llamalor2112 Junkie
Name : Evan Age : 31 Location : Granite Falls, WA Joined : 2012-07-13 Post Count : 852 Merit : 13
| Subject: Re: Valve cover gasket replacement - advice? Fri Feb 07, 2014 5:14 pm | |
| I just removed it. Going to need to look into new cover if I wanna replace that piece for aesthetics later. The bottom clips had to be broken off as they were fused on like stated above. Also the center slide-post on the vc removed half of itself with the plastic piece as I removed it...
Scratch, vc is cracked/chipped along front edge. Funny as leak before was from gasket failure on far right side ...now it leaks from the front center. Go figure, off to get a new set of covers like Zach's. Sigh... | |
