 Supercharger.....Listen Close?
Supercharger.....Listen Close? Empty
PostSubject: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyTue Mar 06, 2007 3:36 pm
my buddys brother put an aftermarket supercharger in his 96 mustang..it makes a lound noise when it kicks in...
i have the supercharger....does it make a noise when its activated/kicks in?
or is it always running therefore always mixin with the natural engine noise?
Thanks
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyTue Mar 06, 2007 4:19 pm
I can usually hear the blower whine when the BBV is utilizing boost. If you hear it, you could say it's "activated". A good example is in OD when climbing a hill. You'll hear a lower pitched whine, even at 1800 RPM or so, whereas you normally wouldn't if you're not under load.
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyTue Mar 06, 2007 4:27 pm
your stock intake has resanotors to muffle the sound out. Put a CAI or FWI on it and you will here it quite clearly.
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyTue Mar 06, 2007 4:43 pm
Thought the '95 had a pre-gutted air box. Should be able to hear the whine when the engine's under load. Maybe you aren't pressing the pedal hard enough... twisted
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyTue Mar 06, 2007 6:03 pm
only the baffles are removed the resnotaors on the pipe are still there. trust me remove stock intake put a straight one in and be prepared for a surprise twisted
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyTue Mar 06, 2007 7:30 pm
what do u mean "suprise"?
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyTue Mar 06, 2007 8:26 pm
The loud supercharger whine you will get.
NO 4 EVR
NO 4 EVR
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyTue Mar 06, 2007 8:31 pm
Speaking of sc noises, does anyone else hear when the BBV releases boost? Like when you ease of the throttle after hitting it? I try to tell people in the car to listen for it, but they can't hear it. You guys know what I mean?
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyWed Mar 07, 2007 9:12 am
I can't hear my BBV. frown
NO 4 EVR
NO 4 EVR
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyWed Mar 07, 2007 1:40 pm
I don't mean to hijack the thread, But if I hit the accelerator and get the boost built up, and if I let go of the accelerator to about 1/4 I hear a release of air. I don't know if this is normal, but I know for sho I can hear it. I may try to record it with my phone or a better digi camera, but can't promise it will work out. It is louder when I ease of the accelerator when the RPMs are high. And I can hold the accelerator at that critical point sometimes and I can hear it constantly letting out a little bit of boost as long as I hold the pedal in the same position.
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyWed Mar 07, 2007 1:50 pm
Only time I'm ever heard anything consistent with that was when my belt was slipping. It was more of a chirp, but could be interpreted as air, and it happened exactly when you're saying you hear the noise.
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyWed Mar 07, 2007 1:56 pm
is it a hissing sound? like a vac leak? i cant hear my valve open or close...but i can feel it 3gears
if i hit the throttle and let off of it all i hear is the rotors winding down.
btw its probably not good for the engine to go from WOT to 0% throttle rapidly, especially if you floor it again before the engine has time to figure out what your trying to do. (both A/F and tranny get confused)
Supercharger.....Listen Close? Dsc_0110
NO 4 EVR
NO 4 EVR
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyWed Mar 07, 2007 5:09 pm
I don't do wot and back down. Just enough throttle.
NO 4 EVR
NO 4 EVR
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyWed Mar 07, 2007 5:15 pm
Why would my belt slip tho? Its in good condition. The only noise I am worried about is the SC coupler noise. And I just hope my bearing isnt bad on the SC too.
NO 4 EVR
NO 4 EVR
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyWed Mar 07, 2007 6:34 pm
Ok I just went out with my roommate and had him listen to the sound. He heard it. It sounds like air. I don't think it is belt slip because I can hold it at low throttle and go slow and still hear it, and make the sound stay consistant or just for a second. It really sounds like air being blown out like a BOV
PostSubject: Re: Supercharger.....Listen Close?   Supercharger.....Listen Close? EmptyWed Mar 07, 2007 6:39 pm
I have had someone tell me that they heard something that sounded like air was released from a valve when I let off of it. He wasn't in the car, so maybe he could hear it better. It probably just came from my intake.
» Scuba Pro Twin Jet Max close foot fins?
» May's Photo Challenge - Close Up
» close season in the lakes?
» MPI SUPERCHARGER for a 660 RHINO For Sale CHEAP!
» Close contact weapons 2005
