| 96 Riv with a 4T65 transmission | |
+3palermocorey90 Chicken BillBoost37 7 posters |
BillBoost37 Junkie
| Subject: 96 Riv with a 4T65 transmission Fri Jul 04, 2008 8:08 pm | |
| The skinny here is doing the swap from the 96 4T60 to the more easily moddable 4T65. And in Oldsmans' case..from a dead trans to a working trans. I arrived in NYC yesterday and Enriques car with dead transmission went under the knife about 7pm. Three lunatics worked through the night to swap transmissions, swap pcm's to a 97 and rewire the necessary transmission wiring. Thanks go out to TType Riviera for wiring diagrams, Corey for some general info...Bonnie buddys, Aaron and Mike. Aaron did the swap in the past on his car and Mike hit the 97 FSM's for a wire that wasn't in the 97 Riviera PCM connector listing. The help from them was invaluable. The happy report is our only hang up when trying to turn the key was the car not starting due to it not seeing itself as being in park. There is a metal piece that sits on top and operates via the shifter cable. Between the shifter cable bracket and that piece.. the car thought it was in reverse and wouldn't start. Some quick diagnosing and it was rolling through the shift pattern. Enrique is finishing up the fix up. More to come with pictures from him. edit.. Enrique is done and the car starts correctly. Test drive soon to come. PS..hey Corey.... your gear selector armature is from a 4T60 | |
Chicken Aficionado
Name : Mark Age : 57 Location : Montana Joined : 2008-06-13 Post Count : 1296 Merit : 8
| Subject: Re: 96 Riv with a 4T65 transmission Fri Jul 04, 2008 8:24 pm | |
| Nice....
Can you do a write-up? | |
palermocorey90 Expert
| Subject: Re: 96 Riv with a 4T65 transmission Fri Jul 04, 2008 8:36 pm | |
BillBoost37 Junkie
| Subject: Re: 96 Riv with a 4T65 transmission Fri Jul 04, 2008 10:11 pm | |
| Gonna let Oldsman do the write up as soon as we can get him away from the car. He didn't have 3rd gear or a supercharger belt for quite some time. | |
Chicken Aficionado
| Subject: Re: 96 Riv with a 4T65 transmission Fri Jul 04, 2008 10:17 pm | |
| - BillBoost37 wrote:
- Gonna let Oldsman do the write up as soon as we can get him away from the car. He didn't have 3rd gear or a supercharger belt for quite some time.
I didn't know Oldsman was Amish! | |
TType_Riviera Fanatic
| Subject: Re: 96 Riv with a 4T65 transmission Sat Jul 05, 2008 10:14 am | |
| Nice Job guys!!!!!!!!!!!! glad i could help... thos damn range selectors suck though, did you have to ohm it to the right spot?? | |
Buickman104 Enthusiast
Age : 38 Location : New York City Joined : 2007-11-29 Post Count : 156 Merit : 0
| Subject: Re: 96 Riv with a 4T65 transmission Sat Jul 05, 2008 10:54 am | |
| - TType_Riviera wrote:
- Nice Job guys!!!!!!!!!!!! glad i could help... thos damn range selectors suck though, did you have to ohm it to the right spot??
No we just used the one from the 96 4t60. | |
BillBoost37 Junkie
| Subject: Re: 96 Riv with a 4T65 transmission Sat Jul 05, 2008 2:10 pm | |
| No, the range selector switch actually has a dot on the inner ring that lines up with a line on the switch.
But the selector actuator (little armature) was the issue.
We nabbed a picture of the dot and line on the PNP that need to line up. | |
| Subject: Re: 96 Riv with a 4T65 transmission Sat Jul 05, 2008 2:21 pm | |
| Congrats! looking foward to the writeup.
BillBoost37 Junkie
| Subject: Re: 96 Riv with a 4T65 transmission Mon Jul 07, 2008 7:15 am | |
| All the road tests were successful and overall this swap was easy.
Things we had on hand that made it easy were: PCM and trans pinouts for both years The new trans year pcm and trans connectors with some wiring. The axles were researched for inboard and outboard splines as well as length (rockauto is great for this) Some extra wire, soldering iron and electrical tape.
Things we found along the way. I don't have good memory skills and got the wrong side axle from the JY for cheap. The trans armature that is moved by the cable for gear selection depends on the vehicle. Three guys in a super clean shop can lose a subframe washer. The trans shop that put the last rebuild in didn't replace the backwards bolt. (Behind engine. Unlike the rest of the bolts that go in from the trans to engine, this one goes into the engine first and holds to the trans.)
Overall I'd rate the project pretty easy from a technical standpoint. Mechanically it's the same as changing a transmission. Using Deekster Caddy's writeup it's a snap. | |
| Subject: Re: 96 Riv with a 4T65 transmission Mon Jul 07, 2008 11:45 am | |
| As long as we follow the proper steps and do things carefully. Next time we need to swap trans, I believe we may be able to do this by our selfs!
As long as we can call Bill when we scrwe uo or forget something! | |
BillBoost37 Junkie
| Subject: Re: 96 Riv with a 4T65 transmission Mon Jul 07, 2008 1:07 pm | |
oldsman105 Junkie
| Subject: Re: 96 Riv with a 4T65 transmission Mon Jul 07, 2008 2:55 pm | |
| I was getiing to it. I got send out on a errand at work. | |
BillBoost37 Junkie
| Subject: Re: 96 Riv with a 4T65 transmission Tue Jul 08, 2008 7:34 am | |
| Just busting your chops....
How's it running? | |
oldsman105 Junkie
| Subject: Re: 96 Riv with a 4T65 transmission Tue Jul 08, 2008 8:39 am | |
- Just busting your chops....
How's it running? Like a champ. Will be ordering my Shift kit next before I grow to accustomed to the luxury shifts its making now. | |
BillBoost37 Junkie
| Subject: Re: 96 Riv with a 4T65 transmission Tue Jul 08, 2008 9:15 am | |
| Aaron.. can you coach us on DHP shift times and tables? | |
| Subject: Re: 96 Riv with a 4T65 transmission | |
