 FAQ: Good Battery Replacement?
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
FAQ: Good Battery Replacement? - Page 8 Empty
PostSubject: Re: FAQ: Good Battery Replacement?   FAQ: Good Battery Replacement? - Page 8 EmptySun Nov 01, 2015 7:44 am
Years ago AC Delco/Delphi was the only option. Now aftermarket has batteries with the correct vent openings and sometimes even the vent tube (which is often broken). Due to the weather-safe location under the back seat, and the high CCA requirement, the "correct" battery will last a long time pretty much no matter what the brand name is on it.
The 'green dot' doesn't mean it's going to pass a load test wink
I bought a battery for an '04 Buick LeSabre that came with the vent tube assembly attached from Advanced Auto Parts. I can't remember the name of the brand they carry off the top of my head, but it was several years ago and it's still working properly...
PostSubject: Re: FAQ: Good Battery Replacement?   FAQ: Good Battery Replacement? - Page 8 EmptySun Nov 01, 2015 4:55 pm
Thanks Derek,
I went to Advance Auto Parts and got one for the Riv. Exact fit. No problems with vent tubes or install.
The old one just wouldn't take a charge anymore and would drop to 6 volts under a load.
Managed to find a $40.00 off code for Advanced, so saved some bucks and I'm back on the road with the Riv after about 5 months. smile
Page 8 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
» Battery replacement and chargers
» Replacing GP Battery - Self Vs Shop
» Battery Replacement
» GP3000 - info on Lucky Lark Battery and Coil
» My battery barely turns the starter. Could it be a bad a connection?
