with my M62 instead of an M90 top swap
» L36 top swap
» Write-Up: L32 (Series III SC) Install/swap, the saga continues
