 Horn Fuse
steve1173
Name : stephen rabinowitz
Horn Fuse Empty
PostSubject: Horn Fuse   Horn Fuse EmptySun May 25, 2008 8:13 pm
I have a 98. The horn & panic button on the remote does not turn on the alarm. Is there a fuse the dealer might have pulled so the alarm did not go off. Where is it as the manual does not say.
Horn Fuse Empty
PostSubject: Re: Horn Fuse   Horn Fuse EmptyMon May 26, 2008 12:33 pm
Will that remote lock and unlock the doors and open the trunk? Does the 2nd remote work?
steve1173
Horn Fuse Empty
PostSubject: Re: Horn Fuse   Horn Fuse EmptyMon May 26, 2008 2:00 pm
The remote unlocks the trunk & doors. The other remote dose not work. There is no chirp when locking & unlocking, not sure if there is supposed to be one. Dealer probably I hope removed the fuse but I do not know where it is. I think the 2nd remote needs to be programmed.
Horn Fuse Empty
PostSubject: Re: Horn Fuse   Horn Fuse EmptyMon May 26, 2008 2:38 pm
When your door is open does the 'security' light flash?
steve1173
Horn Fuse Empty
PostSubject: Re: Horn Fuse   Horn Fuse EmptyMon May 26, 2008 6:56 pm
Yes the security light flashes.
steve1173
Horn Fuse Empty
PostSubject: Re: Horn Fuse   Horn Fuse EmptyMon May 26, 2008 7:06 pm
Which fuse is it for the horn , I would like to eliminate the fuse before I go further. The owners manual in the index under horn fuse says see fuses & circuit breakers but the horn fuse is not listed. Is it on the side of the drivers door or under the rear seat or somewhere else.
Horn Fuse Empty
PostSubject: Re: Horn Fuse   Horn Fuse EmptyMon May 26, 2008 7:33 pm
The FSM doesn't mention a fuse, but they removing the horn relay, and with a test light you should see power on both #85 and #30.
Can you honk the horn from the steering wheel?
steve1173
Horn Fuse Empty
PostSubject: Re: Horn Fuse   Horn Fuse EmptyTue May 27, 2008 12:32 am
Cannot honk the horn with the steering wheel, also I pressed the panic button on the remote in case they are related & it did not work otherwise the remote works.
96riv
96riv
Horn Fuse Empty
PostSubject: Re: Horn Fuse   Horn Fuse EmptyFri May 30, 2008 8:48 am
Horn fuse is #4 under the hood passenger side behind headlight on my 96.
http://www.arizonagn.com
Horn Fuse Empty
Horn Fuse
» Maxxis Big Horn Tire Pressure
» How do I waterproof my fuse and eletrical components?
» Big Horn Tires
» fuse block
» Blue Sea Fuse Box Install
