 engine vacuum at oil fill?
baynes72
engine vacuum at oil fill? Empty
PostSubject: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyMon Jun 09, 2008 12:46 am
ive done some work on my 95 s/c and the other day i noticed something and it may be nothing but im not sure. when i took off the oil fill cap there was a good amount of vacuum there and the car even ran a little diffrently. im wondering if my lower intake gaskets may be leaking or maybe i did something even more stupid and installed something wrong headbutt
Merit : 154
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyMon Jun 09, 2008 2:56 am
Hmmm... isn't that normal?
baynes72
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyMon Jun 09, 2008 5:19 am
maybe, just never noticed it before. ive owned this car twice now and the car was sold twice between now and the previous time i owned it. both owners beat the car badly (one drove it from northern indiana to georgia with no supercharger oil). i noticed that the intake and supercharger bolts were mixed up when i changed the blower so i dont know how deep the people went into it. could be worried about nothing but thought id check
urbsnspices
urbsnspices
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyMon Jun 09, 2008 10:44 am
I think a little vacuum is better then a little pressure. Your pcv valve should maintain a little vacuum. May just want to pop in a new one if you never have.
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyMon Jun 09, 2008 1:12 pm
Yes, there should be vacuum at idle, but not like a vacuum cleaner. afraid
baynes72
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyMon Jun 09, 2008 3:31 pm
lot like vacuum cleaner. do you guys think im headed in the right direction with lower intake? or what else should i try?
BillBoost37
Merit : 25
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyTue Jun 10, 2008 10:09 am
I don't see the lowers doing it.
Thinking about this..the lowers have intake and water passages only. There is quite a bit of material and added sealing lines between the oil return areas and the intake runners. Vacuum like that is typically a pcv issue. Meaning when the PCV clogs it allows vacuum from the intake manifold to be pulled on the crankcase. Where as when the pcv functions properly it shoudl keep any vaccum from being pulled on it, only relieving pressure from blow by etc.
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyTue Jun 10, 2008 11:16 am
First and cheapest option is replace the PCV. Cheap part, but you won't find a gasket at the parts store, and it's not needed. Just use a thin layer of RTV when you put the PCV cover back on. If the old PCV rattles freely, you likely have other issues. Can't say I've ever heard of someone having a lot of vacuum pull at the oil cap.
98RIV7777
98RIV7777
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyTue Jun 10, 2008 2:16 pm
Ya, definately replace the pcv if you've never replaced it before first, this should solve your problem smile
baynes72
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyTue Jun 10, 2008 2:20 pm
ill do it today. and will post results. and thanks for all the info.
baynes72
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyThu Jun 12, 2008 11:26 pm
done. running much better thanks to all
BillBoost37
Merit : 25
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyFri Jun 13, 2008 7:38 am
Was it the PCV?
baynes72
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptySat Jun 14, 2008 3:25 am
i hate to admit it but i forgot to check the valve for rattle when i changed the supercharger and it was stuck, kinda feel a little dumb right now...
Merit : 154
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptySun Jun 15, 2008 3:55 am
...not as bad as leaving the connector off the airflow sensor when replacing the air cleaner, or leaving the gas cap loose...
98RIV7777
98RIV7777
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptySun Jun 15, 2008 11:37 am
Good, I am glad you fixed your problem
BillBoost37
Merit : 25
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyMon Jun 16, 2008 8:08 am
Checked or not ... it's nice when things are an easy fix. Smile and have a beer.
baynes72
PostSubject: Re: engine vacuum at oil fill?   engine vacuum at oil fill? EmptyMon Jun 16, 2008 9:51 pm
i think i will
» How do I Prime my 4 stroke engine?
» RCGF 45cc Petrol Engine
» Tecumseh engine
» How man cc is an 11hp engine?
» Poss. sale of 09 RZR "S" engine
