 Power Antenna ??
Power Antenna ?? - Page 3 Empty
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptyTue Mar 17, 2009 12:11 pm
You could wire your own switch to the antenna, independent of the radio. I forget exactly which wire it is, or if it's+ or -, but it's just an on-off signal.
dscott2000
dscott2000
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptyTue Mar 17, 2009 10:34 pm
I agree.. That would be the best way. It would just be easier.
http://www.cardomain.com/ride/3061543
sqrivi
Merit : 52
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptyWed Mar 18, 2009 12:00 am
Does your stereo have both a blue wire and a blue with white stripe? If so hook your power antenna wire to the blue/white wire instead of the blue. This way the antenna will be up whenever the stereo is on. You could also connect the power antenna wire to the ignition wire powering the stereo. This will make the antenna go up whenever the ignition is on.
99prixgt
99prixgt
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptyWed Mar 18, 2009 12:23 am
you could tap the antenna wire to the accessory wire on the radio, so it will go up when the radio turns on and go down when the radio goes off.
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptyWed Mar 18, 2009 2:55 pm
better to use just a swich or connect the blue wire whit the aftermarket radios blue wire(remote antenna)
if u connect it just whit the ignission then you can not turn make it go in when the car is running. well its good in some automatic car waches.
duster_do_little
duster_do_little
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptyWed Mar 18, 2009 3:07 pm
Yeah, I have blue with white and just blue. So if I took the stereo out and hooked the blue with white up to the antenna, then it would still go down when I turned the stereo off?
I didn't buy the wiring kit, I just hard wired it all in, so it's not tough to cut the wire and sauder it to a different wire. Fitting all of the wiring back in behind the stereo will probably be a PITA though, lol...3 sets of RCA's, antenna adapter (universal, so it has quite a few plugs on it).
Is there an easier way to get everything to fit back there? Like a panel I can take off so that I can still get to the wires to move them while I'm pushing the stereo in.
sqrivi
Merit : 52
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptyWed Mar 18, 2009 3:29 pm
Yes, connect the antenna to the blue/white and the antenna will go down when the deck is turned off.
millerje18
millerje18
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptySun Aug 02, 2009 1:09 am
is there a way that the antenna would not come up at all, even if your listening to the radio?
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptySun Aug 02, 2009 8:23 am
that depends on the head unit. Not with stock, but I had an aftermarket head unit once that would close the power antenna when you weren't using the radio. I wish I could remember the brand but it was a looong time ago. You could always skip the head unit and wire the antenna to your own switch, manually controlling the up/down.
sqrivi
Merit : 52
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptySun Aug 02, 2009 9:20 am
(With stock radio) when the antenna is in the down position, at the antenna in the trunk, unplug or cut the wires going to the antenna. No need to unplug the larger antenna cable itself, just the smaller wires. If you cut the wires cut them one at a time.
(with aftermarket radio) don't hook up the blue wire on the back of the radio.
millerje18
millerje18
PostSubject: Re: Power Antenna ??   Power Antenna ?? - Page 3 EmptyThu Aug 06, 2009 10:48 am
thanks derek and scott. it worked out good. i think i like the look of my riviera without the antenna. only problem now is that when i search through my stations it skips a couple. ugh.......... ill see if i can deal with it.
Power Antenna ??
» Power Mods ????
» power chips or modules
» Power Plays
» Repairing power lead
» Duro Power-Grips ,25x8x12,25x10x12 $125.00
